Fagor 8055 post help
2 hours ago, tsdunen71 said:
Thanks for any help
Nowhere near enough information.
Which Generic post? 3,4 or 5 axis?
Give an example of what you have and what you want in code.
A copy of the post if you have made any changes would also help.
I assume when you say Text you mean comments, which ones do you want to modify: tool comments (?), operation comments?
What Post are you starting with?
The variables for "comment start" and "comment end", are typically:
sopen_prn & sclose_prn
or
scomm_str & scomm_end
Example, change from this:
sopen_prn    : "("   #String for open parenthesis "("
sclose_prn   : ")"   #String for close parenthesis ")"
To this:
sopen_prn    : '(MSG" '   #String for open parenthesis "("
sclose_prn   : ')"'  #String for close parenthesis ")"
scomm_str : "("
scomm_end : ")"
To this:
scomm_str : '(MSG" '
scomm_end : ')"'
Thanks for the input I have part of the comments working. I have another bigger issue at the moment.  The machine is a fagor 8055 lathe we have mounted a second turret on the table. The new turret always cuts on the negative side of the X axis. I'm using the generic MPFAN post that came with  mastercam 2022. I have changed the line
dia_mult     : -2     #Multiplier for output on X axis (Neg. switches sign of X)
So it is now posting out with negative X moves. I also had to switch the G2 & G3 directions. My problem is its posting out positive numbers for the I and K moves for the G2 & G3 arcs. Can anyone tell me what to change in the post to reverse the I & K values to negatives?
Example its posting  G02 X-11.1242 Z-.0259 I.0172 K.0261
Needs to be
G02 X-11.1242 Z-.0259 I-.0172 K-.0261
Thanks for any help I'm pretty stuck
  • 3 weeks later...
