I guess I got it correct. It now returns a list of entities, in order, starting with the entity I mention.
Does it chain the list correctly? Oh absolutely not. TBC!
            List<int> chainSorter(Chain inChain, int startId) {
                var tempListIn = new List<int>();
                var tempListOut = new List<int>();
                var geo = ChainManager.GetGeometryInChain(inChain);
                foreach (var ids in geo){
                    var geoId = ids.GetEntityID();
                    tempListIn.Add(geoId);
                if (tempListIn[0] != startId){
                    bool predicate(int u){
                        if (u == startId){
                            return true;
                        return false;
                    var index = tempListIn.FindIndex(predicate);
                    var listSize = tempListIn.Count;
                    for (var i=index; i<listSize; i++){
                        tempListOut.Add(tempListIn[i]);
                    for (var i = 0; i < index; i++){
                return tempListOut;
                            var finalList = chainSorter(chain, entity.GetEntityID());
                            var geoList = new List<Geometry>();
                            foreach (var entity2 in finalList){
                                geoList.Add(Geometry.RetrieveEntity(entity2));
                            var newChains = ChainManager.ChainGeometry(geoList.ToArray());
                            foreach (var newChain in newChains){
                                var newChainGeo = ChainManager.GetGeometryInChain(newChain);
                                foreach (var testPiece in newChainGeo){
                                    testPiece.Color = 15;
                                    testPiece.Commit();
                                    DialogManager.OK("", "");
On 1/6/2023 at 8:49 PM, byte said:
It seems the function does not rely on the order of entities in the array,
Instead, wrap add_curve_to_chain, and call that for each entitiy in the chain in the order that you want
Going to be trying this today. If you remember me trying to control the direction of open chains, that's what this is all about.
Sure, they are all open chains, but they don't start that way. All the green need to go towards the inside and all the blue needs to go towards the outside. So all the greens get chained together (open chain) and all the blue get chained together (open chain). But since they start from a closed chain, I can put them in the correct order.
I believe this is the only way to achieve the desired result.
The picture I added in the previous post is how everything starts.
It's then separated like this new picture.
Going in a counter clockwise direction around the initial image, one color must be offset one direction and the other color must be offset in the opposite direction.
This is impossible to control with an open chain.
If I can control the order of entities in the chain, I will be able to control the direction of the open chain.
At least that's how things sound in my head 😅
The code I've come up with so far :: #Rookie Struggles
		static Mastercam::Database::Chain^ SelectionManager::ChainLinker (Mastercam::Database::Geometry^ GEO1){
			bool successful;
			Mastercam::Database::Chain^ returnChain; // NETHook side chain
			CHAIN* tempChain; // CLI side chain
			ent entity; // blank entity
			GetEntityByID(GEO1->GetEntityID(), entity, &successful); // Gets ent value and assigns to entity
			std::vector<ent> entities; // Blank vector list needed for CreateChain method
			entities.push_back(entity); // adds entity to vector list
			tempChain = SelectionManager::CreateChain(entities); // Sends Entity List to chain creator (in order)
			//TODO -> Convert from CHAIN* to Mastercam::Database::Chain^
			return returnChain;
		/// <summary> Construct a Chain from the supplied list of entities. </summary>
		/// <param name="entities"> The (in order!) line and/or arc entities. </param>
		/// <returns> The new chain if successful, else null. </returns>
		/// static CHAIN* SelectionManager::CreateChain(std::vector<ent>& entities){
			CHAIN* chain;
			short err = alloc_chain(&chain, FALSE /* partial*/);
			bool result = (err == 0 && chain != nullptr);
			if (result)
				CHAIN_ENT* last_chain_ent = nullptr;
				for (auto& entity : entities)
					short errCode = add_curve_to_chain(&entity, 0, TRUE, 0, chain, &last_chain_ent);
					if (errCode != CHAIN_OK) // bail out !
						result = false;
						break;
			return (result ? chain : nullptr);
I'm stumped. How to get a IntPtr from a CHAIN* ??
		static Mastercam::Database::Chain^ SelectionManager::GetNetChain(CHAIN* nativeChain)
			System::IntPtr cPtr = NETHookApiReflection::GetFieldValue(nativeChain, "Data"); //<- Error
			Chain^ chain = nullptr;
			if (cPtr != IntPtr::Zero)
				chain = NETHookApiReflection::ConstructChain(cPtr);
			return chain;
I have made some progress but I’m still stuck. I believe there are two options for what I need, and the help I need is with conversions.
Option 1:: Needs conversion from DB_LIST_ENT_PTR ** to DB_LIST_ENT_PTR
Option 2:: Needs conversion from CHAIN* to DB_LIST_ENT_PTR && Needs conversion from DB_LIST_ENT_PTR to IntPtr
            static Mastercam::Database::Chain^ SelectionManager::GetNetChain1(CHAIN* nativeChain)
                  Chain^ returnChain = nullptr;
                  DB_LIST_ENT_PTR** chainPointer;
                  ent chain;
                  ent* entity;
                  bool correct;
                  int* entNumber;
                  //dbEntityPtr ptr; <- native intPtr
                  chain_to_eptrs(nativeChain, correct, chainPointer, entNumber);
                  get_ent_from_eptr(chainPointer, entity); // <--Needs conversion from DB_LIST_ENT_PTR ** to DB_LIST_ENT_PTR
                  auto geo = Geometry::RetrieveEntity(entity[0].ent_idn);
                  auto geoArray = gcnew System::Collections::Generic::List<Geometry^>();
                  auto chainArray = ChainManager::ChainGeometry(geoArray->ToArray());
                  returnChain = chainArray[0];
                  return returnChain;
            static Mastercam::Database::Chain^ SelectionManager::GetNetChain2(CHAIN* nativeChain)
                  IntPtr point;
                  DB_LIST_ENT_PTR nativeChainPoint;
                  nativeChainPoint = nativeChain; //<--Needs conversion from CHAIN* to DB_LIST_ENT_PTR
                  point = nativeChainPoint; //<--Needs conversion from DB_LIST_ENT_PTR to IntPtr
                  returnChain = NETHookApiReflection::ConstructChain(point);
                  return returnChain;
      Chain^ NETHookApiReflection::ConstructChain (IntPtr ptr)
            if (ptr != IntPtr::Zero)
                  ConstructorInfo^ ChainConstructor = ReflectChainConstructorInfo();
                  Object^ o = ChainConstructor->Invoke (gcnew array<Object^> { ptr });
                  if (o != nullptr) // Should never be, but just in case...
                        chain = static_cast<Chain^> (o);
            return chain;
First, you have to 'unflip' all the entities or it won't matter.
                var allChains = ChainManager.ChainAll(75);
                foreach (var chain in allChains)
                    chain.Direction = ChainDirectionType.CounterClockwise;
                    var firstGeo = 0;
                    var secondGeo = 0;
                    var step = 0;
                    var tempPoint = new Point3D(0, 0, 0);
                    var tempAngle = 0.0;
                    var chainGeo = ChainManager.GetGeometryInChain(chain);
                    if (step == 0)
                        firstGeo = chainGeo[0].GetEntityID();
                        step = 1;
                    if (step == 1)
                        for (var i = 1; i < chainGeo.Length; i++)
                            secondGeo = chainGeo[i].GetEntityID();
                            var firstGeoTemp = Geometry.RetrieveEntity(firstGeo);
                            var secondGeoTemp = Geometry.RetrieveEntity(secondGeo);
                            if (firstGeoTemp is LineGeometry line1)
                                if (secondGeoTemp is LineGeometry line2)
                                    var firstEndPoint = line1.EndPoint2;
                                    var secondStartPoint = line2.EndPoint1;
                                    if (VectorManager.Distance(firstEndPoint, secondStartPoint) >= 0.001)
                                        tempPoint = line2.Data.Point1;
                                        line2.Data.Point1 = line2.Data.Point2;
                                        line2.Data.Point2 = tempPoint;
                                        line2.Commit();
                                if (secondGeoTemp is ArcGeometry arc2)
                                    var secondStartPoint = arc2.EndPoint1;
                                        tempAngle = arc2.Data.StartAngleDegrees;
                                        arc2.Data.StartAngleDegrees = arc2.Data.EndAngleDegrees;
                                        arc2.Data.EndAngleDegrees = tempAngle;
                                        arc2.Commit();
                            if (firstGeoTemp is ArcGeometry arc1)
                                    var firstEndPoint = arc1.EndPoint2;
                                        line2.Commit();
                                        arc2.Commit();
                            firstGeo = chainGeo[i].GetEntityID();
Then you can send the list(int) of entities to the CLI package
		static Mastercam::Database::Chain^ SelectionManager::ChainLinker (System::Collections::Generic::List<int>^ GeoList){
			bool successful;
			for (auto i=0;i<GeoList->Count;i++){
			GetEntityByID(GeoList[i], entity, &successful); // Gets ent value and assigns to entity
			returnChain = SelectionManager::GetNetChain(tempChain);
			return returnChain;
It used CreateChain which adds entities and creates a 'native' chain
			CHAIN* chain;
			if (result)
						result = false;
						break;
We can use GetNetChain to convert it from a 'native' chain to a NetHook chain (using ChainData Interop -- it has NETHookApiReflection)
		static Mastercam::Database::Chain^ SelectionManager::GetNetChain(CHAIN* chain)
			auto newChains = gcnew List<Chain^>();
			//** you created a chain and now use it below
			if (chain)
				for (auto currentChain = chain; currentChain != nullptr; currentChain = currentChain->next)
					IntPtr chainPointer(currentChain);
					auto o = NETHookApiReflection::ConstructChain ( chainPointer );
						newChains->Add(dynamic_cast<Chain^> (o));
			return newChains[0];
You can now control off offset direction of 'Open Chains'
18 minutes ago, byte said:
That looks good, one thing to consider when using tolerances is that you may want to handle units if the file was ever in metric, .001 would likely be too small of a tolerance...
That'd still be bigger than MTOL 🤣 but you are absolutely correct. I got lucky in this instance, I could've used rounding instead of a tolerance. Doubles are scary.
Getting an error where sometimes, any chain after the first one, goes clockwise. I'm having a rough time tracking down the root.
                inChain.Direction = ChainDirectionType.CounterClockwise;
                        if (u == startId){
                            return true;
                        return false;
                    for (var i = index; i < listSize; i++){
                    return tempListOut;
                else { return tempListIn; }
                var freshChain = ChainManager.ChainAll(75);
                foreach(var chain in freshChain){
                    var tempList400 = new List<double>();
                    var chainDetails = new Mastercam.Database.Interop.ChainDetails();// Preps the ChainDetails plugin
                    var chainDirection = ChainDirectionType.CounterClockwise;// Going to be used to make sure all chains go the same direction
                    chain.Direction = chainDirection;
                    foreach (var entity1 in chainGeo){
                        var endpoint1 = entity1.EndPoint1.x;
                        var endpoint2 = entity1.EndPoint2.x;
                        var xMedian = (endpoint1+endpoint2)/2;
                        tempList400.Add(xMedian);
                    tempList400.Sort();
                        var templist10 = new List<int>(); // temporarily holds geoID of chainEntities
                        var xMedian = (endpoint1 + endpoint2) / 2;
                        if (xMedian == tempList400[0])
                            var finalList = chainSorter(chain, entity1.GetEntityID());
I switched to                             for (var i = 0; i < geoList.Count; i++) and it's working now 🤷‍♂️
seems I only have one issue left, for now anyways 🤣 flippedGeometry
I have it inspect the chain, and then reconstruct the chain, but it isn't spitting out in the correct order. I have two start points touching each other, throwing off the entire chain.
            Chain chainFlipper(Chain inChain){
                var firstGeo = 0;
                var secondGeo = 0;
                var step = 0;
                var chainGeo = ChainManager.GetGeometryInChain(inChain);
                if (step == 0){
                    step = 1;
                if (step == 1){
                    for (var i = 1; i < chainGeo.Length; i++){
                        if (firstGeoTemp is LineGeometry line1){
                            if (secondGeoTemp is LineGeometry line2){
                                if (VectorManager.Distance(firstEndPoint, secondStartPoint) >= 0.001){
                                    line2.Commit();
                            if (secondGeoTemp is ArcGeometry arc2){
                                    arc2.Commit();
                        if (firstGeoTemp is ArcGeometry arc1){
                                    line2.Commit();
                                    arc2.Commit();
                return inChain;
If you can confine your for loops to separate functions, I think it's going to help you, all those loops running side by side get confusing
What do you mean the two start points are not touching?
You'll have to walk me through what you are doing, the code is incomplete so i don't exactly know whats going on,
If an entity is blue, offset to the left. If an entity is green, offset to the right.
Impossible to control.
But, if the endpoint of the first entity and the start point of the second entity touch, then continue the loop.
If the endpoint of the first entity and the start point of the second entity do not touch, then the entity is 'flipped' and needs to be regenerated so that the two ends switch places.
Everything was working out great, I just didn't realize I had to Retrieve after making all the changes 🤦‍♂️
Another lesson learned.
If you want to go CCW, the endpoints must be switched. It only grabs the first GEO in the CCW direction.
            Chain chainFlipperCW(Chain inChain){
                inChain.Direction = ChainDirectionType.Clockwise;
                var firstGeo = 0;
                var secondGeo = 0;
                var step = 0;
                if (step == 0){
                    step = 1;
                if (step == 1){
                                    line2.Selected = false;
                                    line2.Commit();
                                    arc2.Selected = false;
                                    arc2.Commit();
                                    line2.Selected=false;
                                    line2.Commit();
                                    arc2.Commit();
                        //Geometry.RetrieveEntity(firstGeo).Retrieve();
                var tempChainGeo = ChainManager.GetGeometryInChain(inChain);
                for (var i = 0; i < tempChainGeo.Length; i++)
                    tempChainGeo[i].Retrieve();
                return inChain;
            Chain chainFlipperCCW(Chain inChain)
                var firstGeo = 0;
                var secondGeo = 0;
                var step = 0;
                if (step == 0)
                    step = 1;
                if (step == 1)
                                var firstEndPoint = line1.EndPoint1;
                                var secondStartPoint = line2.EndPoint2;
                                    tempPoint = line2.Data.Point2;
                                    line2.Data.Point2 = line2.Data.Point1;
                                    line2.Data.Point1 = tempPoint;
                                    line2.Commit();
                                var secondStartPoint = arc2.EndPoint2;
                                    tempAngle = arc2.Data.EndAngleDegrees;
                                    arc2.Data.EndAngleDegrees = arc2.Data.StartAngleDegrees;
                                    arc2.Data.StartAngleDegrees = tempAngle;
                                    arc2.Commit();
                                var firstEndPoint = arc1.EndPoint1;
                                    line2.Commit();
                                    arc2.Commit();
                return inChain;
