Building High Feed Mills
JB7280
Just now, crazy^millman said:
Bull endmill with the recommend radius. Sorry I am still not 100% convinced defining a highfeed cutter is the best process in Mastercam.
So, how does that work Ron?  They give a a recommended program rad of .094", but that would put my actual diamter at .812" when ingersoll claims it to be .594.
I initially had the same thought, however it seems like that would leave unexpected islands and pyramids?  If that method works well though, I'll continue defining them as bull endmills, as it's a whole lot simpler.
It is a 1.000 diameter bull endmill with a .094 Radius. You don't need to define the smaller diameter on a bull endmill.
I'm missing something.  The green wireframe is a 1" bull endmill with .094rads, and the solid is the step file from Ingersoll.  Wont the areas in between be missed material?  Or is the step geometry wrong, perhaps?
I have used highfeed cutters for almost 20 years and I have always defined them as bull endmills. This process has always worked. Why does it work I did a complete math breakdown of this many years ago and realized yes it leaving a little extra material when defining it this way verses the High Feed way, but when you see major performance hits in some areas of Mastercam using Highfeed Cutters for tool definitions I will stick with the KISS method here.
  • Thanks 2
Sounds good.  Thanks Ron.  I'm just always worried about hitting one of those little ridges/peaks and going above the radius of the cutter.  Probably overthinking it though.
I've been using the High Feed tool and the manufacturer's step models for a couple of years now with no issues
I like doing this because you get accurate stock when you save an STL file out of a Verify session.
In the early days I had trouble with inserts getting crushed because the toolpaths were leaving cusps
the tool was smashing into them during back feed moves .  That problem seems to be solved now.
In the example I've attached, I built a tool from an Ingersoll step file, then saved the geometry to a level
and edited it a little
Notice in my example that I've lied in the Cutting length setting..
If I set it correctly the walls in a Verify session look like they've been cut with a .08R button cutter.
The resulting stl file was an unusable 120meg mess.
After tweaking the defining geometry and setting the Cutting Length to .300 my Verify STL's have nice clean walls
and yielded an 18 meg stl instead of a very messy 120 meg file
  • Like 4
24 minutes ago, gcode said:
I've been using the High Feed tool and the manufacturer's stl files for a couple of years now with no issues
and yielded an 18 meg stl instead of a very messy 12o meg file
What was the purpose for the longer than reality cutting length?  What other editing did you do, aside from the cutting length?
I noticed you mentioned back feed.  Do you find that high feed mills do ok with dynamic toolpaths?  I've always leaned more towards contours, and area mill.  Toolpaths that make a more "uniform" toolpath.  Something about dynamic toolpaths with a high-feed mill makes me feel un-easy.  But you guys have far more experience than me, so I'm open to other methods.
I made a tool using an Ingersol High Feed step file
I was cutting a profile with it, a 12 paddle star shape 115" across and 10" deep
With an .08R corner radius and an .08" step down the walls of the verify stl were very ragged and nasty.
The stl file saved out at 120 meg. Making a stock model from it took forever and yielded poor results
so
I saved the tool geometry to a level, edited the geometry to create a fake .300" flute length.
Everything else matches the original stp file.
The results were clean wall, an 18 meg stl file and a very nice stock model.
The bottom of the tool produces an accurate representation of the stock and the fake
.300 flute leaves a nice clean wall.
I do use high feed in dynamic optipath with no problems
You need to use the bottom diameter of the tool to figure your radial stepover
or you'll leave cusps behind that may cause trouble
95% I use dynamic toolpaths with high-feed mill, so far it always worked!
As Gcode mentioned above, I cheated a little with cut length but the rest of the tool geometry is straight from STL.
I have used this with good effect in both dynamic and 'straight line' programming.
what I have come across is that the tool does not like machining over pre-drilled holes.
so
I think I get it.  So the purpose of that false flute length was to clean up the stl.  nothing to do with the actual real life part.
The bottom of the tool issue is kind of why dynamic paths worried me with a feed mill.  So do you just try to use slightly less stepover than the bottom diameter?
Is there a chance you could post a file with one of your optirough feed mill toolpaths?  If not, it's cool, I'm just always curious to see other programmers' settings and methods.
The tool mfg will provide adoc & rdoc numbers...I generally use Mitsubishi but their recomendations have usually been pretty good...I can't imagine Ingersol would be different in their suggestions
Thank you for sharing that and letting everyone know how much better it is working. I will have to rethink my processes when I have another project requiring a highfeed cutter.
Ron, to your method, it seems that the "recommended programming radius" effectively leaves little enough material that it is small enough to not have an effect.  I'm sure you understand this already, but this diagram helped make a little more sense of it to me.
Correct.. the walls of the real life part look like crap because they are machined by an .08R stepping down .08"
but I don't care because there is still stock
Mastercam's stl file is a different story. The .300 cut length yields fake spring passes that leave a smooth clean dimensionally  correct STL file and a much more user friendly stock model
This is the safest way to program high feed cutters.
You will never gouge your part using this method. However, the stock you get in verify will not be accurate.
For small tools this probably doesn't matter.
For the Ø4 to 6" Ingersoll I'm using that remnant can be a tapered floor  .180" thick by .350 wide and needs to be present in your stock models
I've always defined them as a bull, with the theoretical radius in the tool definition, but also using the accurate geometry as a custom profile.  That way it calculates the toolpath as a bull, but makes the stock model accurate.  Yes, the stock model takes a little longer, but not terribly.
I have been using high feed mills for a long time as well. I do not like how mastercam handles some toolpaths with the highfeed tool geometry so I will define it as a bullmill occasionally for the dynamic or legacy toolpaths. The tool manufacturing models are usually not perfect 1:1 models either and I typically just use the dimensions they give on the websites to define my tools and I haven't had a problem defining them using this system (https://catalog.tungaloy.com/Item.aspx?cat=6993972&fnum=1297&mapp=ML&GFSTYP=I&srch=1).
In the past, I programmed them as a bull mill with the tool manufacturer's geometry for accurate stock model.  But I had problems with cusps that would interfere with my Dynamic/Optirough operations.  It was a hit or miss situation and I had to verify the toolpath after any parameter change to make sure that I wasn't leaving cusps.
I thought  that I would try the High Feed tool definition again and see what I can get.
I brought in a High feed mill model and let Mastercam try to define the tool automatically.  This is what I got
Then I started playing with the parameters and was able to get a much closer profile.  I matched the manufaturer's tip diameter, extended the length and was able to add the relief taper angle.  This is what I ended up with:
So far, after trying different stepovers and other parameters in Optirough, I have not gotten any leftover cusps.
Thanks Tom, et al for this thread
  • Like 5
I ran into a most unexpected result today when using a tool defined as a high feed mill.
I am using Mcam 2022 for this part.
Sorry, I can't share this file.
After defining the tool in the thread above, I used it in a very large part and this is the optirough toolpath that was generated:
I changed the cutter to a bull nose with embedded geometry from the manufacturer's STEP file and then made NO other changes and regenerated the operation and this is what I got and what I was expecting:
I went back and double checked everything and there is definatly something going on with Mastercam using some of the information from the high feed definition to keep it from stepping down a vertical wall and ruining the outside edge of the insert.
BUT it is not consistent.  I generated some other toolpaths with the high feed cutter definition and it worked as I expected.
The cutter is a Sandvik 2.0 dia. MH20 cutter which they are calling a "High-feed pocketing"  cutter and it works well for that application.  I ran a test in 4140 at Vc=625, Fz=.031, Ae=1.3, and Ap=.045.  after 27 minutes in cut, I couldn't see any wear on the insert and the outside corner wasn't blown out.
After 27 minutes:
So: I am back to defining high-feed cutters and bull nose and will deal with the cusp problem because I need to be able to step down veritcal walls.
I am going to reach out to Mastercam and see if they can offer some insight to when this happens and if there is a way to turn it off.
