G76 Bore shift question - Mori Seiki with Fanuc control
I am trying to use a G76 with a shift at the bottom of a bore but getting the tool to line up properly and then getting movement in the correct direction seems to be an issue.
This is something I don't normally use so I am kind of at a loss as to how it's supposed to actually function.
G76 Z-.502 Q.01 R.1 F5.0
What am I missing?
I dont know if its comparable but in quick code in the Haas.
It asks me for a G98, or a G99 first.
G98 is "CANNED CYCLE INITIAL POINT RETURN"
and G99 is "CANNED CYCLE R PLANE RETURN".
after filling out quick code it shows the line formatt like this
G76 G99 Z-.502 Q..01 R.1 F5.
Dont know if this helps you much.
I do have those set as you describe Tim.
Is there a way to get your machine to stop in a certain position so that the y move is actually off the bore wall.?
I'm using a boring head so I cannot change the positioning of the tool but it stops out of position for the y move, thus gougues the wall.
I-.01 will shift -.01" in "X"
J-.01 will shift -.01" in "Y"
The critical thing is you must set the tool tip at a quadrant in your spindle, then use the shift variable of "I" or "J" using a positive or negative shift.
PS. Some controls allow a shift amount and direction within a parameter setting.
Regards, Jack
John, I doubt I J will work with fanuc on a mori.
Your code looks good, here is my sample for a mori:
G76 G98 X... Y... Z-... R.1 Q.005 F1.
+1
It's a must on our moris.
And if it still doesn't work, foolow up on Tim's suggestion and make sure parameters are correct.
another alternative is to us M19 to orient the spindle, feed using G1 moves and a shift on the proper axis depending on the shift direction within the control, also check that your bar is set correctly in the cat holder, the dimple in the cat holder, if set wrong the bar will shift in the wrong direction and scratch the bore coming out
mtc
