Break At Point
I decided to use BreakAtMidpoint(arc).
The problem I'm currently having with it is that it breaks the arc at the midpoint, which is wonderful, but then one of those halves gets broken again.
I'm not seeing any error in my logic though. Does breaking an Entity store the two new pieces under the same EntityID?
            void breakArcsWithPoints(){
                foreach (var i in tempList3) {
                    var ArcID = Geometry.RetrieveEntity(i);
                    if (ArcID is ArcGeometry arc){
                        var arc1X1 = arc.EndPoint1.x; // Arc x 1
                        var arc1X2 = arc.EndPoint2.x; // Arc x 2
                        var arc1Y1 = arc.EndPoint1.y; // Arc y 1
                        var arc1Y2 = arc.EndPoint2.y; // Arc y 2
                        var arc1Center = arc.Data.CenterPoint;
                        Point3D arc1StartPoint = new Point3D(arc1X1, arc1Y1, 0.0);
                        Point3D arc1EndPoint = new Point3D(arc1X2, arc1Y2, 0.0);
                        var tolerance = 0.001;
                        foreach (var v in tempList4){
                            var u = PointGeometry.RetrieveEntity(v);
                            if (u is PointGeometry point) {
                                var ux = point.Data.x;
                                var uy = point.Data.y;
                                Point3D uPoint = new Point3D(uy, ux, 0.0);
                                var delta3Xneg = (arc1Center.x - uPoint.x);
                                var delta3Yneg = (arc1Center.y - uPoint.y);
                                var delta3Radneg = Math.Atan2(delta3Xneg, delta3Yneg);
                                var pt3degreeNeg = VectorManager.RadiansToDegrees(delta3Radneg);
                                if (pt3degreeNeg < 0.0){
                                    pt3degreeNeg = (pt3degreeNeg + 360);
                                var startToUDist = Math.Abs(VectorManager.Distance(arc1StartPoint, uPoint));
                                var endToUDist = Math.Abs(VectorManager.Distance(arc1EndPoint, uPoint));
                                if ((startToUDist >= (endToUDist - tolerance)) && (startToUDist <= (endToUDist + tolerance))){
                                    GeometryManipulationManager.BreakAtMidpoint(arc);
I took 2 arcs
shifted 1 X+0.001 & Y+0.001
shifted the other X-0.001 & Y-0.001
I created points of where the two circles intersect
I then filtered to only keep the points that are actually on the arc
The goal here is to have a chain color A until it hits a point and then change to color B until it hits another point at which it turns back to color A
