Inch or Metric
Frank
Hey all: I am confronted with giving the boss an answer on why I program in Inch, when the prints come in Metric. His thoughts are if it comes in Inch, program it that way, if it comes in Metric, do the same. I know it's just a code in the machine to change to Metric...but can someone tell me what problems can occur by doing this ? I've always converted. Beside already having over 2000 tools in my library, is there something else I'm overlooking.
Good Day Frank,
I dont think you want to mix metric programming
and inch. First of all do you have metric endmills and/or metric tool holders.
The easyest way is to draw all dimensions as shown (keeping in mind that mastercam is based
on units.) then inspect the drawing to the metric
drawing. then Xform - scale - to english.
note:
Some machines need parameter change to switch to
metric. (Not just a G-code)
Tony G
CNCiT Precision Machine - Hudson,NH
X Beta Site
Almost Employed Senior Programmer
N.E Massachusetts - Southern New Hampshire
_________________________________________
End mills and tooling are like The "AMMO"
And coolant and chips are like the enemy
Under your boots as you advance in the
Manufacturing Battle
Not when my words mean nothing! I asked what benifit does he feel he would be getting by me programming in Metric, and his reply was "because I want you to" then he proceeded to tell me he's going to check with his machine shop owner friends, and I have 2 hours to come up with a solid reason why not. So sorry for wasting your time....sounds like he's already made up his mind. I've also been told I get paid by the hour do as I'm told.
Good Day,
Frank...our time is never wasted here.
I LEARN something new here every day.
Typical owner, everything is a five minute job.
Maybe if you get enough knowledge from these
good people on this forum...you can look for
another boss with more realistic outlook.
Best of luck
Tony G
X Beta Site
This guy sounds like a real A$$HOLE! Find new job FAST. If he's not willing to respect your opinions and ideas on how YOU would like to program, then your chances of sucsess are slim.
Just my 2 cents.
As far a Inch or Metric , I use inch because our tool library and collets are inch. And it's easier to find cutters..at least around here. Check with your local tool suppliers and see what they stock more of, Inch or Metric. That would be a good argument. Having to wait a couple extra days to get a cutter in to run a job would be costly to any shop.
Good Luck !!
I use inch because I live in the USA!!!!
If that's not a good enough reason tell him to shove it!
I program in inch because that's what I was brought up learning.
All our operators/programmers use inch also.
My owner/boss has asked me a couple times thru the yrs "wouldn't it be easier if you have a metric print to program in metric?"
I said,maybe,but it would get confusing to the operators switching back and forth learning new feedrates and stuff like that.
Also,unless you buy metric inspecting equipment ,you would have to convert the numbers anyway to check the damn thing!
Although telling the boss to "shove it" ranks right up there with me an Halle Berry spending the night together. I realize right now they are both only fantasies ! So with 2 small kids and a wife, I'll have to program in Metric. After all I do get paid by the hour. And so are the operator's who will scream and bitch, after they get the programs.
Frank,
It's too bad he doesn't see the agrovation this is going to cause.
Here's my thoughts,
Tell him WHY, You don't think it's a good idea but also tell him that whatever his decision is, you'll stand behind it.
Then, make notes as to how the conversation went, what was said and so-on.
Then, carry on as best you can.
If things go hay-wire in the shop, then you'll have to see how things go and who blames who.
At least you'll have the notes from your meeting.
Hang in there.
Good Day,
Quote:
________________________________________________
It doesn't seem real that he would say do it, just because.
I have many bosses who would do the wrong thing
just to be right.(not)
Frank,
just do the work and it will be new knowledge
for you...I have spent many hours learning (practicing) on production time, and using
double-triple the time, so I would benefit
and the next time program faster, and maybe
this is the only way to give your boss what
he wants...and you will become more proficiant.
Tony G
X Beta Site
My point is: IN order to prevent mistakes, it makes sense to kepp things in a unit for that people are used to dealing with. Some shops can do both Inch and Metric. But if your not used to dealing in metric, you can expect a cretian amount of mistakes to be made during the transition.
If he's prepared for that I would say fine, program in metric.
Mike Mattera
Hello, The big decision is in your tooling,tool holders, and inspection tools. Programming in metric does not make sense unless you use metric tooling and measuring equipment. You can use inch tooling and measuring equipment but a conversion is still being used. When I run into an ignorant boss, I like to base my argument on dollars and cents. Let him know the cost to tool up and train the machinists for all metric processing. I don't want to add fuel to your bosses argument (even though it sounds like he doesn't have one) but some machines/controllers have a better resolution in metric mode and will hold tighter tolerances. Even knowing this, we use inches since all of our tooling, inspection, and training is based on inches.
