Ball endmills with taper neck
Hi,
Weighing my options for some ball endmills with tapered necks.  These seem hard to find since manufacturers use different terms. I have to machine some deep free form pockets in aluminum. The pockets all have 1/8" corner rads so I am looking for tools smaller than 1/4" diameter. I am metric friendly as well but part is in inch.  I found something I like the look of from Harvey but wanted to see what else is out there. Hopefully the Harvey link works, otherwise the part # is 775312.
I also attached a sample of one of the pockets I have to machine to help get a clearer picture
SampleOfPocketGeo.mcam
Since you're stepping down the pocket walls anyway, I'd recommend a Tangent Barrel Mill, instead of just a Tapered Endmill.
Check out Moldino Gallea.
Either of these tools would be perfect:
GS4TN7.5-37.5R-TH3
GS4TN10-50R-TH3
The GS4TN10-50R-TH3, has a 50mm barrel radius, tangent to the 2mm tip radius. With this, you can increase the step-down by 5X compared to a standard ball, keeping the cutting on the barrel, until you get down to the fillet radius, and then you just use a standard stepover only in those areas. Unified 5X should fully support this Tool Type in Mastercam 2023...
GS4TN Pages from gs4tn_e.pdf
