Why does my list appear to be empty?
I can tell the error is before line "foreach (var t in chainEntityList){" and after "foreach (var chain in selectedChains)["
                var selectedChains = ChainManager.ChainAll(75);
                foreach (var chain in selectedChains){
                    ChainData data = new ChainData();
                    var chainEntityList = data.ChainEntities;
                        var chainKey = t.Key;
                        var chainValue = t.Value;
                        templist10.Add(chainKey.GetEntityID());
                        System.Windows.Forms.MessageBox.Show("ChainGeometry");
                        foreach (var chainEntity in templist10){
                            var entity = Geometry.RetrieveEntity(chainEntity);
- try this -
var chainDetails = new Mastercam.Database.Interop.ChainDetails();
 // The GetData method in the ChainDetails class returns a ChainData object.
 var chainData = chainDetails.GetData(chain);
 var chainEntityList = chainData.ChainEntities;
 var startPoint = chainData.StartPoint;
 var endPoint = chainData.EndPoint;
Roger,
As I understand this, 'var chainEntityList = chainData.ChainEntities' is a geometry entity and also a bool for the "flip". It is however a list.
I'm not sure how to go about using the list, or extracting those entityIDs into another list.
Is this a key/map/array situation?
                        templist10.Add(Geometry.RetrieveEntity(t));
We can see that it is a List of KeyValue pairs. ->
ChainEntities = gcnew List<KeyValuePair<Mastercam::Database::Geometry ^, bool>> ();
The Key is the geometry entity. (Not the ID of the entity.)
The Value is a flag that lets us know if this entity is marked “flipped” in the chain.
If you really want to “extract” add these entities to another List.
        templist10.Add(t.Key);
Quote
Meaning, I could call t.key[0] for example and t.key[1] would be the connecting entity?
No.
A (.NET) List is like a (C++) std::vector and is “in order”.
You do not [index] the “Key”, as it is not a list or array.
You loop through the ChainEntities  list for each item. The Key is the geometry entity, and the Value is the (bool) “am I flipped” flag for that entity.
Roger, I appreciate your patience. My studies have been in Javascript and Kotlin 😅 so it's a little bit of a culture shock.
I'd just like to confirm that it's possible for entities to be flipped in the middle of a chain.
For example, for lack of better explanation, entity1 = false, entity2 = true, entity3 = false.
Almost a complete understanding.
Shouldn't it be coloring ALL the entities in the chain? It's only changing the color for the FirstEntity. (there are 4 chains on level 75).
                var chainDetails = new Mastercam.Database.Interop.ChainDetails();// Preps the ChainDetails plugin
                var selectedChains = ChainManager.ChainAll(75);// Chains all geometry on level 75
                var chainDirection = ChainDirectionType.CounterClockwise;// Going to be used to make sure all chains go the same direction
                foreach (var chain in selectedChains)// For each of the chains selected
                    templist10.Clear();
                    chain.Direction = chainDirection;//Makes all chains go same direction
                    var chainData = chainDetails.GetData(chain);//Gets the data of the chain
                    var chainEntityList = chainData.ChainEntities;//Creates a list of entities in (geometry format) the selected chain
                    foreach (var t in chainEntityList)// For each entity in that chain
                        (t.Key).Color = 9;
                        (t.Key).Commit();
You are getting the same result? Or would you like me to send you another set of files?
Using the same logic as the templist10.add(t.key)         I also tried                         var chainEntity = Mastercam.Database.Geometry.RetrieveEntity(t.key);
It gives a 'protection level' access error though.
  • 3 weeks later...
I'm struggling to change the start entity of a chain. (closed chain).
Wanting it to be the farthest entity that is to the left (most negative X), I use the logic as follows
                    var chainStartGeo = Geometry.RetrieveEntity(chain.FirstEntityId);
                    if (chainStartGeo is ArcGeometry arcGeo){
                        var chainStartGeoEP1 = arcGeo.EndPoint1;
                        var chainStartGeoEP2 = arcGeo.EndPoint2;
                        var chainStartGeoMidpoint = new Point3D(((chainStartGeoEP1.x + chainStartGeoEP2.x) / 2),((chainStartGeoEP1.y + chainStartGeoEP2.y) / 2),0.0);
                        var chainEntity = ChainManager.GetGeometryInChain(chain);
                        foreach (var entity in chainEntity){
                            if (entity is ArcGeometry tempArc){
                                var entityGeoEP1 = tempArc.EndPoint1;
                                var entityGeoEP2 = tempArc.EndPoint2;
                                var entityGeoMidpoint = new Point3D(((entityGeoEP1.x + entityGeoEP2.x) / 2), ((entityGeoEP1.y + entityGeoEP2.y) / 2), 0.0);
                                if (chainStartGeoMidpoint.x > entityGeoMidpoint.x){
                                    chainData.FirstEntity = entity;
I am using "ChainManager.RelinkChains(ref selectedChains);" after it goes through the checks, but it's not changing.
Link :: https://github.com/UberGamz/CustomNethook
Why am I trying to do this? When I select rightToLeft, it selects the colors of the chains correctly but when I select leftToRight, it colors 3 of the 4 chains correctly.
I've narrowed it down to it being the start point of the chains inside the 'ColorCrossovers()'
Just create a new chain using the entities you want,
I asked the same question a while ago :
In the ChainInterop though,
	Mastercam::Database::Geometry ^ChainData::FirstEntity::get ()
		return m_FirstEntity;
	// Note: The setter is for internal use only!
	void ChainData::FirstEntity::set (Mastercam::Database::Geometry ^entity)
		m_FirstEntity = entity;
So I was hoping it really was that easy.
You can get the first chain_ent from an entity, then get the associated ->eptr to get a database pointer, then you can get the list of entites and remove some elements or re-arrange them , then pass that new list in order, it's not much work I suppose..
In the name of progress! Will it work? Who knows! Not clear on how the predicate works though and finding specific examples instead of a general definition.
            Chain[] chainSorter(Chain inChain, Chain[] outChain, int startId) {
                var tempListIn = new List<int>();
                var tempListOut = new List<Geometry>();
                var geo = ChainManager.GetGeometryInChain(inChain);
                foreach (var ids in geo)
                    var geoId = ids.GetEntityID();
                    tempListIn.Add(geoId);
                if (tempListIn[0] != startId)
                    Predicate<int> predicate = startId; // <- Error
                    var index = tempListIn.FindIndex(predicate);
                    var listSize = tempListIn.Count;
                    for (var i=index; i<listSize; i++){
                        tempListOut.Add(Geometry.RetrieveEntity(i));
                    for (var i = 0; i < index; i++){
                outChain = ChainManager.ChainGeometry((tempListOut.ToArray()));
                return outChain;
Just now, ___ said:
I was thinking more in the context of doing it in c++, then wrapping it in a InteropDll,
It's possible it could be done using your exisiting code, what's predicate?
Exactly my question 🤣
I guess it's a bool that needs to be defined.
Why are lists so difficult 🤦‍♂️
I'll probably have to have the result of the function be a list though. I can't get it to return a single chain, only an array of chains. 🤷‍♂️
                    bool predicate(int i){
                        if (i == startId){
                            return true;
                        return false;
