program cannot be run on 3 axis machine, verify error
Greetings All,
Part I'm working on, when I go to run a solid verification I get an error message saying program cannot run on 3 axis machine. The tool plows through the part when it goes to run the backside. The programs look fine in back plot after posting so, I'm not too concerned with them being bad. What did I do wrong and how do I correct it?
Doug
24 minutes ago, crazy^millman said:
WCS for each side? If so they need to be run for each WCS not complete in Verification.
I just got off the phone with tech support. It's a known issue with 2023 they said. There's an update I'm about to download that supposed to fix the issue. If you run one setup then click the down arrow next to verify selected operations and click add to current verification, the tool doesn't crash through the part.
Thank you, I've only been using Mastercam for a couple years and just started using it again recently. I still have a lot to learn...
I get this issue too on some 3D toolpaths. Update 1 did not fix it. You have to Disable GPU processing in config under Simulation. At least, that's the only thing that worked for me.
Thanks for the tip. They said the patch may or may not fix my issue. Fortunately, it did in my case
