G10 Programming Post
The Fastmill
Is it possable to have a post for G10 programming?
This is the first place I've worked where they use G10 programming for all of there NC files. The other programmer here (including me for now) are just hand editing everything. There is a sub for everything and it was very confusing... I'm sure there is sombody else out there that is doing this type of programming. The programs are for Mazak horozontals of varieing sizes. Here is an example of the code I'm trying to reproduce...
N2502P5M98
G0G90G54G80G40B90.
X-blah Y-blah S-blah M3
G43Z0.M8
T40
G98G85Z-1.0R-.250F10.L0
P2125M98 (POINT SUB)
P200M98 (SHIFT SUB)
P201M98 (SHIFT SUB)
P2225M98 (POINT SUB)
P202M98 (SHIFT SUB)
G80G40M09
G91G30Y0Z0M5
G28X0
M01
M06
Any ideas or advise is welcome... I'm getting tired of hand editing...
V9.1 SP2 Waiting on Key for X!!!
We use the G10's in the subs for setting the fixture offsets... The operator just sweeps one point on the fixture and sets the XYZ values in the correct sub (in the example above it's P5). Then the program jumps around to different parts of the tombstone and cuts the parts... using shifts...
"sounds more like you need to get involved with nesting routines/patterns for MC."
Thank you... I will look at that... Not sure if it will help though...
No, it won't. I sort of get what you're doing. I'd like to see what the sub looks like and the code it uses though.
Not sure if I'm understanding you here though. You're sweeping a position on a stone or fixure then having to handtype that as a G10 offset in each sub? headscratch.gif
If I'm thinking right, (it is late for me), why not just use multiple work offsets? If you're sweeping each spot anyway..... confused.gif
I use g10's on some older mills that only have g54-g59. It's a very safe way to program multiple parts and have multiple setups on one of these old clunkers. I swear that we used to get one crash a week during shift changeover. I am currently doing a 9 part program so you can imagine what the program looks like. The centerline tolerances are such that simply transforming toolpaths is not accurate enough in the real world. Peter
I think... headscratch.gif he's using them to create an infinite number of work offsets (on a machine that doen't support enough offsets).
His G10 is setting a location to run a pos. then a second G10 would efectively change to another "fixture" offset.
If I remeber right there was another post talking about this a few weeks ago.
edit: here it is.
At least that's what I think hes doin.
3rd String, That's exactly what I'm doing.... Just didn't know how to discribe it... Thank You...
The Subs looks like this...
O00000005
(OFFSET SUB)
(THIS WRITES TO THE G54 OFFSET)
G90
G10P1L2X-20.6746 Y-20.7216 Z-28.7663
G90G54
M99
O00002125
(POINT SUB)
X0.Y1.625
X-0.9551Y1.3146
X-1.5455 Y.5022
Y-0.5021
X-.9552Y-1.3147
X0.Y-1.625
X.9552Y-1.3146
X1.5455Y-.5022
Y0.5021
X0.9551Y1.3146
M99
I hope this helps clarify...
Thanks for all your responces.. You guys are great...
David,
You're going to need this wherever you want your G10 to be output in the program.
"(", pwcs, ")", e
"G90 G10", pwcsp, "X00.0000", "Y00.0000", "Z00.0000", "B000.000", e
Then you're going to need to put this postblock in your post somewhere after peof.
pwcsp            #Out put "P" for G10 Line
if workofs < 6,
p_wcs = workofs + 1
"L2", *p_wcs
else,
p_wcs = workofs - five
"L20", *p_wcs
I'm not sure I follow you on this?
Where do I put it?
Do I insert text?
I'm not even sure if I have my file setup right... I have a different WCS position for all the origins and parts.
I'm not translating any of the toolpaths... Should I ?
As far as the post edit... I think I have it right...
I've been using MC for about 8 years now and I still feel like I only know half of what I should... bonk.gif
Fastmill,
Here's a Makino A55 post with G10's.
It uses a std. Fanuc Txt with it.
Backup your post first. Then start copying and pasting pieces of this post into your Backed up copy of your post. You can copy your Mazak txt file if you want to make any changes to it.
I provide this with no warranty or guarantees.
 # Post Name           : MAKINOA55
# Product : MASTERCAM VER 9.1SP2
# Machine Name : MAKINO A55
# Control Name : PROFESSIONAL 3
# Description : FANUC HORIZONTAL MILL POST
# Associated Post : NONE
# Mill/Turn : NO
# 4-axis/Axis subs. : YES
# 5-axis : NO
# Subprograms : YES
# Executable : MP 9.14 Post Updated to run in 9.1SP2 jimmy 08/07/2004
# This an original Version 8 post modified and updated to run in V9.1SP2
# Revision log:
# Programmers Note:
# CNC 01/27/00 - Initial post setup, don
# CNC 05/23/00 - Move 'c_msng' in ptlchg0 to position subs when no work offset, jph
# CNC 07/27/00 - Modified for horizontal machines with the following additions / changes. jce
# 1. Added support for G10 use
# 2. Added MR1 for Z clearance point on a null toolchange.
# 3. Added strings and switch for lock/unlock of table.
# 4. Post is setup for G10 usage. May need customization to not use G10 or
# Use MPFAN and set VMC to 0 for horizontal with no G10 support.
# xxx 07/28/00 - Updated tapping cycles and header
# xxx 07/31/00 - 1. Added "n" number for each tool
# 2. Removed g28 line for tool change (contained in M6 code in machine)
# xxx 08/16/00 - Made separate programs for Multi-DNC usage
# 1. Now has seperate programs (g10 and Main)
# 2. Uses M198 to Call 2nd Program (Main)
# 3. Has M30 at end of 1st Program (G10) and M99 after 2nd Program (lines 594-612)
# 1. Changed the L12 callout for rad comp to L11 to conform to PRO 3 Control
# 2. Got rid of additional incremental B axis rotation on lines 1000-1013
# xxx 08/17/00 - Changed work offset designation on Parameters so 54-59=g54-g59(instead of 0-5=g54-g59)
# and 1-48=g54.1p1-g54.1p48(instead of 6-54=g54.1p1-g54.1p48).
# I just like it that way better.
# THIS POST HAS BEEN MODIFIED FOR MAKINO A55 HORIZONTALS ONLY
# Features:
# This post supports Generic Fanuc code output for 3 and 4 axis milling.
# It is designed to support the features of Mastercam Mill V9.1SP2
# Following Misc. Integers are used:
# mi1 - Work coordinate system
# 0 = Reference return is generated and G92 with the
# X, Y and Z home positions at file head.
# 1 = Reference return is generated and G92 with the
# X, Y and Z home positions at each tool.
# 2 = WCS of G54, G55.... based on Mastercam settings.
# mi2 - Absolute or Incremental positioning at top level
# 0 = absolute
# 1 = incremental
# mi3 - Select G28 or G30 reference point return.
# 0 = G28, 1 = G30
# Following Misc. Reals are used:
# mr1 - Z safe clearance position for rotary on null toolchange
#Canned text:
# Entering cantext on a contour point from within Mastercam allows the
# following functions to enable/disable.
# Cantext value:
# 1 = Stop = output the "M00" stop code
# 2 = Ostop = output the "M1" optional stop code
# 3 = Bld on = turn on block delete codes in NC lines
# 4 = bLd off = turn off block delete codes in NC lines
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative
# axis of rotation).
# vmc = 1 (vertical machine) uses the top toolplane as the base machine
# view.
# vmc = 0 (horizontal machine) uses the front toolplane as the base machine
# view.
# Relative to the machine matrix -
# Rotation zero position is on the Z axis for rotation on X axis.
# Rotation zero position is on the Z axis for rotation on Y axis.
# Rotation zero position is on the X axis for rotation on Z axis.
# The machine view rotated about the selected axis as a "single axis
# rotation" are the only legal views for 4 axis milling. Rotation
# direction around the part is positive in the CCW direction when
# viewed from the plus direction of the rotating axis. Set the variable
# 'rot_ccw_pos' to indicate the signed direction. Always set the work
# origin at the center of rotation.
#Toolplane Positioning:
# Create the Cplane and Tplane as the rotation of the machine view about
# the selected axis of rotation. The toolplane is used to calculate
# the position of the rotary axis. This is the default setting.
#3 Axis Rotary (Polar)
# Polar positioning is offered in Mastercam 3 axis toolpaths through the
# rotary axis options dialog. The selected toolpath is converted to angle
# and radius position. The axis of rotation is forced to zero.
#Axis substitution:
# Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder. The rotary axis button must be active for axis
# substitution information to be output to the NCI file. The radius of
# the rotary diameter is added to all the Z positions at output.
#Simultaneous 4 Axis (11 gcode):
# Full 4 axis toolpaths can be generated from various toolpaths under the
# 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are
# converted to 4 axis paths where only the angle about the rotation axis
# is resolved.
#Drill:
# All drill methods are supported in the post. See Simultaneous 4 Axis.
#Additional Notes:
# 1) Disable 4 axis by setting the numbered question 164. to 'n'.
# 2) G54 calls are generated where the work offset entry of 0 = G54,
# 1 = G55, etc.
# 3) Metric is applied from the NCI met_tool variable.
# 4) Incremental mode calculates motion from home position at toolchanges.
# The home position is used to define the last position of the tool
# for all toolchanges.
# 5) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for
# the 'top level' absolute/incremental program output. Subprograms are
# updated through the Mastercam dialog settings for sub-programs.
# 6) Always avoid machining to the center of rotation with rotary axis!
# 7) Transform subprograms are intended for use with G54.. workshifts.
# 8) G10 work offsets (L2 & L20) output is controlled by use_g10wcs flag. When active G10
# output will occur at the begining of the NC file and uses the tool origin.
# G10 L2 P_ X_ Y_ Z_
# 9) G10 Tool offsets (L11) output is controlled by use_g10tloff flag. When active G10 L11
# output will occur at the begining of the NC file and cancel at the end of the file in the
# following format.
# G10 L11 P_ R_
# Debugging and Factory Set Program Switches
m_one : -1 #Define constant
zero : 0 #Define constant
one : 1 #Define constant
two : 2 #Define constant
three : 3 #Define constant
four : 4 #Define constant
five : 5 #Define constant
c9k : 9999 #Define constant
fastmode : 1 #Posting speed optimizition, 0 for debug jimmy
bug1 : 2 #0=No display, 1=Generic list box, 2=Editor
bug2 : 30 #Append postline labels, non-zero is column position?
bug3 : 0 #Append whatline no. to each NC line?
bug4 : 1 #Append NCI line no. to each NC line?
whatno : yes #Do not perform whatline branches? (leave as yes)
get_1004 : 1 #Find gcode 1004 with getnextop?
skp_lead_flgs : 1 #Do not use v9 style contour flags
rpd_typ_v7 : 0 #Use Version 7 style contour flags/processing?
strtool_v7 : 2 #Use Version 7+ toolname?
tlchng_aft : 2 #Delay call to toolchange until move line
cant_tlchng : 1 #Ignore cantext entry on move with tlchng_aft
newglobal : 1 #Error checking for global variables
getnextop : 0 #Build the next variable table
tooltable : 1 #Read for tool table and pwrtt
# General Output Settings
sub_level : 1 #Enable automatic subprogram support
breakarcs : 0 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
helix_arc : 2 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck : 1 #Check for small arcs, convert to linear
atol : .01 #Angularity tolerance for arccheck = 2
ltol : .002 #Length tolerance for arccheck = 1
vtol : .0001 #System tolerance
maxfeedpm : 1000 #Limit for feed in inch/min
ltol_m : .05 #Length tolerance for arccheck = 1, metric
vtol_m : .0025 #System tolerance, metric
maxfeedpm_m : 10000 #Limit for feed in mm/min
force_wcs : yes #Force WCS output at every toolchange?
spaces : 0 #No. of spaces to add between fields
omitseq : YES #Omit sequence no.
seqmax : 9999 #Max. sequence no.
stagetool : 1 #0 = Do not pre-stage tools, 1 = Stage tools
use_gear : 0 #Output gear selection code, 0=no, 1=yes
max_speed : 14000 #Maximum spindle speed
min_speed : 50 #Minimum spindle speed
nobrk : YES #Omit breakup of x, y & z rapid moves
progname : 1 #Use uppercase for program name
use_g10wcs : yes #Output G10 work offsets
use_g10tloff : yes #Output G10 Tool offsets
hoffset = tloffno
doffset = 17
prognomain = progno + 1
prognomainsub = progno + 1
# Rotary Axis Settings
vmc : 0 #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x : 2 #Default Rotary Axis Orientation, See ques. 164.
#0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 1 #Axis signed dir, 0 = CW positive, 1 = CCW positive
index : 0 #Use index positioning, 0 = Full Rotary, 1 = Index only
lock_table : YES #Lock table for indexing operations
ctable : 1 #Degrees for each index step with indexing spindle
use_frinv : 0 #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
maxfrdeg : 2000 #Limit for feed in deg/min
maxfrinv : 999.99#Limit for feed inverse time
frc_cinit : 1 #Force C axis reset at toolchange
ctol : 225 #Tolerance in deg. before rev flag changes
ixtol : .01 #Tolerance in deg. for index error
frdegstp : 10 #Step limit for rotary feed in deg/min
# Enable Canned Drill Cycle Switches
usecandrill : yes #Use canned cycle for drill
usecanpeck : yes #Use canned cycle for Peck
usecanchip : yes #Use canned cycle for Chip Break
usecantap : yes #Use canned cycle for Tap
usecanbore1 : yes #Use canned cycle for Bore1
usecanbore2 : yes #Use canned cycle for Bore2
usecanmisc1 : yes #Use canned cycle for Misc1
usecanmisc2 : yes #Use canned cycle for Misc2
# Common User-defined Variable Initializations (not switches!)
xia : 0 #Formated absolute value for X incremental calculations
yia : 0 #Formated absolute value for Y incremental calculations
zia : 0 #Formated absolute value for Z incremental calculations
cia : 0 #Formated absolute value for C incremental calculations
cuttype : 0 #Cut type flag
#0 = Tool Plane, 1 = Axis Subs, 2 = Polar, 3 = 4/5 axis
bld : 0 #Block delete active
result : 0 #Return value for functions
sav_spc : 0 #Save spaces
sav_gcode : 0 #Gcode saved
sav_absinc : 0 #Absolute/Incremental Saved Value
sav_coolant : 0 #Coolant saved
sav_frc_wcs : 0 #Force work offset flag saved
toolchng : 1 #On a toolchange flag
spdir2 : 1 #Copy for safe spindle direction calculation
#Drill variables
drlgsel : -1 #Drill Select Initialize
drillref : 0 #Select drill reference
peckacel : 0 #Fractional percent to reduce peck2 when usecan.. : no
drlgcode : 0 #Save Gcode in drill
sav_dgcode : 0 #Drill gcode saved
#Subprogram variables
mr_rt_actv : 0 #Flag to indicate if G51/G68 is active
#0=Off, 1=Toolchange, 2=Subprogram call/start, G68
#3=Absolute start, both
rt_csav : 0 #C saved value
end_sub_mny : 0 #Many tool setting captured at transform sub end
#Rotary/Index variables
prvcabs : 0 #Saved cabs from pe_inc_calc,
#Used for rotary feed and direction calculations
cdelta : 0 #Calculation for angle change
rev : 0 #Calculation for deg/min
sav_rev : 0 #Saved revolution counter
indx_out : c9k #Rotation direction calculation
fmt 16 indx_mc #Rotation direction calculation
#Vector Constants for Rotatary Calculations
aaxisx : 1 #A axis rotation vector constant
aaxisy : 0 #A axis rotation vector constant
aaxisz : 0 #A axis rotation vector constant
baxisx : 0 #B axis rotation vector constant
baxisy : 1 #B axis rotation vector constant
baxisz : 0 #B axis rotation vector constant
caxisx : 0 #C axis rotation vector constant
caxisy : 0 #C axis rotation vector constant
caxisz : 1 #C axis rotation vector constant
#Feedrate calculation variables
frdelta : 0 #Calculation for deg/min
frinv : 0 #Feedrate inverse time
frdeg : 0 #Feedrate deg/min actual
prvfrdeg : 0 #Feedrate deg/min actual
ldelta : 0 #Calculation for deg/min, linear
cldelta : 0 #Calculation for deg/min, linear and rotary
circum : 0 #Calculation for deg/min
ipr_type : 0 #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place
fs2 16 1 0 1 0n #Integer, forced output
#String and string selector definitions for NC output
#Numbered question 164. string to detect Rotary axis y/n
sq164
#Address string definitions
strm "M"
strn "N"
stro "O"
strp "P"
srad "R"
srminus "R-"
sblank
#Cantext string definitions (spaces must be padded here)
sm00 "M0"
sm01 "M1"
strtextno
strcantext
#Transform mirror and rotate codes
strns_mir_on "G51.1" #Programmable mirror image code
strns_mir_off "G50.1" #Programmable mirror image cancel code
strns_rot_on "G68" #Coordinate System Rotation
strns_rot_off "G69" #Coordinate System Rotation Cancel
# Error messages
saxiswarn "WARNING-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') OVERWRITTEN BY OPERATION"
saxisoff "ERROR-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') IS DISABLED"
saxiserror "ERROR-INVALID ROTARY AXIS ASSIGNMENT ('rot_on_x') FOR CURRENT OPERATION"
sindxerror "WARNING-INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')"
stlorgerr "ERROR-TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING"
shomeserror "ERROR-G92 WORK OFFSET ('mi1') DOES NOT SUPPORT TRANSFORM SUBPROGRAM"
# General G and M Code String select tables
# Motion G code selection
sg00 G0 #Rapid
sg01 G1 #Linear feed
sg02 G2 #Circular interpolation CW
sg03 G3 #Circular interpolation CCW
sg04 G4 #Dwell
sgcode #Target for string
fstrsel sg00 gcode sgcode
# Select work plane G code
sg17 G17 #XY plane code
sg19 G19 #YZ plane code
sg18 G18 #XZ plane code
sgplane #Target string
fstrsel sg17 plane sgplane
#Select english/metric code
sg20 G20 #Inch code
sg21 G21 #Metric code
smetric #Target string
fstrsel sg20 met_tool smetric
#Select reference return code
sg28 G28 #First reference point return
sg30 G30 #Second reference point return
sg28ref #Target string
fstrsel sg28 mi3 sg28ref
# Cutter compensation G code selection
scc0 G40 #Cancel cutter compensation
scc1 G41 #Cutter compensation left
scc2 G42 #Cutter compensation right
sccomp #Target for string
fstrsel scc0 cc_pos sccomp
# Canned drill cycle string select
sg81 G81 #drill - no dwell
sg81d G82 #drill - with dwell
sg83 G83 #peck drill - no dwell
sg83d G83 #peck drill - with dwell
sg73 G73 #chip break - no dwell
sg73d G73 #chip break - with dwell
sg84 G84 #tap - right hand
sg84d G74 #tap - left hand
sg85 G85 #bore #1 - no dwell
sg85d G89 #bore #1 - with dwell
sg86 G86 #bore #2 - no dwell
sg86d G86 #bore #2 - with dwell
sgm1 G183 #misc #1 - no dwell
sgm1d G183 #misc #1 - with dwell
sgm2 G81 #misc #2 - no dwell
sgm2d G82 #misc #2 - with dwell
sgdrill #Target for string
fstrsel sg81 drlgsel sgdrill
# Select incremental or absolute G code
sg90 G90 #Absolute code
sg91 G91 #Incremental code
sgabsinc #Target string
fstrsel sg90 absinc sgabsinc
# Feed mode G code selection
sg94 G94 #UPM
sg94d G94 #DPM, See pfcalc_deg if you use another gcode
sg93 G93 #Inverse
sgfeed #Target for string
fstrsel sg94 ipr_type sgfeed
#Canned drill cycle reference height
sg98 G98 #Reference at initht
sg99 G99 #Reference at refht
sgdrlref #Target for string
fstrsel sg98 drillref sgdrlref # Drill cycle G string select
# Generate string for spindle
sm04 M4 #Spindle reverse
sm05 M5 #Spindle off
sm03 M3 #Spindle forward
spindle #Target for string
fstrsel sm04 spdir2 spindle
# Coolant M code selection
sm09 M9 #Coolant Off
sm08 M8 #Coolant Flood
sm08_1 M8 #Coolant Mist
sm08_2 M26 #Coolant Tool
sm08_3 m
scoolant #Target for string
fstrsel sm09 coolant scoolant
# Table rotation direction
# Table rotation direction, index
sindx_cw M22 #Rotate CW code
sindx_ccw M21 #Rotate CCW code
sindx_mc #Target for string
fstrsel sindx_cw indx_mc sindx_mc
sunlock M11 # Unlock Rotary Table
slock M10 # Lock Rotary Table
# Define the gear selection code
flktbl 1 3 #Lookup table definition - table no. - no. entries
40 0 #Low gear range
41 400 #Med gear range
42 2250 #Hi gear range
# Toolchange / NC output Variable Formats
fmt T 4 t #Tool No
fmt T 4 first_tool #First Tool Used
fmt T 4 next_tool #Next Tool Used
fmt D 4 tloffno #Diameter Offset No
fmt N 4 hoffset #equal to tloffno for N block at tool change
fmt D 4 doffset #default diameter offset number for MAKINO
fmt H 4 tlngno #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt N 4 n #Sequence number
fmt X 2 xabs #X position output
fmt Y 2 yabs #Y position output
fmt Z 2 zabs #Z position output
fmt X 3 xinc #X position output
fmt Y 3 yinc #Y position output
fmt Z 3 zinc #Z position output
fmt Z 2 zclrot #Z clearance position for rotation
fmt B 11 cabs #C axis position
fmt B 14 cinc #C axis position
fmt B 4 indx_out #Index position
fmt R 14 rt_cinc #C axis position, G68
fmt I 3 i #Arc center description in X
fmt J 3 j #Arc center description in Y
fmt K 3 k #Arc center description in Z
fmt R 2 arcrad #Arc Radius
fmt F 15 feed #Feedrate
fmt P 4 dwell #Dwell
fmt M 5 cantext #Canned text
#Move comment (pound) to output colon with program numbers
fmt O 7 progno #Program number
#fmt ":" 7 progno #Program number
fmt P 7 prognomain #Program number +1
#fmt ":" 7 prognomain #Program number +1
fmt O 7 prognomainsub #Program number +1
#fmt ":" 7 prognomainsub #Program number +1
fmt O 7 main_prg_no #Program number
#fmt ":" 7 main_prg_no #Program number
fmt O 7 sub_prg_no #Program number
#fmt ":" 7 sub_prg_no #Program number
fmt X 2 sub_trnsx #Rotation point
fmt Y 2 sub_trnsy #Rotation point
fmt Z 2 sub_trnsz #Rotation point
fmt Q 2 peck1 #First peck increment (positive)
fmt Q 2 shftdrl #Fine bore tool shift
fmt R 2 refht_a #Reference height
fmt R 2 refht_i #Reference height
fmt "T" 4 tnote # Note format
fmt " DIA. OFF. - " 4 toffnote # Note format
fmt " LEN. - " 4 tlngnote # Note format
fmt " DIA. - " 1 tldia # Note format
# Tool Comment / Manual Entry Section
ptoolcomment #Comment for tool
tnote = t
toffnote = tloffno
tlngnote = tlngno
"(", *tnote," ",pstrtool, ")", e
pstrtool #Comment for tool
if strtool <> sblank,
strtool = ucase(strtool)
*strtool, " "
pcomment #Comment from manual entry (must call pcomment2 if booleans)
pcomment2
pcomment2 #Comment from manual entry
scomm = ucase (scomm)
if gcode = 1007, "(", scomm, ")"
else, "(", scomm, ")", e
# Start of File and Toolchange Setup
psof0 #Start of file for tool zero
psof
psof #Start of file for non-zero tool number
pcuttype
toolchng = one
if ntools = one,
#skip single tool outputs, stagetool must be on
stagetool = m_one
!next_tool
"%", e
*progno, "(", progname, "-G10)", e
"(MAKINO A55 HORIZONTAL)", e
"(TORQUE VALUE ---FT/LBS)", e
"(CUSTOMER NAME ---)", e
"(PART NUMBER ---", progname, ")", e
"(PART NAME ---)", e
"( ---)", e
"( ---)", e
"(PROGRAM BY ---JIMMY KALLHOFF)", e
"(PROGRAM DATE ---", month,"/",day,"/",year,")", e
"(PROVEN DATE ---)", e
"(CYCLE TIME ---)", e
" ", e
pbld, n, *sgcode, *sgplane, *smetric, "G40", "G49", "G80", *sgabsinc, e
"G10L2P0X0Y0Z0B0", e
#Read buffer 2 and write out preload work offsets
if use_g10wcs = yes, preloadwcs
" ", e
if use_g10tloff = yes, preloadtloff
" ", e
"M98", *prognomain, e
" ", e
"G90M30", e
sav_absinc = absinc
if mi1 <= one, #Work coordinate system
absinc = one
# pfbld, n, sgabsinc, *sg28ref, "Z0", e
# pfbld, n, *sg28ref, "X0", "Y0", e
pfbld, n, "G92", *xh, *yh, *zh, e
absinc = sav_absinc
pcom_moveb
c_mmlt #Multiple tool subprogram call
pcan
*prognomainsub, "(", progname, "-MAIN)", e
hoffset, *t, "M6", e
"M1", e
"M11", e
pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, "B0", scoolant, e
"M10", e
ptoolcomment
comment
pindex, pfxout, pfyout, *speed, *spindle, pgear, strcantext, next_tool, e
"G43", "H1", pfzout, "M754", e #turn on chip conveyor wash
"G8P1", e
absinc = sav_absinc
pcom_movea
toolchng = zero
c_msng #Single tool subprogram call
ptlchg0 #Call from NCI null tool change (tool number repeats)
pcuttype
pcom_moveb
pzclrot
pcan
pbld, n, sgplane, e
# if prv_spdir2 <> spdir2, pbld, n, *sm05, e
if prv_speed <> speed | prv_spdir2 <> spdir2,
pbld, n, *speed, *spindle, pgear, e
pbld, n, scoolant, e
if mi1 > one & workofs <> prv_workofs,
sav_absinc = absinc
absinc = zero
"G8P0",e
"M128", e
" ", e
"M11", e
pbld, n, *sgabsinc, pwcs, "B0", e
"M10", e
comment
pfxout, pfyout, e
"G8P1", e
pe_inc_calc
ps_inc_calc
absinc = sav_absinc
if cuttype = zero, ppos_cax_lin
if gcode = one, plinout
else, prapidout
pcom_movea
ptlchg #Tool change
pcuttype
toolchng = one
if mi1 = one, #Work coordinate system
# pbld, n, "M1", e
pcom_moveb
pcan
"G8P0",e
pbld, n, "M117", e
" ", e
sav_absinc = absinc
if mi1 > one, absinc = zero
hoffset, "M1", e
*t,"M6", e
"M11", e
"M10", e
ptoolcomment
comment
"G43", *"H1", pfzout, "M754", e #turn on chip conveyor wash
"G8P1",e
absinc = sav_absinc
pcom_movea
toolchng = zero
pretract #End of tool path, toolchange
sav_absinc = absinc
absinc = one
sav_coolant = coolant
coolant = zero
#cc_pos is reset in the toolchange here
cc_pos = zero
gcode = zero
# pbld, n, sccomp, *sm05, psub_end_mny, e
# pbld, n, sgabsinc, sgcode, *sg28ref, "Z0",
scoolant, e
# pbld, n, *sg28ref, "X0", "Y0", protretinc, e
absinc = sav_absinc
coolant = sav_coolant
protretinc #Reset the C axis revolution counter
if frc_cinit & rot_on_x,
rev = zero
sav_rev = zero
cabs = zero
csav = zero
indx_out = zero
if index, e, pindxcalc, pindex
else, *cabs
prvcabs = zero
!csav, !cabs
peof0 #End of file for tool zero
peof
peof #End of file for non-zero tool
pretract
comment
#Remove pound character to output first tool with staged tools
#if stagetool = one, pbld, n, *first_tool, e
"M6", e
"M1", e
" ", e
" ", e
n, "G90", e
n, "M99", e
mergesub
clearsub
mergeaux
clearaux
"%", e
pwcs #G54+ coordinate setting at toolchange
if mi1 > one,
sav_frc_wcs = force_wcs
if sub_level, force_wcs = zero
if workofs <> prv_workofs | (force_wcs & toolchng),
if workofs > 53,
g_wcs = workofs
*g_wcs
else,
p_wcs = workofs
"G54.1", *p_wcs
force_wcs = sav_frc_wcs
!workofs
pgear #Find spindle gear from lookup table
if use_gear = one,
gear = frange (one, speed)
*gear
#Toolchange setup
pspindle #Spindle speed calculations for RPM
speed = abs(ss)
if maxss = zero | maxss > max_speed, maxss = max_speed
if speed > max_speed, speed = maxss
if speed < min_speed, speed = min_speed
spdir2 = fsg3(spdir)
pq #Setup post based on switch settings
if stagetool = one, bldnxtool = one
#Rotaxtyp = 1 sets initial matrix to top
#Rotaxtyp = -2 sets initial matrix to front
if vmc, rotaxtyp = one
else, rotaxtyp = -2
#Shut off rotary axis if, Q164. Enable Rotary Axis button? n
if ucase(sq164) = strn, rot_on_x = zero
if arctype = one | arctype = four,
result = newfs(two, i)
result = newfs(two, j)
result = newfs(two, k)
else,
result = newfs(three, i)
result = newfs(three, j)
result = newfs(three, k)
pheader #Call before start of file
if met_tool = one, #Metric constants and variable adjustments
ltol = ltol_m
vtol = vtol_m
maxfeedpm = maxfeedpm_m
ptoolend #End of tool path, before reading new tool data
!speed, !spdir2
ptlchg1002 #Call at actual toolchange, end last path here
sav_rev = rev #Axis Sub does not update to rev
pspindle
whatline = four #Required for vector toolpaths
if gcode = 1000,
#Null toolchange
else,
#Toolchange and Start of file
if gcode = 1002,
#Actual toolchange
pretract
if stagetool = one, prv_next_tool = m_one
prv_xia = vequ(xh)
prv_feed = c9k
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout #Output to NC of linear movement - rapid
pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, strcantext, scoolant, e
plinout #Output to NC of linear movement - feed
pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, feed, strcantext, scoolant, e
pcirout #Output to NC of circular interpolation
pcan1, pbld, n, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, parc, feed, strcantext, scoolant, e
pcom_moveb #Common motion preparation routines, before
pxyzcout
ps_inc_calc
pncoutput #Movement output
pcom_moveb
comment
pcan
if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
if gcode = zero, prapidout
if gcode > one & gcode < four, pcirout
if mr_rt_actv, #Restore absolute/incremental for G51/G68
absinc = sav_absinc
mr_rt_actv = zero
pcom_movea
pcom_movea #Common motion preparation routines, after
pcan2
pe_inc_calc
pdwl_spd #Call from NCI gcode 4
pspindle
comment
pcan
if fmtrnd(dwell), pcan1, pbld, n, *sgcode, dwell, strcantext, e
else, pcan1, pbld, n, strcantext, e
pcan2
prapid #Output to NC of linear movement - rapid
pncoutput
pzrapid #Output to NC of linear movement - rapid Z only
pncoutput
plin #Output to NC of linear movement - feed
pncoutput
pz #Output to NC of linear movement - feed Z only
pncoutput
pmx #Output to NC of vector NCI
pncoutput
pcir #Output to NC of circular interpolation
pncoutput
#Pre-process rotary motion control flags
pmx0 #5 axis gcode setup
if drillcur = zero,
if fr = -2, gcode = zero
else, gcode = one
plin0 #Linear movement, mill motion test
pmotion_su
pcir0 #Circular interpolation, mill arc motion test
pmotion_su
# Motion output components
pbld #Canned text - block delete
if bld, '/'
pfbld #Force - block delete
pccdia #Cutter Compensation
#Force Dxx#
# if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno = c9k
sccomp
if cc_pos, doffset
pzclrot #Z Clearance for rotation on Null Tool change
# prv_indx_out, ~indx_out, e
if prv_indx_out <> fmtrnd (indx_out),
zclrot = mr1
gcode = 0
pbld, n, "G8P0",e
"M128", e
pfxout #Force X axis output
if absinc = zero, *xabs, !xinc
else, *xinc, !xabs
pxout #X output
if absinc = zero, xabs, !xinc
else, xinc, !xabs
pfyout #Force Y axis output
if absinc = zero, *yabs, !yinc
else, *yinc, !yabs
pyout #Y output
if absinc = zero, yabs, !yinc
else, yinc, !yabs
pfzout #Force Z axis output
if absinc = zero, *zabs, !zinc
else, *zinc, !zabs
pzout #Z output
if absinc = zero, zabs, !zinc
else, zinc, !zabs
pfcout #Force C axis output
if index = zero & rot_on_x,
if absinc = zero, *cabs, !cinc
else, *cinc, !cabs
pcout #C axis output
if absinc = zero, cabs, !cinc
else, cinc, !cabs
pindex #Index output
if index & rot_on_x & prv_indx_out <> fmtrnd (indx_out),
if use_g10wcs = 1, indx_out = 0
# `sindx_mc, indx_out
if lock_table = yes, pbld, n, *sunlock, e
*indx_out
if lock_table = yes, pbld, n, *slock, e
!cabs, !cinc
parc #Select the arc output
if arcoutput = zero,
#Arc output for IJK
*i, *j, k
else,
#Arc output for R
if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
else, result = nwadrs(srminus, arcrad)
*arcrad
ppos_cax_lin #Position the rotary axis before move - rapid
# if index, pindex
# else,
# if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x,
# sav_gcode = gcode
# gcode = zero
# pbld, n, sgcode, pcout, e
# !cia
# ps_cinc_calc
# gcode = sav_gcode
# Drilling
pdrill0 #Pre-process before drill call
sav_dgcode = gcode #Capture gcode for 5 axis drill
pdrlcommonb #Canned Drill Cycle common call, before
if sav_dgcode = 81,
result = newfs (two, zinc)
if drillcyc = three, drlgsel = fsg1(-ss) + drillcyc * two
else, drlgsel = fsg2(dwell) + drillcyc * two
if initht <> refht, drillref = zero
else, drillref = one
prv_refht_a = c9k
prv_refht_i = c9k
if cuttype = three, sav_dgcode = gcode
else, z = depth
if cuttype = one, prv_zia = initht + (rotdia/two)
else, prv_zia = initht
feed = fr_pos
prv_dwell = zero
@dwell
pcom_moveb
comment
pcan
#5 axis must map the true Z, correct Z calculation here
if cuttype = three,
prv_zia = zabs + (-depth) + initht
zia = fmtrnd(zabs)
zinc = zia - prv_zia
prdrlout #R drill position
if cuttype = one, refht_a = refht + (rotdia / two))
else, refht_a = refht
refht_i = refht - initht
if cuttype = three, refht_a = w
if absinc = zero, refht_a, !refht_i
else, refht_i, !refht_a
pdrill #Canned Drill Cycle
pdrlcommonb
pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, prdrlout,
dwell, *feed, strcantext, e
pcom_movea
ppeck #Canned Peck Drill Cycle
pdrlcommonb
prdrlout, *peck1, *feed, strcantext, e
pcom_movea
pchpbrk #Canned Chip Break Cycle
pdrlcommonb
pcom_movea
ptap #Canned Tap Cycle
pdrlcommonb
"G8P0"
*speed, e
"M135", e
prdrlout, *feed, strcantext, e
pcom_movea
pbore1 #Canned Bore #1 Cycle
pdrlcommonb
prdrlout, dwell, *feed, strcantext, e
pcom_movea
pbore2 #Canned Bore #2 Cycle
pdrlcommonb
pcom_movea
pmisc1 #Canned Misc #1 Cycle
pdrlcommonb
prdrlout, shftdrl, dwell, *feed, strcantext, e
pcom_movea
pmisc2 #Canned Misc #2 Cycle (User Option)
pdrill
pdrill_2 #Canned Drill Cycle, additional points
pdrlcommonb
pcan1, pbld, n, pxout, pyout, pzout, prdrlout, dwell,
feed, strcantext, e
pcom_movea
ppeck_2 #Canned Peck Drill Cycle
pdrill_2
pchpbrk_2 #Canned Chip Break Cycle
pdrill_2
ptap_2 #Canned Tap Cycle
pdrill_2
pbore1_2 #Canned Bore #1 Cycle
pdrill_2
pbore2_2 #Canned Bore #2 Cycle
pdrill_2
pmisc1_2 #Canned Misc #1 Cycle
pdrill_2
pmisc2_2 #Canned Misc #2 Cycle
pdrill_2
pdrlcst #Custom drill cycles 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
"CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, e
pcom_movea
pdrlcst_2 #Custom drill cycles 8 - 19, additional points (user option)
pdrlcommonb
pcom_movea
pcanceldc #Cancel canned drill cycle
result = newfs (three, zinc)
z = initht
pxyzcout
!zabs, !zinc
prv_gcode = zero
pbld, n, "G80", e
#Subprogram postblocks
#sub_trnstyp - 0=mirror, 1=rotate, 2=scale, 3=translate
#sub_trnmthd (mirror) - 0=X axis, 1=Y axis, 2=line
#sub_trnmthd (rotate) - 0=tplane, 1=tplane origin only, 2=coordinates
psub_call_m #Call to main level, single tool
psub_call_trans
psub_call_mm #Call to main level, multiple tools
psub_call_trans
psub_call_trans #Translate level calls from toolchange, user
if mi1 <= one, result = mprint(shomeserror)
sav_absinc = absinc
pindex
#Mirror or Rotate Coord's
if sub_trnstyp = zero | (sub_trnstyp = one & mr_rt_actv),
#The original pattern is not mirrored or rotated
if sub_sec_no,
absinc = zero
if sub_trnstyp, psub_rotate
else, psub_mirror
mr_rt_actv = three
else, #Translate
if sub_mny_t,
pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfzout,
pfcout, e
pe_inc_calc
ps_inc_calc
absinc = sav_absinc
result = nwadrs(strp, main_prg_no)
pbld, n, "M98", *main_prg_no, e
prv_feed = c9k #Force feed in sub
psub_mirror #Mirror start code, user
#Mirror Y axis
if sub_trnmthd, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsx, e
#Mirror X axis
else, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsy, e
psub_rotate #Rotate start code, user
pbld, n, *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx, *sub_trnsy,
[absinc = one], *sgabsinc, *rt_cinc, e
psub_st_m #Header in main level
result = nwadrs(stro, main_prg_no)
" ", e
*main_prg_no, e
#G51/G68 requires absolute position on first move
if mr_rt_actv & absinc = one,
sav_absinc = absinc
absinc = zero
prv_absinc = m_one
prv_xabs = m_one
prv_yabs = m_one
else, pbld, n, sgabsinc, e
psub_end_m #End in main level
n, "M99", e
#Reset update variables for subs at main level
#Mirror or Rotate cancel, output is forced
if (sub_trnstyp = zero & esub_sec_no > zero)
| (sub_trnstyp = one & esub_sec_no = esub_totl_no-one
& sub_trnmthd = two),
subout = zero
no_nc_out = m_one
sav_absinc = absinc
#Mirror cancel
if sub_trnstyp = zero,
absinc = zero
pbld, n, *sgabsinc, strns_mir_off, *sub_trnsx, *sub_trnsy, e
else, #Rotate cancel
pbld, n, strns_rot_off, e
absinc = sav_absinc
no_nc_out = zero
end_sub_mny = sub_mny_t
psub_end_mny #End in main level for many tools sub, user
#Check for coming out of xform with stage tool.
if end_sub_mny & stagetool = one,
*t
end_sub_mny = zero
psub_call_s #Call to sub level
result = nwadrs(strp, sub_prg_no)
sub_prg_no = sub_prg_no + 1000 #Add sub number offset
pbld, n, "M98", *sub_prg_no, e
psub_st_s #Header in sub leveln
result = nwadrs(stro, sub_prg_no)
" ", e
*sub_prg_no, e
psub_end_s #End in sub level
n, "M99", e
# Canned Text
pcan #Canned text - before output call
strcantext = sblank
if cant_no > zero,
if cant_pos1 = zero, pcant_1
if cant_pos2 = zero, pcant_2
if cant_pos3 = zero, pcant_3
if cant_pos4 = zero, pcant_4
if cant_pos5 = zero, pcant_5
if cant_pos6 = zero, pcant_6
if cant_pos7 = zero, pcant_7
if cant_pos8 = zero, pcant_8
if cant_pos9 = zero, pcant_9
if cant_pos10 = zero, pcant_10
strcantext = sblank
pcan1 #Canned text - with move
strcantext = sblank
if cant_no > zero,
if cant_pos1 = one, pcant_1
if cant_pos2 = one, pcant_2
if cant_pos3 = one, pcant_3
if cant_pos4 = one, pcant_4
if cant_pos5 = one, pcant_5
if cant_pos6 = one, pcant_6
if cant_pos7 = one, pcant_7
if cant_pos8 = one, pcant_8
if cant_pos9 = one, pcant_9
if cant_pos10 = one, pcant_10
if cstop, strcantext = strcantext + sm00
if cgstop, strcantext = strcantext + sm01
#Output of strcantext occurs at the end of the output line
pcan2 #Canned text - after output call
strcantext = sblank
if cant_no > zero,
if cant_pos1 = two, pcant_1
if cant_pos2 = two, pcant_2
if cant_pos3 = two, pcant_3
if cant_pos4 = two, pcant_4
if cant_pos5 = two, pcant_5
if cant_pos6 = two, pcant_6
if cant_pos7 = two, pcant_7
if cant_pos8 = two, pcant_8
if cant_pos9 = two, pcant_9
if cant_pos10 = two, pcant_10
strcantext = sblank
pcant_1 #Canned text - output call
cantext = cant_val1
pcant_out
pcant_2 #Canned text - output call
cantext = cant_val2
pcant_out
pcant_3 #Canned text - output call
cantext = cant_val3
pcant_out
pcant_4 #Canned text - output call
cantext = cant_val4
pcant_out
pcant_5 #Canned text - output call
cantext = cant_val5
pcant_out
pcant_6 #Canned text - output call
cantext = cant_val6
pcant_out
pcant_7 #Canned text - output call
cantext = cant_val7
pcant_out
pcant_8 #Canned text - output call
cantext = cant_val8
pcant_out
pcant_9 #Canned text - output call
cantext = cant_val9
pcant_out
pcant_10 #Canned text - output call
cantext = cant_val10
pcant_out
pcant_out #Canned text - build the string for output
#Assign string select type outputs
if cantext = three, bld = one
if cantext = four, bld = zero
#Build the cantext string
if cantext = one, strcantext = strcantext + sm00
if cantext = two, strcantext = strcantext + sm01
if cantext > four,
strtextno = no2str(cantext)
strcantext = strcantext + strm + strtextno
# Position calculations, generally these do not need to be modified
pmiscint #Capture the top level absinc for subprograms
if sub_level = zero, absinc = mi2
#Disable cutpos2 if not 4 axis, saves time
if rot_on_x = zero, cutpos2 = m_one
pmotion_su #Motion Setup (Set brklinestype & linarc)
brklinestype = zero
linarc = zero
if rot_on_x,
if cuttype = one, linarc = one #Axis subs
if cuttype = two, #Polar
brklinestype = rotary_axis + three
linarc = one
pcuttype #Determine the cut type
#cuttype (0 = Tool Plane, 1 = Axis Subs, 2 = Polar, 3 = 4/5 axis)
cuttype = rotary_type
if cuttype = three, cuttype = zero
if mill5,
if rot_on_x = zero, result = mprint(saxisoff)
cuttype = three
if rotary_axis,
if rotary_axis <> rot_on_x, result = mprint(saxiswarn)
rot_on_x = rotary_axis
#Check for Tool Origin in Polar Milling
if cuttype = two & (tox | toy | toz), result = mprint(stlorgerr)
#Transform Rotate, set mr_rt_actv if user selected 'coordinates'
if sub_trnstyp = one & sub_trnmthd = two,
#Calculate the rotation incremental angle for G68
rt_csav = atan2(sub_m2, sub_m1)
rt_cinc = prv_rt_csav - rt_csav
while rt_cinc > 180, rt_cinc = rt_cinc - 360
while rt_cinc < -180, rt_cinc = rt_cinc + 360
if rot_ccw_pos = one, rt_cinc = -rt_cinc
!rt_csav
if sub_sec_no, mr_rt_actv = two
else, mr_rt_actv = one
else, mr_rt_actv = zero
pfcalc_u_min
pmotion_su
pxyzcout #Map coordinates
if rot_on_x,
if cuttype = zero, pxyzcout0 #Toolplane Positioning
if cuttype = one, pxyzcout1 #Axis Substitution
if cuttype = two, pxyzcout2 #Polar Conversion
if cuttype = three, pxyzcout3 #Simulatneous 4 axis (Multi-axis)
if rot_ccw_pos = one, csav = -csav
if mr_rt_actv <> two,
pcoutrev
if index, pindxcalc
pfcalc
else, feed = fr_pos
else,
xabs = vequ (x)
feed = fr_pos
xabs = vequ (x)
if rot_on_x = two, csav = -c
else, csav = c
pxyzcout1 #Axis substitution
if rot_on_x = one, #X axis substitution
xabs = x
yabs = zero
zabs = z + (rotdia / two)
csav = -y * (360 / (pi * rotdia))
else, #Y axis substitution
xabs = zero
yabs = y
csav = -x * (360 / (pi * rotdia))
pxyzcout2 #polar interpolation
#Drill polar is toolplane drilling toward center
#if not a coincident axis
#Also, Capture initial index position for Polar Milling
if (opcode = three & rot_on_x <> three), pxyzcout0
else,
if rot_on_x = one, #X axis rotation
csav = atan2(y, z) #Z+ zero
axisx = vequ(aaxisx)
xabs = rotp(csav, x)
if rot_on_x = two, #Y axis rotation
csav = atan2(-x, z) #Z+ zero
axisx = vequ(baxisx)
if rot_on_x = three, #Z axis rotation
csav = atan2(-y, x) #X+ zero
axisx = vequ(caxisx)
csav = csav + c
pxyzcout3 #Multisurf rotary axis motion
if rot_on_x = one, #Multisurf Rotary about X
csav = atan2 (vtooly, vtoolz)
axisx = vequ (aaxisx)
if rot_on_x = two, #Multisurf Rotary about Y
csav = atan2 (-vtoolx, vtoolz)
axisx = vequ (baxisx)
xabs = rotp (csav, x)
u = rotp (csav, u)
csav = csav + c
pcoutrev #Rotary axis revolution calculation (Modify for wind-up)
cdelta = csav - prv_csav
while abs(cdelta) > ctol, #If motion exceeds ctol, add wind-up
if cdelta > zero,
rev = rev - one
cdelta = cdelta - 360
else,
rev = rev + one
cdelta = cdelta + 360
if cuttype <> one, cabs = rev * 360 + csav
else, cabs = sav_rev * 360 + csav
!csav
pindxcalc #Index move calculations, direction is shortest
#Check if in tolerance
cdelta = frac(abs(csav)/ctable)
if cdelta > ixtol & cdelta < 1-ixtol,
result = mprint(sindxerror)
cdelta = prvcabs - cabs
#Phase shift delta 10 revolutions, check odd/even
if frac(int((cdelta + 3600)/180)/two), indx_mc = one
else, indx_mc = zero
#Set range 0-360
indx_out = csav
while indx_out < 0, indx_out = indx_out + 360
while indx_out > 360, indx_out = indx_out - 360
#Feedrate calculations
pfcalc #Feedrate calculations, gcode 0 does not evaluate
if gcode <> zero,
if fmtrnd(cabs) = prvcabs | index, pfcalc_u_min
else,
if cuttype = one & (cutpos2 <= one | cutpos2 = four),
pfcalc_u_min
else, pfclc_deg_inv
if ipr_type <> prv_ipr_type, prv_feed = c9k
pfcalc_u_min #Feedrate unit/min
ipr_type = zero
feed = fr_pos
if feed > maxfeedpm, feed = maxfeedpm
prvfrdeg = feed
pfclc_deg_inv #Feedrate deg/min
circum = zabs * two * pi
if circum = zero, circum = c9k #Don't allow Zero
ldelta = sqrt((xabs-prv_xabs)^2+(yabs-prv_yabs)^2+(zabs-prv_zabs)^2)
cdelta = ((abs(cabs - prvcabs))/360)*circum
if ldelta = zero, cldelta = cdelta
else, cldelta = sqrt(cdelta^two + ldelta^two)
if cldelta = zero, cldelta = c9k
if use_frinv,
#Feedrate inverse calculation
ipr_type = two
prv_feed = c9k #Always force feed
frinv = fr_pos/cldelta
if frinv > maxfrinv, frinv = maxfrinv
feed = frinv
else,
#Feedrate deg/min control and calculation
ipr_type = zero #Change to ipr_type = one to force new DPM
frdeg = abs(cdelta/cldelta) * abs(fr_pos * (360/circum))
if abs(frdeg - prvfrdeg) > frdegstp | ipr_type <> prv_ipr_type,
#Control output of frdeg
prvfrdeg = frdeg
feed = frdeg
if frdeg > maxfrdeg, feed = maxfrdeg
#Incremental calculations
ps_inc_calc #Incremental calculations, start
xia = fmtrnd(xabs)
yia = fmtrnd(yabs)
zia = fmtrnd(zabs)
xinc = vsub (xia, prv_xia)
ps_cinc_calc
ps_cinc_calc #Incremental calculations, start rotary
cia = fmtrnd(cabs)
cinc = cia - prv_cia
pe_inc_calc #Incremental calculations, end
prvcabs = fmtrnd(cabs) #Avoid updating until called explicitly
!xia, !yia, !zia, !cia
!x, !y, !z
# G10 tool offset (L11) preloads & cancel write, read, output routines
#This section is designed to allow the user to output the many different G10 L10 - L13
#Tool offset settings for preload and cancel. By default the L11 is supportted but can
#be replaced or additional L output can be added. Additional variable data can be written to
#The buffer and extracted from it. If you do not know how to use buffers, please contact your
#Mastercam dealer or CNC Software's post Department
wc3 : 1 #Initial count for write buffer 3
rc3 : 1 #Initial count for read buffer 3
size3 : 0 #Buffer 3 size
fmt P 4 offset3 #Buffer 3
offsetn : 0 #Next buffer variables
fbuf 3 0 1 0 #Buffer 3 definintion
preloadtloff #Read tool offset buffer and write to NC file
#This postblock is called from the PSOF and PEOF postblocks and only if the use_g10tloff flag is on.
#This postblock is responsible for reading the tool offset buffer and outputting the preloads or cancel
#to the NC output file.
pg10sortl12
rc3 = 1
size3 = rbuf (3, 0)
"G90", e
while rc3 <= size3,
offset3 = rbuf (3, rc3)
pbld, n, sgabsinc, "G10", "L11", *offset3, "R0", e
pg10sortl12 #Sort preload work offsets in accending order
#This postblock is designed to sort the tloffno preload buffer in accending order. This postblock is called
#from the preloadtloff postblock. DO NOT MODIFY this post block unless you are absolutely sure of what you
#are doing.
rc3 = 1
size3 = rbuf (3, 0)
cnt1 = 1 #intialize counters
cnt2 = 1 #intialize counters
while cnt1 < size3, #loop 1 - loop 1 time less than the size of the buffer
size3 = rbuf (3, 0)
while cnt2 <= size3 - cnt1, #loop 2 - loop 1 less every time
rc3 = cnt2 #set buffer read counter to current loop counter value (Current record to read)
offset3 = rbuf (3, rc3) #Read current and next record from buffer
offsetn = rbuf (3, rc3)
if offsetn < offset3, #Check and swap records if next offset is less than current
wc3 = cnt2 #initalize write counter to current loop counter value (current record to write)
offsetn = wbuf (3, wc3) #Swap records by writing back into buffer. Next into current, current into next
offset3 = wbuf (3, wc3)
cnt2 = cnt2 + 1 #increment loop counter 2
cnt2 = 1 #Reset loop counter 2 to start at record 1
cnt1 = cnt1 + 1 #increment loop counter 1
pg10tloff_writbuf #Buffer 2 works offset preload buffer
#This postblock is called from pwrtt and only if the use_g10tloff variable is on.
#This postblock is designed to write out the tool offsetinformation to buffer 3 the
#preload buffer. The preload buffer will be scanned and checked to see if the tloffno was already
#written to the buffer, if not the wcs is written to the buffer.
test = 0
size3 = rbuf(3, 0) #Get size of buffer
#read buffer and compare current tloffno value with one read from buffer.
#If current tloffno matches one already in buffer set flag to not process.
while rc3 <= size3,
if tloffno = offset3, test = 1
#If tloffno doesn't match one in the buffer, write it to the buffer
if test = 0,
offset3 = tloffno
rc3 = 1 #reset read counter for next pass
# G10 work offset preloads write, sort, read, output routines
#This section is designed to write the work offsets preloads to a buffer file, then sort them
#into accesding order and eventually output the preloads to the NC output files. These sections
#only get called if the use_g10wcs flag is on.
# Work offset preload buffer
test : 0 #Result variable
cnt1 : 0 #Loop counter number 1 for sort
cnt2 : 0 #Loop counter number 2 for sort
wc2 : 1 #Initial count for write buffer 2
rc2 : 1 #Initial count for read buffer 2
size2 : 0 #Buffer 2 size
toz3 = toz2 - 26.378 #Figures Z Offset from machine zero
toy3 = toy2 - 25.1969 #Figures Y Offset from machine zero
fmt W 4 workofs2 #Buffer 2
fmt P 4 pofs2 #Buffer 2
fmt X 2 tox2 #Buffer 2
fmt Y 2 toy2 #Buffer 2
fmt Z 2 toz2 #Buffer 2
fmt B 2 cout2 #Buffer 2
fmt Z 2 toz3 #Writes Z Offset from machine zero
fmt Y 2 toy3 #Buffer 2 Offset from machine zero
workofsn : 0 #Temporary data for swap in buffer2
pofsn : 0 #Temporary data for swap in buffer2
toxn : 0 #Temporary data for swap in buffer2
toyn : 0 #Temporary data for swap in buffer2
tozn : 0 #Temporary data for swap in buffer2
coutn : 0 #Temporary data for swap in buffer2
fbuf 2 1 6 0 #Buffer 2
preloadwcs #Output G10 preloads from Buffer2
#This postblock is called from the PSOF postblock and is designed to output the WCS
#preloads to the beggining of the NC output file and only if the use_g10wcs flag is active.
pg10sort #Sort preload buffer in accesnding order before output
#read preload buffer and output preloads
rc2 = 1
size2 = rbuf (two, 0)
while rc2 <= size2,
workofs2 = rbuf (two, rc2)
if workofs2 > 53, pbld, n, sgabsinc, "G10", "L2", *pofs2, *tox2, *toy3, *toz3, *cout2, e #Offsets G54 - G59
else, pbld, n, sgabsinc, "G10", "L20", *pofs2, *tox2, *toy3, *toz3, *cout2, e #Extended offsets g54.1 P1 - P48
pg10sort #Sort preload work offsets in accending order
#This postblock is designed to sort the wcs preload buffer in accending order. This postblock is called
#from the preloadwcs postblock. DO NOT MODIFY this post block unless you are absolutely sure of what you
#are doing.
rc2 = 1
while cnt1 < size2, #loop 1 - loop 1 time less than the size of the buffer
while cnt2 <= size2 - cnt1, #loop 2 - loop 1 less every time
rc2 = cnt2 #set buffer read counter to current loop counter value (Current record to read)
workofs2 = rbuf (two, rc2) #Read current and next record from buffer
workofsn = rbuf (two, rc2)
if workofsn < workofs2, #Check and swap records if next offset is less than current
wc2 = cnt2 #initalize write counter to current loop counter value (current record to write)
workofsn = wbuf (two, wc2) #Swap records by writing back into buffer. Next into current, current into next
workofs2 = wbuf (two, wc2)
pg10wcs_writbuf #Buffer 2 works offset preload buffer
#This postblock is called from pwrtt and only if the use_g10wcs flag is active.
#This postblock is designed to write out the WCS and tool origin information to the
#preload buffer. The preload buffer will be scanned and checked to see if the WCS was already
test = 0
size2 = rbuf(2, 0) #Get size of buffer
#read buffer and compare current workofs value with one read from buffer.
#If current workofs matches one already in buffer set flag to not process.
while rc2 <= size2,
workofs2 = rbuf (2, rc2)
if workofs = workofs2, test = 1
#If workofs doesn't match one in the buffer, write it to the buffer
# with the P value and tool origin.
if test = 0,
cout2 = atan2 (m7, -m8)
workofs2 = workofs
pofs2 = workofs - 53
if workofs2 < 54, pofs2 = workofs #Extened offsets P1 - P48
tox2 = tox
toy2 = toy
toz2 = toz
# cout2 = cout
workofs2 = wbuf (2, wc2)
rc2 = 1 #reset read counter for next pass
pwrtt #Buffer toolchange information
# Call to save work offset and tool origin to buffer for output at SOF.
if use_g10wcs = yes, pg10wcs_writbuf
if use_g10tloff = yes & opcode <> 3, pg10tloff_writbuf #don't output for drilling tools
# Numbered questions for Mastercam Version 8
38. Rapid feedrate? 1187.0
76. Name of associated CFG file?
400. Name of associated CFG file?
1538. Rapid feedrate (metric)? 10000.0
#76. Configuration file name?
80. Communications port number for receive and transmit (1 or 2) ? 2
81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 19200
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 2
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name? RPFAN
100. Number of places BEFORE the decimal point for sequence numbers? 3
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 14000
107. Average time for tool change (seconds)? .8
#110. Default tool library? TOOLS.TL8
159. Compensate the first and last point in cutter comp. in control simulation? y
160. Display first and last entity in toolpath when simulating cutter compensation in control? y
161. Enable Home Position button? y
162. Enable Reference Point button? y
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? y
165. Enable Tool Plane button? y
166. Enable Construction Plane button? y
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? y
# Default Miscellaneous Real Values
201. Default miscellaneous real variable 1 (mr1)? 0.0
202. Default miscellaneous real variable 2 (mr2)? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Work Coordinates [0-1=G92, 2=G54's] (mi1)? 2
302. Absolute or Incremental [0=ABS, 1=INC] (mi2)? 0
303. Reference Return [0=G28, 1=G30] (mi3)? 1
304. Miscellaneous integer variable 4 (mi4)? 0
305. Miscellaneous integer variable 5 (mi5)? 0
306. Miscellaneous integer variable 6 (mi6)? 0
307. Miscellaneous integer variable 7 (mi7)? 0
308. Miscellaneous integer variable 8 (mi8)? 0
309. Miscellaneous integer variable 9 (mi9)? 0
310. Miscellaneous integer variable 10 (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? n
1503. Write transform operations (0=transform ops, 1=source ops, 2=both)? 1
1520. Display a warning when cutter compensation in control simulation finds an error? n
1521. Number of controller look-ahead blocks for CDC in control? 2
1530. Ignore work offset numbers when processing subprograms? y
1531. Ignore contour flags when processing subprograms? y
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
3001. Machine acceleration? 2
3002. timing size? .1
David, somewhere on Jays ftp site is a zip file called vertical_G10.zip which contains a V9 post and text file and a sample mc9 file to try it out. It is setup for a vertical but that is just a switch in the post to switch it to horizontal. This post creates a G10 list at the top of the file, not really what you want. I beleive without too much post editing it could be made to do what you want. Turn off the list at the top of the file and then read the buffer at the start of each sub. Without actually doing it I don't know how long it would take but I beleive it should be doable.
  • 18 years later...
12 hours ago, mahesh kumbhar said:
How to use i, j, k while using G10 programming, and also meaning of W which is used.
Ex. G0G90G10L20X500. 0Y500.0Z500.0
     G0G91W1I5. 0J20.0K100.0
They are not even related. The example given is using G10 and the line shown doesn't have G10. Without knowing exactly what you are trying to accomplish that is like reading Greek translated by a Japanese person then converted to German and given back as English.
In other words give us something to help you with. What and where are you needing to change the machine? What purpose will it serve and how will it help you accomplish automation and time reduction by implementing this change to the machine? The topic was referring to outputting the Work Offsets for a machine from the CAM file. How does what you want to do relate? Context? Background? Something beside throwing darts at a dart board blindfolded, facing the wrong direction in a different country trying to hit the board.
