Custom Drill Cycle? Post Help
Paul McGarr
Hi,
I don't know if I need a custom drill cycle or what, but here's what I need...
I need to basically drill 24 holes in a part. At the bottom of the hole I need to have two (custom) lines of code in my program before the drill retracts from the hole. The two lines of code are predetermined and always the same so I can cram those into the post somewhere without much trouble.
Right now I program the holes with a peck cycle and post the program with canned cycles off in the post so I get long hand code. I then edit the program and paste the two lines of code in 24 places. This is no big deal, but everytime (several times a day) the hole pattern changes, it's another edit.
What would you guys do to make this easier? I'm running Mastercam 9 with MPMaster for 9.
Paul McGarr
Well if it is all you use that particular drill cycle for, I would editing the post drill cycle would be OK. But if you use it for other things as well a Custom cycle is probably the way to.
What do you need you cycle to look like?
What post are you using?
Agree custome drill cycle all the way. Here is one I did for a back spot facing.
pdrlcst		 #Custom drill cycles 8 - 19 (user option)
  #Use this postblock to customize drilling cycles 8 - 19
  pdrlcommonb
  #if drillcyc = 8, pcan1, pbld, n, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout,
  #  prdrlout, dwell, *feed, strcantext, e
  if drillcyc = 8,
	sub_prg_call = peck1
	pcan1, pbld, n, *sg00, *sgabsinc, pfxout, pfyout, strcantext, e
	pbld, n, "M98", *sub_prg_call, e
  if drillcyc = 9,
	 pdrlcommonb
	 pcan1, pbld, n, pdrlxy, pfzout, pcout, *feed, strcantext, e
	 "M00", e
	 *drl_prm1, *drl_prm2, e
	 "G1", *drl_prm3 , *drl_prm4, e
	 *drl_prm5, e
	 "M00" , e
	 *drl_prm6, e
	 pcom_movea
  else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e
  pcom_movea
pdrlcst_2	   #Custom drill cycles 8 - 19, additional points (user option)
  pdrlcommonb
  #if drillcyc = 8, pcan1, pbld, n, pdrlxy, pzout, pcout, prdrlout, dwell,
  #  feed, strcantext, e
  if drillcyc = 8,
  if drillcyc = 9,
	 pdrlcommonb
	 pcan1, pbld, n, pdrlxy, pcout, *feed, strcantext, e
	 pbld, n, pfzout, e
	 "M00", e
	 "G1", *drl_prm3, *drl_prm4, e
	 *drl_prm5, e
	 "M00" , e
	 *drl_prm6, e
	 pcom_movea
  pcom_movea
Then here is where they were defined:
fmt  Q  2   peck1	  #First peck increment (positive)
fmt	 2   peck2	  #Second or last peck (positive)
fmt	 2   peckclr	#Safety distance
fmt	 2   retr	   #Retract height
fmt  Q  2   shftdrl	#Fine bore tool shift
fmt  Z  2   zdrl	   #Depth of drill point
fmt  Z  2   tosz	   #Drilling top of stock
fmt  N  4   n_tap_thds #Number of threads per inch (tpi) / Pitch (mm)
fmt  F  2   pitch	   #Tap pitch (inches per thread)
fmt  R  2   refht_a	 #Reference height
fmt  R  2   refht_i	 #Reference height
fmt  S  4   drl_prm1	#Back Spot Facing Spinlde Speed
fmt  M  5   drl_prm2	#Back Spot Facing Spindle Direction
fmt  Z  2   drl_prm3	#Back Spot Facing Intinal Z depth to start Clearence postion
fmt  F  15  drl_prm4	#Back Spot Facing Feedrate
fmt  Z  2   drl_prm5	#Back Spot Facing Depth
fmt  Z  2   drl_prm6	#Back Spot Facing Retract Z place for moves between places
Post is MPMaster for version 9
Code needs to be like this (very simple)
G0 X0. Y0.
G0 Z0.05
G1 Z-1. F20.
M91 OUT1 ;THIS IS CUSTOM LINE ONE
M90 OUT1 ;THIS IS CUSTOM LINE TWO
G0 Z0.05
This example would be without pecking just for clarity, and is obviously one hole only.
I'll take a look at doing a custom cycle tomorrow if everybody thinks that's the way to go.
Ron, is your example from a MPMaster post? Something pretty close anyway? I'm not a post wizard, but I can usually get most stuff done with a little time. I'll take a look.
Paul
  • 17 years later...
