Compare Solid faces for parallelism
Corey Hampshire
Is there a way to click on two solid faces and see if they are parallel to one another? My parts have multiple faces at all different angles and it would be nice to know if they are at the same angle. For instance I create a plane off one face for milling, is the other face in the same plane, or do I need to create a new plane for that face as well?
Thanks in advance.
Thanks in advance.
Create the 1st angled Plane, then make sure it is active. (Can just use "=" button to set WCS, T/Plane, and C/Plane).
Run the 'Curvature' Command, in the drop-down menu, under 'Check Solid'. Give it a 0.0001 Tolerance, and run the function. Pick the color for all "Flat Faces". You should instantly see what faces are "flat" to that current active Plane.
Byte Automation for Mastercam has a Function Mark All C-Plane Surfs that colors all the faces in the active C-Plane,
You can download the Demo Version from https:\\theebyte.com
If it works for you, I can send you an installer just for that component on the house, if you want.
We also have a function that creates a plane from a flat face, which verisurf has too
  • Like 4
Remember that with a solid face, you can use Right Click > Quick C-Plane to create a temporary plane to work on.  If you can't create a quick C-Plane on a solid face, then you know that it's not flat as well, so it kills two birds with one stone :)
Thanks in advance.
another option would be to set a plane or quick plane off one face, then run analyze draft angle, this will report all horizontal surfaces as a specific color, i think this would work better than analyze curvature would parallelism. just click the little blue rewind looking button when you launch analyze draft angle and it will process the solid with the given tolerance.
curvature only reports flat surfaces, so it can prove something flat but not parallel, where analyzed draft angle can be set to a specific plane and can actually give you what is horizontal based on a specific plane
