Geometry Error
My geometry disappears after the dashed line. 🤷‍♂️
If I run all the methods before the dash line, everything is great.
If I run all the methods after the dash line, everything is great.
If I run all the methods before the dash line, save and exit, then run all the methods after the dash line, everything is great.
If I run all the methods, geometry goes missing and my file becomes corrupt.
Because it works after a reload, that would suggest there is no error in the code.
Perhaps it's a memory leak? There is no memory usage increase while running the NetHook though.
I could separate it into two different files, but I need the data stored in the first half.
            translate();
            findIntersectionOfLines();
            findIntersectionOfArcs();
            clearTempLinesAndArcs();
            breakArcsWithPoints();
            selectNewGeo();
            colorCrossovers();
            movePoints();
            seperateGeometry();
            offsetCutchain80();
            offsetCutchain81();
            shortenChains500();
            shortenChains501();
Quote
Corrupt in what way?
If you do Statistics  on the file after the run, are the missing entities included in the count?
If you remove the shortenChain### calls, does that make a difference?
If you do a rebuild graphics after the run, does that make a difference?
Since I have almost nothing to go on there, I'm reduced to guessing.
The geometry ends up on a different level.
It gets corrupt because there is no geometry on the certain level of activities. That part is completely my fault.
But the moving geometry is odd. Because it only moves if the whole thing is ran.
I've tried Graphics.clear(true) after each method as well. Also tried a sleep.
Quote
Break it down...
Create a method that does just the "move" of the geometry.
Work out that process out in isolation of all the 'other' code.
Once you know that it works and how it works, you can concentrate your efforts on the other code in your add-in.
Quote
This is "Clear Color" that clears the Group/Result markings on geometry.
Probably not going to help and maybe *not* want you want. See NOTE below.
Quote
Also tried a sleep.
No. Just no.
Is this what is happening?
I am restating basically what x4g said here. ->
"If you translate something make sure you call retrieve on the entity if you are holding a list of pointers to the entities,"
Your add-in has selected geometry, then is translates/rotates/moves that geometry using some XForm method.
After the XForm operation are you then still "looking" at the original geometry your add-in holds in a list?
Looking at the docs for:
GeometryManipulationManager.TranslateGeometry Method
GeometryManipulationManager.CopySelectedGeometryToLevel Method
Etc.
NOTE!
Any Geometry objects that get altered will NOT be reflected in that entity's data "on the NET-Hook side" if that entity's data is being held in a NET-Hook Geometry object!
You can use GetResultGeometry() to retrieve the result of the XForm operation.
That's where I keep getting lost.
At no point do I tell it anything about level 81, but the geometry on level 81 gets moved.
The geometry on level 75 gets duplicated in translate() and those duplicates are deleted in clearTempLinesAndArcs(). The geometry on level 75 is then broken in breakArcsWithPoints(). The geometry on level 75 is then colored in colorCrossovers() and then half of the geometry is moved to level 80 and the other half is moved to level 81 in seperateGeometry().
After all of this is done, there are no errors but when I run offsetCutChain80() it completes the void but the geometry on level 81 gets moved. offsetCutChain80() offsets the geometry on level 80, not on level 81.
And when I run offsetCutChain81() instead of offsetCutChain80(), the geometry on level 80 gets moved 🤦‍♂️
I believe this is the root of all my issues 😅 How do you reset/update the geometry?
                var levels = LevelsManager.GetLevelNumbersWithGeometry();
                foreach (var i in levels){
                    var geometryFound = SearchManager.GetGeometry(i);
                    foreach (var t in geometryFound){
                        t.Commit();
                        t.Retrieve();
                    GraphicsManager.Repaint(true);
I've tried running this before offsetCutChain80()
if you change something in the geometry and want to update the entity, you would change a class members value then commit, after you can dipose of the list and translate it or whatever you want, here is an example where you select the entities on a level and move them up an inch on the y axis in top plane,
if the geomtry is not present, you can throw an error then catch it and report it to the user without too much typing
try
//ask for unselection of all geometry
Mastercam.IO.SelectionManager.UnselectAllGeometry();
//repaint
Mastercam.IO.GraphicsManager.Repaint(false,true);//force rebuild
//ask for a list of geometry
var geometryFound = SearchManager.GetGeometry(100);
//handle any errors retrieving geometry and report them to the user
if(geometryFound == null || geometryFound.Length == 0)
    throw new System.Exception("Error Finding Geometry!");
else
    var views = Mastercam.IO.ViewManager.GetAllViews(false);
    if(views == null)
        throw new System.Exception("Error Finding Views!");
    else
        //set the entity as selected
        t.Selected = true;
        //commit the changes to the database
        t.Commit();
        //invalidate the list of geometry
        geometryFound = null;
        //ask to reclaim the memory from the list
        System.GC.Collect();
        //repaint the scren
        Mastercam.GeometryUtility.GeometryManipulationManager.TranslateGeometry(
        new Mastercam.Math.Point3D(0.0,0.0,0.0),//from point
        new Mastercam.Math.Point3D(0.0,1.0,0.0),//to point
        views[0],views[0],false);
        views = null;
catch(System.Exception e)
    Mastercam.IO.EventManager.LogEvent(
    Mastercam.IO.Types.MessageSeverityType.ErrorMessage,
    "Error Manager",e.Message);
These are new terms for me, and I appreciate the knowledge :D
I've tried this in different areas of the program to no avail.
https://github.com/UberGamz/CustomNethook
MCAM file included. -- if ran AS IS, geometry from level 81 gets moved to level 501.
You don't need to call Gc.Collect, the garbage collector should take care of the memory when u set it to null,
it is just a polite way to ask the garbage collector to release the memory,
I don't see that the function that youi wrote called commit() actually does anything
Here you are iterating through a list and in the first loop invalidating the list
 foreach (var geometry in selectedGeometry)
                    if (geometry.Color == 10)
                        geometry.Level = 80;
                        geometry.Selected = false;
                        geometry.Commit();
                    if (geometry.Color == 11)
                        geometry.Level = 81;
                        geometry.Commit();
                    selectedGeometry = null;//ERROR!!!!!!!!!!!!!
                    System.GC.Collect();//ERROR!!!!!!!!!!!!!
                    //repaint the scren
                    Mastercam.IO.GraphicsManager.Repaint(true);//force rebuild
This is a repaint,
This is a rebuild, you could try to use this instead, your are flipping the select bit over and over,
this can cause selection to bug rebuilding should force things to work even
I've tried that, but there's an error. "no overload for method 'repaint' takes 2 arguments"
That second overload was added in the 2023 package. 😕
I've changed this and level 81 still went missing 😅
If you ommit offSetCutChain80() and only run those first few it completes level 80 and 81. 🤷‍♂️
Below is an image of the end-result Level Manager I get.
I see 49 entities on Level #80 and 49 entities on Level #81.
So where is “geometry on level 81 gets moved” ?
Quote
After you have done an XForm operation the resulting entities are marked by Mastercam as a “result” group.
You should be able to retrieve those entities that are a “result of the last Xform” doing this.
var resultGeom = SearchManager.GetResultGeometry();
Get rid of the lines setting an array = null
e.g. The last 4 lines of the translate method -
// NOT needed
tempSelectedGeometry1Result = null
tempSelectedGeometry1 = null;
tempSelectedGeometry2Result = null;
tempSelectedGeometry2 = null;
And other locations in the code -
selectedGeometry = null; // NOT needed
System.GC.Collect(); // NOT needed
Will these cause problems? Probably not, but the are not needed and just add "noise" to the code.
Edited by Roger Martin from CNC Software
Running
            translate();
            selectNewGeo();
            colorCrossovers();
            movePoints();
            seperateGeometry();
Results in
Running
            translate();
            selectNewGeo();
            colorCrossovers();
            movePoints();
            seperateGeometry();
            offsetCutchain80();
Results in (level 81 got moved to level 501)
Running
            translate();
            selectNewGeo();
            colorCrossovers();
            movePoints();
            seperateGeometry();
            offsetCutchain81();
Results in (level 80 got moved to level 501)
This is not the result you are having Roger?
This has been what I have been doing
                            var cutResultGeometry = SearchManager.GetResultGeometry();
                            foreach (var entity in cutResultGeometry)
                                entity.Color = 11;
                                entity.Selected = true;
                                entity.Commit();
3 minutes ago, x4g said:
Can you share the ChainData project with me?
Are you referring to the ChainData API kit? I'm not sure if I'm allowed to give it out 😅 I sent SDK@Mastercam an email requesting that and the surfaces API kit.
If Roger says I can then I'll email it over to you.
I haven't gotten the surface kit yet though.
That's okay If its's a CNC Software I can email them and see if they will share it,
What do you want to do to a surface?
most of the data you can get through the surfaCE union and some simple helpers, well "simple"
Don’t know “why” at this point, but it makes a difference.
In -> offsetCutChain80()
Original:
int createdUpperLevel = 500;
int createdLowerLevel = 501;
Altered:
GraphicsManager.Repaint(false); // or remove this call
Result ->
Quote
Yes, you can share the ChainDataInterop project.
And to think, I added all that nonsense to prevent such a thing from happening 🤣 It definitely fixed it.
4 minutes ago, Roger Martin from CNC Software said:
Also...
It does not appear to make a different in the output in "this" case, but...
// Be careful doing '=' or '!=' comparisons of floating point values.
//if (chain.Area != t.Area) // No
if (Math.Abs(chain.Area - t.Area) < Mastercam.IO.SettingsManager.SystemTolerance)  // Yes, check against some tolerance
You're absolutely right, I've forgotten about that. First I tried the 'equals' method but that didn't work so I switched to calculating the area. Wanting it to offset everything except for the bounding box when selecting the 'area'.
Thankfully we've all been using the same resolution or the cursor point wouldn't have worked 🤣
I greatly appreciate the help! This has completed all my tickets I've emailed in except for the last one, asking about converting. (I think it'll just be a matter of refactor/rename/find+replace but I'm a rookie)
I've sent it to your sales email.
As for surfaces, I've asked about creating a draft surface. 98% of what this company does is offset chains (worked my way through that) and then drafting surfaces from those chains. There's an API that might be able to help since there are no Surface Creation tools in the Nethook API kit.
Are we talking about a flat surface from a chain?
That's a negative. It's angled at either 10, 15, 20, or 30 degrees at a negative depth.
This here is an example of an end result. White line is the supplied geometry. We offset the green geometry. And then draft a surface down.
53 minutes ago, JKLINE said:
I'm not against taking the first steps towards a Chook instead of a NetHook if you can introduce me 😅
Chooks are not cross platform, I would need to know what version of Mastercam and Visual Studio
There are templates for generating a working Chook for Mastercam 2023 on the Visual Studio Marketplace, you just need the appropriate development tools for c++;
There is a new Mastercam Project Template that will create a chook-InteropDll and c# project like what you are used to, this will make it easier to manage your c++ code
