Operation Linking
            //Surface Finish Contour
            var maximumStepdown = 0.01;
            var contourMinimumDepth = 0;
            var contourMaximumDepth = 0;
            //Surface Finish Pencil
            var depthLimits = true;
            var pencilMinimumDepth = 0;
            var pencilMaximumDepth = 0;
            var selectedOps = SearchManager.GetOperations(true);
            foreach (var op in selectedOps)
                op.Retrieve();
                op.Linking.
                op.Commit();
            GraphicsManager.Repaint(true);
            return MCamReturn.NoErrors;
I've started this code, but I'm not finding a LinkingParams to suit my needs.
Looking to alter the circled boxes
DepthCutsParams also didn't work.
                op.Retrieve();
                op.Linking.
                op.Commit();
There is a very short list of Nethook supported operations, contour, pocket,circle mill, drilll, slotmill, that about it
You make that sound super easy 😅 I think I'm missing a large piece. I just find the parts in the C++ files that I need and copy them to where they go? Do you have a VS Project I can reference?
Solution : ChainDataInterop
  	Namespace : Mastercam
  		Class : NETHookApiReflection
          Public Methods
          		Class : Object
  	Namespace : Mastercam.Database.Interop
      	Class : ChainData
        Class : ChainDetails
          	Public Methods
          		 Class : Object
          Public Methods
          		Class : Object
      	Class : ChainData
          	Public Methods
          		 Class : Object
Yes, make a copy of the ChainDataInterop project and rename it
Then make it make an operation, I will show you if u want
OR just build using the CLR template from the marketplace
Mastercam C++/CLI New Project Template VS 2022 - Visual Studio Marketplace
Here is an example of getting the operations..
/// <summary> Retrieves the operations found in the Toolpath Manager of the specified type. </summary>
/// <param name="opCode"> (Optional) The operation code to filter on. (TP_NULL for NO Filtering). </param>
/// <returns> The list of matching operations found. </returns>
std::vector<operation*> GetOperations(TP_OPCODE opCode = TP_OPCODE::TP_NULL)
	std::vector<operation *> ops;
	for (auto index = 0; index < TpMainOpMgr.GetMainOpList().GetSize(); ++index)
		auto op = TpMainOpMgr.GetMainOpList()[index];
		if (op && (opCode == TP_NULL || op->opcode == opCode))
			ops.push_back(op);
	return ops;
55 minutes ago, JKLINE said:
You would post this as a DLL, load it into the resources, and then call on it with opCode?
You need to export a managed function that gets you a list of operation ID's
a std::vector doesn't exist in c#
ref class OperationsManagerInterop abstract sealed
public:
static System::Collections::Generic::List<int>^ GetOperations(int opCode)
	auto list = gcnew System::Collections::Generic::List<int>();
			list->Add(op->op_idn);
	return list;
the in the c# code where you have reference the DLL
var opIDs = OperationsManagerInterop.GetOperations(15);//get only surface finish contour operations
			ops.push_back(op);
	return ops;
Referencing the ChainDataInterOP source,
this would go into the Main.CPP ?
public:
	return list;
This would be a header file?
And this would go into my NetHook file?
I'm not sure why this is so difficult for me? 😅
https://github.com/UberGamz/SurfaceToolpathInterop
No, the second block is c# code, you dont need to define the function in a header in c++/cli the managed signature is exported simply by defining the class in main.cpp or another file
The dll will need to be added to the c# project in visual studios by right clicking on dependancies and selecting add reference, then choosing the dll
It's a Christmas Miracle! Got it to select the pencil and finish contour toolpaths. Thank you so much!
Put this into my NetHook portion ::
            OperationsManager.UnSelectAllOperations();
            var surfaceFinishContourOpID = Mastercam.IO.Interop.SelectionManager.GetOperations(15);
            var surfaceFinishPencilOpID = Mastercam.IO.Interop.SelectionManager.GetOperations(39);
            foreach (var op in surfaceFinishContourOpID)
                var thisOp = SearchManager.GetOperation(op);
                thisOp.SetSelectedState(true);
            OperationsManager.RefreshOperationsManager(true);
            foreach (var op in surfaceFinishPencilOpID)
I pasted this into the SelectionMangerExample.h
		return list;
Taking this to the finish line, I've found all the codes I'll need I believe. Just need practice calling them in C++. I feel like i'm sooooo close but soooo far away 🤣😅
	static bool AlterContourFinish(int opCode)
		bool succ = false;
		 /// <summary> operation parameters - surface finish contour. </summary>
		struct prm_srf_fin_contour
			prm_srf_common common;		//!< common parameters for all surface operations
			prm_srf_depths depth;		//!< surface operation's depth settings
		/// <summary> operation parameters - surface operation's depth settings. </summary>
		struct prm_srf_depths
			double min_depth;			 //!< abs: highest cut
			double max_depth;			 //!< abs: lowest cut
		/// <summary> operation parameters - common parameters for all surface operations. </summary>
        struct prm_srf_common
		double max_stepdown;		  //!< maximum stepdown
		if (succ)
		return succ;
	static bool AlterPencilFinish(int opCode)
		bool succ = false;
		/// <summary> operation parameters - surface finish pencil. </summary>
		struct prm_srf_fin_pencil
			prm_srf_limits limit;		//!< surface operation's limit settings
		/// <summary> operation parameters - surface operation's limit settings. </summary>
		struct prm_srf_limits
			bool on;				 //!< T-use cut depth limits
			double z1;				 //!< depth limit 1
			double z2;				 //!< depth limit 2
		if (succ)
			return succ;
Even closer! One problem though 😕 C++ has 'rules' 🤣
"C++ a nonstatic member reference must be relative to a specific object"
	static bool AlterContourFinish(long opID, double maxStepdown, double minDepth, double maxDepth)
		//Get
		auto thisOp = TpOpList::OpByID(opID);
		//Set
		thisOp.prm_srf_common::max_stepdown = maxStepdown;
		thisOp.prm_srf_depths::min_depth = minDepth;
		thisOp.prm_srf_depths::max_depth = maxDepth;
		return ;
	static bool AlterPencilFinish(long opID, bool status, double limitOne, double limitTwo)
		//Get
		//Set
		thisOp.prm_srf_limits::on = status;
		thisOp.prm_srf_limits::z1 = limitOne;
		thisOp.prm_srf_limits::z2 = limitTwo;
		return ;
And I'm officially stuck 😅 The first portion works in Mastercam, but the second portion throws an alarm.
"Method not found: 'Boolean Mastercam.IO.Interop.SelectionManager.AlterContourFinish(Int32, Double, Double, Double)'."
Maybe I put something in the wrong place? Or am calling it incorrectly?
		return list;
	static bool SelectionManager::AlterContourFinish(long opID, double maxStepdown, double minDepth, double maxDepth)
		//Get
		prm_srf_common opCommon;
		prm_srf_depths opDepth;
		tp_entity thisToolPath;
		thisToolPath.op_idn = opID;
		//Set
		opCommon.prm_srf_common::max_stepdown = maxStepdown;
		opDepth.prm_srf_depths::min_depth = minDepth;
		opDepth.prm_srf_depths::max_depth = maxDepth;
		return true;
	static bool SelectionManager::AlterPencilFinish(long opID, bool status, double limitOne, double limitTwo)
		//Get
		prm_srf_limits opData;
		//Set
		opData.prm_srf_limits::on = status;
		opData.prm_srf_limits::z1 = limitOne;
		opData.prm_srf_limits::z2 = limitTwo;
		return true;
                Mastercam.IO.Interop.SelectionManager.AlterContourFinish(op, 0.2, -0.2, -0.2);
https://github.com/UberGamz/SurfaceInterop (CLI)
https://github.com/UberGamz/Rotary-PD---Copy (Nethook)
3 hours ago, ___ said:
Is the function marked as public?
It won't let me mark it 'public' because it says ": expected". Your portion also doesn't say public, is there another way to mark it so?
Everything is inside the public class "public ref class SelectionManager"
Second question, was the dll copied over correctly?
My code is directly under yours, inside the same file. Since yours works, I'd assume the dll was copied correctly.
You want to edit the operation union, then use the operation_manager () function with the OPMGR_REWRITE flag
if (op && ( op->opcode == TP_SRF_FIN_CONTOUR
bool success = false;
DB_LIST_ENT_PTR operationPointer = nullptr;
//set cut method to zig zag
op->u.f_contour.cut_method = (short)0;
operation_manager(op, OPMGR_REWRITE, &operationPointer, &success);
if (success == false)
//TO DO : Handle any errors rewriting the operation
1 hour ago, ___ said:
You will need to include the header file and library
In your header file or at the top of your source code add these lines
#include "m_mill.h"
#pragma comment(lib,"MCMill.lib")
Brilliant! :D  Thank you soooo much!
Solution ::
CLI ::
		static bool SelectionManager::AlterContourFinish(double maxStepdown, double minDepth, double maxDepth)
				if (op && (op->opcode == TP_SRF_FIN_CONTOUR
					) && op->db.select_flag == true)
					op->u.r_contour.common.max_stepdown = maxStepdown;
					op->u.f_contour.depth.max_depth = maxDepth;
					op->u.f_contour.depth.min_depth = minDepth;
			return true;
		static bool SelectionManager::AlterPencilFinish(bool status, double limitOne, double limitTwo)
				if (op && (op->opcode == TP_SRF_FIN_PENCIL
					op->u.f_pencil.limit.on = status;
					op->u.f_pencil.limit.z1 = limitOne;
					op->u.f_pencil.limit.z2 = limitTwo;
			return true;
NetHook ::
            var contourList = new List<int>();
            var pencilList = new List<int>();
                foreach (var thisOp in selectedOps)
                    var selectedOp = thisOp.GetOperationID();
                    if (selectedOp == op)
                        contourList.Add(selectedOp);
                        pencilList.Add(selectedOp);
            foreach (var op in contourList)
                Mastercam.IO.Interop.SelectionManager.AlterContourFinish(0.2, -0.2, -0.2);
                thisOp.MarkDirty();
                thisOp.Commit(false);
            foreach (var op in pencilList)
                Mastercam.IO.Interop.SelectionManager.AlterPencilFinish(true, -0.020, 0.00);
                thisOp.MarkDirty();
