Which 5 axis toolpath is best for this, any tips are greatly appreciated and if I can produce a good toolpath, ill get u some brews
When your stating the best that still doesn't give us the details you need for the finish.
Are you simply looking for a controlled scallop height or do you want the scallops to be in the same flow pattern as the wire groove?
I've done these in the past with 3 axis machines. Are you looking to use 5 axis simply for getting the tool off the tip for better finish and due to tool size needed?
Not trying to be picky or anal, just looking to give you the right feedback to help you get the best finish you need 😃
Yes and thank u. The width and Height for the groove are different for every set, only one remains the same. The width and Height are +/- .002 inches and the bottom radius max .018. I can select geometry and avoidance just fine, I usually use flowline with a .001 stepover which they dont call out a particular finish but any lines in the groove get transferred onto the Stent and if you've done medical parts thats unacceptable,. These go into a salt pot later to form Memery metal
If you set the program planes to how you have it modelled, it shouldn't do any full rotations.  It will adjust the angle of the B/C simultaneously.
Should more or less be able to just create a new work plane based off your actual "Top" Plane but then orient the Z Axis to be pointing at the flat surface.  Then use the "Top" as WCS and the new plane as your T-plane.  T-plane is what sets your tool orientation.
I would imagine that any modernish Haas 5-axis would have infinite C-axis anyways. So, even if you ran it how I have it oriented, you should be just fine.
12 hours ago, SIMPLEEDABESST said:
OK I wanna thank u and buy u some coffee or beer so pm WITH YOUR CASHAPP HANDLE
Lol, all good dude! I don't have cashapp.  We are all happy to help here and I like to use these as little mini exercises for myself to stay fresh.  Not often that I actually get to program full 5 axis
