Dmu 50 post configuration
Hello
I am working on dmu 50 post
here is the post setup:
#Assign axis address
str_pri_axis : "B"
str_sec_axis : "C"
str_dum_axis : "A"
#Toolplane mapped to top angle position strings
str_n_a_axis : "A"
str_n_b_axis : "B"
str_n_c_axis : "C"
mtype        : 3
head_is_sec  : 0
rotaxis1$ = vecz   #Zero
rotdir1$  = vecx  #Direction
rotaxis2$ = vecx  #Zero
rotdir2$  = vecy  #Direction
p_nut_restore
      result = updgbl(rotaxis1$, "vecz") #Zero
      result = updgbl(rotdir1$,  "vecx") #Direction
      result = updgbl(rotaxis2$, "vecx") #Zero
      result = updgbl(rotdir2$, "vecy")  #Direction
saxisx       : 0     #The axis offset direction?
saxisy       : 0     #The axis offset direction?
saxisz       : 155 #The axis offset direction?
r_intersect  : 0     #Rotary axis intersect on their center of rotations
n_saxisx     : 0     #The axis offset direction?
n_saxisy     : 0     #The axis offset direction?  178.763
n_saxisz     : 0     #The axis offset direction?
n_r_intrsct  : 0     #Rotary axis intersection with nutating (normally zero) 0
frc_cinit    : 1
top_type     : 2
shift_90_s   : 1
vmc          : 1
rot_on_x     : 3   #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos  : 0
rot_type     : 1
adj2sec      : 1
 auto_set_lim : 1
pri_limtyp$  : 0
sec_limtyp$  : 0
pri_limlo$   : 0
pri_limhi$   : 360
#Set intermediate angle, in limits, for post to reposition machine
pri_intlo$   : -5
pri_inthi$   : 365
#Set the absolute angles for axis travel on secondary
sec_limlo$   : -75
sec_limhi$   : 75
sec_intlo$   : -80
sec_inthi$   : 80
bias_null    :     0
use_tool_plane_as_bias : no$
#Machine base matrix (Base matrix to map positions into)
matb1$       : 1
matb2$       : 0
matb3$       : 0
matb4$       : 0
matb5$       : 1 # 1
matb6$       : 0
matb7$       : 0
matb8$       : 0.707107
matb9$       : -0.707107
I get tis error when generating G-codes  "ERROR-SETUP FOR PRIMARY OR SECONDARY AXIS IS ILLEGAL"
