Tool inspection/ change switch
JrScott
I have a part that I have programmed and wanted to add tool inspection every so often. The switch appears broken. I contacted my reseller and he said this was a known issue and supposed to be resolved in the next release. Was wondering how many of y’all have had issues with this.
10 hours ago, JrScott said:
I’m running a custom post ability post for a Mazak variaxis i700. This is a morph 5 axis tool path with all axes moving on a very weird shaped piece of wasp alloy.
They don't have Tool Inspection in the 5 Axis toolpaths that I am aware of you have to break up the toolpath to get it.
1 hour ago, JrScott said:
The switch is in the new unified 5 axis tool path. It is right under the select library tool button on the tool page.
Sorry I hadn't seen it in my use of Unified since I have been stuck in MT land for sometime. That is not an option in MT.
I tested this in Mill using a 3rd party post and it worked good.
Edited by crazy^millman
Pictures removed to add space
Should be working fine for you?  Here's a simple morph in 2022:
Here's what I see if I set a tool inspection every 15 inches:
If you investigate the NCI, you'll find a full header output preceeded by:
Can you be more specific about what doesn't work?
Oh, I should add that it only can get triggered on a linking move after you hit the inspection point, so you may need to rearrange your toolpath if it's one continuous cut.
