N BLOCK
Hello all ,I need fix some thing in my post
I can get N block  an T number in same line ,haw I can fix this ??
sample my program
(COMPENSATION TYPE - COMPUTER)
N1 T1
M06 (1/2 FLAT ENDMILL)
(MAX - Z7.2211)
(MIN - Z.91)
G57 H901
G00 G17 G90 B90. X-.2857 Y-.1003
my post
# Tool Comment / Manual Entry Section
ptoolcomment    #Comment for tool
      tnote = t$
      toffnote = tloffno$
      tlngnote = tlngno$
      tldianote = tldia$
      spaces$ = 0
      scomm_str, pstrtool, " ", *tnote, " ", *toffnote, " ", *tlngnote, " ", *tldianote, scomm_end, e$
      spaces$ = sav_spc
pstrtool        #Comment for tool
      if strtool$ <> sblank,
        strtool$ = ucase(strtool$)
        *strtool$, " "
thank you for any help
sample my program
N1 T1
(MAX - Z7.2211)
(MIN - Z.91)
G57 H901
my post
      tnote = t$
      toffnote = tloffno$
      tlngnote = tlngno$
      tldianote = tldia$
      spaces$ = 0
      spaces$ = sav_spc
        *strtool$, " "
MPMASTER has this built into it.
tseqno      : 0     #Output sequence number at toolchanges when omitseq = yes
                    #0=off, 1=seq numbers match toolchange number, 2=seq numbers match tool number
Follow the logic used in that post.
ptlchg_com
section removed
      if stagetool >= zero,
        if omitseq$ = 1 & tseqno > 0,
          if tseqno = 2, n$ = t$
          pbld, *n$, *t$, "M06", ptoolcomm, e$
        else, pbld, n$, *t$, "M06", ptoolcomm, e$
pheader$
section removed
      if tseqno = 1 & omitseq$ = 1,
        seqno$ = 1
        seqinc$ = 1
        n$ = seqno$
ptlchg_com
section removed
pheader$
section removed
        seqno$ = 1
        seqinc$ = 1
        n$ = seqno$
 I am missing something  ,this is my post
          pbld, *n$, *t$, e$
          pbld, n$, "M06", ptoolcomm, e$
        else,
          pbld, n$, *t$, e$
      spaces$=0
      if output_z = yes$,
          pbld, *n$, *t$, e$
        else,
          pbld, n$, *t$, e$
      spaces$=0
      if output_z = yes$,
Not in that section of the post. Download MPMASTER and use it to reverse engineer what is missing in your post. I am a teacher of the idea if I do al the work for you then you will not learn how to figure it our for yourself.
6 minutes ago, crazy^millman said:
What did the base post start life from? Need to know to see what the Tool Change Logic looks like.
[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V25.00 P0 E1 W25.00 T1663592119 M25.00 I0 O0
# Post Name           : MPM TOSHIBA HMC.PST
# Product             : MILL
# Machine Name        : TOSHIBA BTD/BTH/HM/HBM SERIES
# Control Name        : TOSNUC 777/888/999
# Description         : TOSHIBA 4 AXIS VMC
# 4-axis/Axis subs.   : YES
# 5-axis              : NO
# Subprograms         : YES
# Executable          : MP v11.0
# Post Revision       : 11.2.07337 (MC_FULL.MC_MINOR.YYDDD)
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Start of File and Toolchange Setup
psof0$           #Start of file for tool zero
      psof$
psof$            #Start of file for non-zero tool number
      probe_head$
      ptravel
      pwritbuf5
      pcuttype
      toolchng = one
      if ntools$ = one,
        #skip single tool outputs, stagetool must be on
        #stagetool = m_one
        !next_tool$
      tooltotal = rbuf(4,0)  #Reads total tool and null tool changes
      if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)
      else, nexttool = first_tool$
      if tool_table = 2, ppredstck
      if tool_table = 3, pmetastck
      spaces$=0
      if output_z = yes$ & tcnt > 1,
        scomm_str, "OVERALL MAX - ", *z_tmax, scomm_end, e$
        scomm_str, "OVERALL MIN - ", *z_tmin, scomm_end, e$
      spaces$=sav_spc
      if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
      pbld, n$, *sgcode, *sgplane, "G40", "G80", *sgabsinc, e$
      pbld, n$, "G53", e$
      inhibit_probe$
      sav_absinc = absinc$
      absinc$ = one
      if wcstype <= one, #Work coordinate system
        pfbld, n$, sgabsinc, *sg28, "Z0.", e$
        pfbld, n$, *sg28, "X0.", "Y0.", e$
        pfbld, n$, "G92", *xh$, *yh$, *zh$, e$
      else,
        pbld, n$, sgabsinc, *sg28, "Z0.", e$
      absinc$ = sav_absinc
      sav_mi9 = mi9$
      sav_workofs = workofs$
      if sav_workofs < 0, sav_workofs = 0
      ptlchg_com
      sof = 0
ptlchg_com      #Tool change common blocks
      if force_output | sof,
        result = force(ipr_type,ipr_type)
        result = force(absinc$,absinc$)
        result = force(plane$,plane$)
      pcom_moveb
      pcheckaxis      #Check for valid rotary axis
      if sof, uninhibit_probe$
      #ptoolcomment
      if sof & scomm_sav <> snull,
        spaces$ = 0
        n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
        spaces$ = sav_spc
      if sof = 0, scomm_sav = snull
      if mi3$,
        result = nwadrs(strw,zabs)
        result = nwadrs(strw,zinc)
        result = nwadrs(strz,mi1$)
      else,
        result = nwadrs(strz,zabs)
        result = nwadrs(strz,zinc)
        result = nwadrs(strw,mi1$)
      comment$
      pcomment3
      pmisccheck
      pcan
          pbld, *n$, e$
          pbld, *t$, e$
        else,
          pbld, n$,
          pbld, *t$, e$
      spaces$=0
      if output_z = yes$,
        preadbuf5
        if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
          n$, pspc, scomm_str, "MAX - ", *max_depth, scomm_end, e$
          n$, pspc, scomm_str, "MIN - ", *min_depth, scomm_end, e$
That looks like it started like as a MPMASTER based post.
Look for this section in the ptlchng_com
      if safe_index,
        if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
        pbld, n$, pgear, e$
        pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], pfcout, strcantext, e$
        if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
        if convert_rpd$ = one,
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
        pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, pfspindleout, [if gcode$ = 1, *feed], e$
      else,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
        pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
          pfspindleout, [if gcode$ = 1, *feed], strcantext, e$
If that is identical then easy change. If not then you need to look for the section that has pfcout, ppfxout, pfyout on the same line. This is the line combining them all for output together. In the MPMASTER original post that is this line:
I always try to copy any original line or lines in a postr and comment them out. Then make modification to the copied lines to see what works. I ever need to go back to the original stuff then easy as uncommenting the original lines and commenting out the copied lines. FYI # is what we call a comment line in MP post. Anything seen after the # sign is ignored and considered comments.
#        pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
#          pfspindleout, [if gcode$ = 1, *feed], strcantext, e$
        pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed], pfcout, dfspindleout, [if gcode$ = 1, *feed], strcantext, e$ #changed to break out X and Y on a seperate line RDB 12-28-22
        pcan1, pbld, n$, *sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, [if gcode$ = 1, *feed], e$ #changed to break out X and Y on a seperate line RDB 12-28-22
Here is how I would break it out and test. I would see what it does and then modify as needed for the output I am getting. I always try to add my initials to any post mod. That way anyone else can know I did it and I also try to give a brief reason for the post mod.
      if safe_index,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
      else,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
if safe_index,
        pbld, n$, pgear, e$
        pcan1, pbld, n$, *sgcode, sgplane, sgabsinc, pfcout, strcantext, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
        pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, [if gcode$ = 1, *feed], e$
        #pbld, n$, pfspindleout, e$
      else,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
        pcan1, pbld, n$, *sgcode, sgplane, sgabsinc, [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
It looks identical now up to you to take what I have showed you and apply it to that section of the post. You also notice I used the code section for putting up this information. By using that is keeps the spacing format correct when posting it on the forum. It was missed by nerds like me that want to see proper spacing for computer language information.
      if safe_index,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
      else,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
if safe_index,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
      else,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
NEW
      #  pcan1, pbld, n$, *sgcode, sgplane, sgabsinc, [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
T1
(MAX - Z7.2211)
(MIN - Z.91)
G57 H901
B90.
G17 G90 Z1.4211
X-.2857 Y-.1003
G94 G01 Z1.1928 F150.
NEW
I am not sure ,the G173  W  value missing
Just now, crazy^millman said:
No you didn't do both lines. That is 2 lines when you put a # on the first line it needs to now be on both since the post is not seeing the first complete line. Does the post give you an error?
yes
