HELP WITH G54.4
motor-vater
There's a lot going on in that post <laughter>
Regarding the alarms, my guess is there could some parameters set incorrectly.
To know how to properly answer some of them I'm going to need a copy of your machine's parameters. Send me a DM or e-mail me directly.
Now, regarding probing while WSEC is active, your Renishaw InspectionPlus software needs to be fairly new... say within the last 3 years AND you need some parameters set correctly. If any of those two are deficient it won't work.
Regarding handle positioning while WSEC is active, I've only ever tested/checked to see if my part was flat after error correction. If there is error on your theoretical axis it will require a simultaneous XY move to check straightness of an edge. I've not run a table/table 5-Axis that had handle jog that could move 2 axes simultaneously.
Shoot me your parameters and I'll take a look. I think I'll have a little time tomorrow while my part runs and I wait for a CMM report. Also let me know of the machine is a 31i-A5 or a 31i-B5.
Just had this very issue on 4 different machines in the last month from a OEM with parameters not set correctly. I was being told it was posting and code issues. I took 3 different posts for one machine and came up with the same code then it was hard to argue it was the post.
I'm looking for the shocked face emoji. THe suck thing about ALL of this is FANUC gets the bad rap here and the MTB comes out smelling like a rose... even though they are 100% at fault for not getting the support they need from FANUC (which BTW they are more than happy to help MTB's get squared away).
I'm not sayin' I'm just sayin.
Fanuc was who help sort it out the MTB was not helpful at all. The AE is doing his best, but he is getting 10 different directions from the MTB and asking me to help sort it out. I have developed a test block for running 5 Axis machines through several different motions and toolpaths to test them. I mix 3+2 and full 5 Axis features on the part with a CDS on one of the faces with a Swarf Cone toolpath on the ID of the CDS. All 3 points on the CDS come together nicely in 3+2 and the different transition of 5 Axis with 3+2 finishing then the machine and post should be able to handle just about anything anyone throws at them. The OEMs like it because no more waiting for the customer to get around to running the machine to sign off on it. The run the test block give them a good part and prove the machine is good. Your CAM System is not up to the task then they tell them to call me and I recommend Mastercam. Yes that is the CAM Software I use to earn a living so it will be what I recommend.
I would love a copy of that file! I have a couple I've made over the years myself, but I'd like to see the master's work.
When I find the Master your referring too I will let you know. Sorry this one I am holding close to the vest. Had one of the MTB customers not using Mastercam want to share it with all of the shops in their group and I specially told them that is 5th Axis CG Inc. Intellectual property. They can purchase the model to be shared in their group only, but they don't own the right to that file. I do some fancy lettering on one of the faces with a ball endmill for each MTB or customer I provide the test block for. Nice dog and pony show. I have people make them out of 6061-T6 and they look really nice when completed.
We typically do a modified NAS979 (we had to buy the obsolete standard from NIST IIRC) combined with a feature from the ISO TC39SC2 - N2185 standard (that we also bought). We had a customer requirement for machine tool buy-off one time so this particular test file was the result of that effort and expense.
Along with the ANSI NCITS 37-1999 APT Standard because a CAM vendor with a massive superiority complex told me they "strictly" adhered to the APT standard <laughter>. I said yeah, you adhere ot the APT standard like everyone adheres ot the IGES standard. I was LOL he was not. <more laughter> When proven wrong... #crickets Smug bastid.
The reality So Not A Guru is you do not need anything complicated to test/check #19700-#19705 parameters on a trunion machine. A 2" x 2" x 2.5" cube with uniform pockets width, length, and depth on the 5 Exposed Sides. Face the top with the end of the tool, do a contour for the 2x2 with the sideof the tool. Mic it and adjust cutter comp to get the perfect size, then mill all the pockets. The individual walls will tell you which direction (if any) you need to move things.
Remember kids, kinematic numbers are not necesarrily the same numbers as COR work offsets. I made that mistake once. <laughter> Work offsets CANNOT compensate for the 1/2 Offset Error(s) (#19703-#19705)
For what it's worth > Haas now sells a MRZP Test Cut Kit, which includes everything needed to make a test cut (besides the block of aluminum).
https://www.haascnc.com/service/troubleshooting-and-how-to/how-to/umc---mrzp-test-cut-kit---ad05450.html
PN: 93-3347 UMC - MRZP TEST CUT KIT
This kit comes with a self-centering vise, and 3 tools (complete tool assemblies), needed to cut a test block, to find and correct MRZP Errors, using their 'standard test program' (which you can find in that Haas Link above).
Leave it to HAAS to put a endmill in an ER holder and say that is a good way to make test cuts on a part.
  • Haha 1
This is, essentially, what I've made. I've used it on several different machines to determine the necessary adjustments.
Update, Test part back from inspection. I am doing something wrong in the errors page for sure... My holes were shifted + 0.028 in my X direction. Every thing else I cut seemed right... Manager loosing patience, sad because I am this close to making a life changing thing happen in our set up and they want to shut me down when I'm 0.028 from the finish line. Lol
Im gonna give it one last go in the AM before everyone gets there. So any last minute suggestions are appreciated. I have my G54 set to the theoretical perfect point of Origin (which is where I am programed from in mastercam) I calculated that from the Standard G54 point kept on the control for COR) I am trying to figure out the best way to set the errors. What I am doing is setting the B axis orientation to get my part straight, then probing the center of the part to get my X while the part is in its new B location. I am using G58 to store the values. Then basically subtracting the location of my G54 from G58 to update my error Values. In todays case that was b-.101 and x .0469 and a z of -.0544. Am I doing this wrong? Any last minute help super appreciated
When I'm not getting what I am after with a probe, I will go to XY Tilt and Rotary program 0.
Next I will set my relative XY Tilt and Rotary to 0. Next I will flatten the part and move to a feature I can measure, then out those error numbers in the appropriate axis in the WSEC AND put the Tilt and Rotary value of the actual Machine Position.
Z you'll have to work out by cutting and measuring.
