I need a good way to hold this
45 minutes ago, jstell said:
V-block cradle?  Or a wide slot with 'fence' walls to locate and keep it from rolling?
Strap clamps over the top with long bolts or studs to the pallet?
when i did it in the 3 axis machine i made a cradle with the radius and used a 2 piece bolt down vise. but i wont have much clearance in this machine for that. we were hoping to increase the cutting aggressiveness.
 i can use some long studs and straps to reach the side. I'm putting a dovetail on it
that Titians guy had a big chuck in a makino video he dis. i think it was 3 individual jaws
Jeez, that's quite the chunk!
I could see dovetails on each end, held with maybe a vise like this one:
https://schunk.com/us/en/workpiece-clamping-technology/manual-clamping-systems/single-acting-clamping-vises/ksc-f/ksc-f-160-480/p/000000000000432620
480mm long Schunk Kontec w/ dovetail jaws.
But honestly most of my parts are much smaller so I am definitely no expert.
1 hour ago, Aaron Eberhard said:
Pitbulls were going to be my suggestion.  This is just for the dovetail op?
Any idea what kind of cutting force you're going to be putting against? i.e., how much clamping force you need to hold?
Yeah it's just to put the dovetail on. I have to probably rough two inches off. In the feeler I use the iscar  h400. But I also had that chain turn on the bottom and bolted the table so it couldn't fall out of that saddle..
 let it run overnight so I wasn't pushing it.
According to HSMAdvisor, if you use a 5FL .75" and keep the DOC to 1" 12.3% (.0921") WOC, it'll generate ~735lb of cutting force.
The two bigger sized pit bulls claim to have 6 or 12000lb of holding force.   I'd make some stand-offs to mount those at the end and dig into the middle of the ends.
Make a fixed side wedge and a clamp-driven wedge to lock the bottom in place after clamping with the miteebites, just to ensure it can't rock or get pushed since you're not holding it on the front/back?
Make a fixed side wedge and a clamp-driven wedge to lock the bottom in place after clamping with the miteebites, just to ensure it can't rock or get pushed left or right (since you're not holding it on the front/back)?
Thanks, I'll check it out tomorrow
  • 3 weeks later...
7 hours ago, Aaron Eberhard said:
@Leon82 - Someone just replied to my post, so I'm wondering how you ever made out here?
I haven't done much yet. I modeled a fixture with some of the big pit bulls. Probably going to get on it more next month
4 hours ago, Leon82 said:
I'm thinking something like this might work.
I would put 3 on each side not 2, built I like building massive overkill fixtures. Funny some of the fixtures from 30 years ago are still be used at the company I worked for back in Florida. Seen fixtures from 20 years ago still be used at another company last year. I would also radius or chamfer the corners to keep any extra material inside the swing and not have sharp concerns create pinch points for loading and unloading the material.
ok ill add them, they arent very expensive so its worth it. i will be cutting the corner off this is just a starting sketch
I was going to say 4 per side! Mitee-bites are nice, but not sure they provide the clamping forces to resist aggressive machining on such a large chunk of Ti.
My 2 Cents:
https://www.fixtureworks.com/store/pc/side-clamps-wide-jaw-cp102-s37.htm
https://www.fixtureworks.com/store/pc/side-clamps-pivoting-serrated-jaw-heavy-cast-iron-bj100-s2862.htm
My 2 Cents:
Those are snazzy, multi-mitee-bites :)
