How to reliably scan NCI 1051 (machine name) ?
I still don't get opinfo, even after reading the docs a thousand times.
NCI 1051 contains "Machine name" that is (almost) always same for every op. So I need to retrieve it only once. However, the following naive code works for all but not for Contour (Ramp), in which case it return with NCI 1051 not found message, even though NCI 1051 is there. Why?
In pheader$ postblock:
    while smachine_name = "" | smachine_name = "-99999",
        smachine_name = opinfo(1051, op_index, 0000)
        *smachine_name, e$
        op_index = op_index + 1
        if op_index > 10000, result = mprint("NCI 1051 not found"), exitpost$
What is the preferred to way to get NCI 1051 and return immediately?
pcomment$ is not an option. I need the information in pheader$.
On 11/16/2022 at 4:41 AM, SlaveCam said:
Still same...
It's odd that only if Contour Ramp is included, the scanning fails. Feels like a bug, anyone else?
I looked at the NCI and each operation (even contour ramp) contains a 1051 after the 999.  I've also had no trouble doing the following...
#// Postblock
op_index       : 0
operation_id   : 0
s_machine_name : ""
p_write_machine_names
    op_index = 0
    while s_machine_name <> "-99999",
        operation_id = opinfo(1, op_index)
        s_machine_name = opinfo(1051, op_index)
        *operation_id, s_machine_name, e$
#// Call
pheader$         #Call before start of file
// Sample output
operation_id 1. Mill Default
operation_id 2. Mill Default
O0000(T)
(DATE=DD-MM-YY - 19-11-22 TIME=HH:MM - 11:07)
(MCAM FILE - T)
My operations.
Can you share a bit more about what you are trying to do?
I created a test post from your example with a single addition, the first line (how do you get syntax highlighting?):
[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V23.00 P4 E1 W23.00 T1610470599 M23.00 I0 O10
op_index       : 0
operation_id   : 0
s_machine_name : ""
    op_index = 0
#// Call
Then I posted a single Contour operation and got:
operation_id 1, -99999
Maybe a switch issue? Machine or control definition issue? This is mcam 2021
