Left Hand Thread Mill Cutter Confusion
CNC CHRIS
First Time Thread Milling with a left hand cutter. i was told to use a left handed cutter because it was best suited for the type of material (titanium)
The call out for the thread is 1/4-28 UNJF - 3B
i Define my tool correctly and chose the spindle direction CCW.
On my cut parameters, i chose "ID Thread".
when its asking "right hand thread" or "left Hand Thread", is that asking for the thread on the blueprint call out or the type of cutter you're using?
I pressed the "help" button, and it says its the "thread you are cutting"
so i chose "right hand thread" since thats the call out on the BP.
then i chose "top to bottom" for the machining direction. and it says its going to be "conventional milling" but when i run backplot, i believe its climb cutting.
am i missing something?\
i have attached a file.
i am using MC2022
trial.mcam
go the the online Carmex threading wizard   Carmex Tool Wizard - Welcome
work your way through it selecting the correct material and a thread mill from the "HARDCUT" line
keep working through the wizard and use it to post gcode... that will show you what your code should look like
you should be getting a G04 , a G42 CDC callout and a top down toolpath
when using these cutters I lie to Mastercam and define the cutter as a single point tool so that I get a single toolpath from top to bottom
These cutters have 3 teeth and doing that gives you one finish pass and 2 spring passes all in one pass.
If you can, run the tool 3 teeth deeper than your depth callout.. as the leading teeth break down, the next two are still
making good spring passes and your thread will gage properly to the required depth
You get a safe repeatable toolpath that makes good threads for a long time.
