4th axis indexing
Greetings Experts,
I have a couple machines that have indexers that are fired by an M code. I'm working with the mpmaster post. I would like the post to output the M code with the angle on it's own line.
this is what I'm currently getting
Th
G28 A0.  <---------- remove
N1 T1 M06 (7.4MM GUHRING DRILL)
(MAX - Z.25)
(MIN - Z-.4578)
<-----------------------------------  index code here
G00 G17 G90 G54 A0. X2.44 Y-1.0107 S1976 M03
G43 H1 Z.25
G94
G98 G81 Z-.4578 A0. R.1 F8.89  <-----------remove all the redundant "A" moves
X1.0107 Y-2.44 A0.
X-1.0107 A0.
X-2.44 Y-1.0107 A0.
Y1.0107 A0.
X-1.0107 Y2.44 A0.
X1.0107 A0.
X2.44 Y1.0107 A0.
G80
Off  <---------------------- Not sure why this is here?
M05
G49 G53 Z0.
M01
**What I'd like to see**
(MAX - Z.25)
(MIN - Z-.4578)
G15 B0
G00 G17 G90 G54  X2.44 Y-1.0107 S1976 M03
G43 H1 Z.25
G94
G98 G81 Z-.4578 R.1 F8.89
X1.0107 Y-2.44
X-1.0107
X-2.44 Y-1.0107
Y1.0107
X-1.0107 Y2.44
X1.0107
X2.44 Y1.0107
G80
M05
G49 G53 Z0.
M01
TIA,
Doug
It looks like the A output is being forced, that's normally not the default condition for Mpmaster.
The OFF is a coolant conflict.
We will probably need a Zip2go or at least a post file.
Thanks nickbe10, I'll whip up a mock file since this is a customer file I'm working on and cannot share
I've made some progress. I deleted irrelevant parts of the program so it isn't so long. It's not outputting a move every line anymore. I've attached a new Zip2go file of my progress
G00 G17 G20 G40 G49 G80 G90
G53 Z0.
M1
M15 A0  <-------------   I have it putting out the M code but, I'd like to move it after the tool change and have it after every tool change
so if I have to go back to this operation and it's in a different plane, it will index correctly
N1 T1 M6 (7.4MM GUHRING DRILL)
(MAX - Z.25)
(MIN - Z-.4578)
G00 G17 G54 G90 X2.44 Y-1.0107 S1976 M03
G43 H1 Z.25 M08
G94
G80 M09
M05
G49 G53 Z0.
M01
N2 T2 M6 (#25 GUHRING DRILL)
(MAX - Z.25)
(MIN - Z-.4522)
G00 G17 G54 G90 X-1.8511 Y1.8837 S3833 M03
G43 H2 Z.25 M08
G94
G98 G81 Z-.4522 R.1 F11.5
G80 M09
M05
G49 G53 Z0.
M01
                 *** not sure why it didn't out put index, it's moving to a different plane
N7 T5 M6 (3.149MM DRILL, HARVEY BVT1240-C3)
(MAX - Z.25)
(MIN - Z-.6526)
G00 G17 G55 G90 X2.0721 Y.2728 S4621 M03
G43 H5 Z.25 M08
G94
G98 G83 Z-.6526 A180 R.1 Q.375 F13.86 *** it put to A move in the drill cycle and in every cycle in this plane
G80 M09
M05
G49 G53 Z0.
M01
M15 A0
N8 T3 M6 (3/8 SPOTDRILL)
(MAX - Z.25)
(MIN - Z-.083)
G00 G17 G55 G90 X2.0721 Y.2728 S2546 M03
G43 H3 Z.25 M08
G94
G98 G82 Z-.083 A180 R.1 P.5 F5.09
G80 M09
M05
G49 G53 Z0.
M01
M15 A0
M0(USE MOLY-DEE)
N9 T6 M6 (6-32 ROLL TAP)
(MAX - Z.25)
(MIN - Z-.6)
G43 H6 Z.25 M08
G94
M29 S300
G98 G84 Z-.6 A180 R.1 F9.38
G80 M09
M05
G49 G53 Z0.
G28 Y0.
M15 A0
sleeve.MCAM-CONTENT
