Okuma Spindle Tool Fix
Greg Williams
Hi All,
For those with Okuma mills, Below is the fix for the spindle tool commanded in program error. This fix will work for U100 E100 and P200 machines. It may also work on older ones but O have not tried them.
Ok, Save the following text as tool.lib
OTCK (GET NOMINATED TOOL)
IF [PT EQ EMPTY] NERR
IF [PT EQ VTLCN] NEND
IF [PT EQ VNTOL] NM6
IF [VNTOL EQ 0] NCT
M64
NCT T=PT
NM6 M6
NEND G56 H=PT D=PT
GOTO NRTS
NERR M63
M6
NRTS RTS
ONOT1(M201)
M63
M329
M06
RTS
ONOT2(M202)
M64
M63
M329
M06
RTS
Copy this tool.lib file to MD1 directory of the machine.
If the buffer has been set large enough all will be sweet, If not you will need to initalize the buffer and reset it to a binary number (say 4800)
If in doubt miss this step
Turn off all power
Restart Machine - Note if there are any lib registration errors, If there are none all is good if there are *lib errors see previous step
Go to Parameters G and M codes
Next to G116 set OTCK
Save, Yes very important
On a new P200 control you will need to register the *.lib file. From Run mode, press extend then Register lib files
OK now G code needs to look like this
Blah Blah
G116 T4
G00 X0 Y0 Blah Blah
So if T4 is in the spindle the program will continue with no errors if not the machine will go and get T4 then continue. This will also work thru DNC-DT
  • 8 years later...
Hi All,
IF [VNTOL EQ 0] NCT
M64
NCT T=PT
NM6 M6
NEND G56 H=PT D=PT
GOTO NRTS
NERR M63
M6
NRTS RTS
ONOT1(M201)
M63
M329
M06
RTS
ONOT2(M202)
M64
M63
M329
M06
RTS
Turn off all power
Blah Blah
G116 T4
G00 X0 Y0 Blah Blah
Hope this helps someone graemlins/cheers.gif
For P300 machines change the VNTOL to VTLCN. It will eliminate alarms if the tool is designated as heavy or large tool. It also will address alarms with tool numbers greater than 999.
