Roger Peterson
Benchmark
1,633 posts in this topic
Same part but Metric with same converted tolerance 0.0025mm
Time 5 minutes
CPU Intel Core2 E6600
RAM 2Gb
Win XP
turned Hyperthreading OFF and it reduced the time from 30 min 50 sec down to 29 min 30 sec. I'm hoping for a 25 minute reduction! Any other sugestions! I guess it must have something to do with the vpn connection?
If someone could send me the file, I'd like try it on an AMD laptop, and an Intel desktop.
For some reason, the server on the Mcam support site shuts off when the samples are only halfway downloaded.. ??
thanks in advance..
Steve
svp2@netpipe.com
9.5 minutes
System Manufacturer: Dell Inc.
System Model: Precision M65 Laptop
Processor: Intel® Core2 CPU T7200 @ 2.00GHz (2 CPUs)
Memory: 2046MB RAM
Card name: NVIDIA Quadro FX 350M
Manufacturer: NVIDIA
I used to have a M70, but th M65 is much faster as it is dual core.
7min 59 sec
HP nw9440 Mobile Workstation,
Intel Core 2 Duo Processor
T7400, 2.16GHz, with Centrino
Technology, 2GB RAM,
6 min 40 sec
Home made (assembled) computer
Intel Duo Core 2.66
Windows XP Pro
2 Gb ram
I guess the new computer was well worth it :-)
6 min 7 sec
Dell Precision 390
Intel Core 2 X6800 @ 2.93GHZ
4 Gig of RAM
Nvidia Quadro FX4500
XP Pro SP2
9 MIN 05 SEC
Dell Precision 470
Dual Xeons,3.2 GHZ
2GB ram
Windows XP pro
Nvidia Quadro fx1300
14min 30sec
Dell M60 Laptop
Intel Pentium M processor, 1.7GHz
1.5GB RAM
Quadro FX Go1000 graphics card
Display surface/plane intersections: ON
other aps were running during test
9:02
Dell M65 notebook
Intel Core 2 Duo, 2 GHz
2 GB RAM @ 1.99 GHz
Windows XP
I shut down Outlook, iTunes, and other memory hogs.
In our benchmarks the M70 and M65 are pretty close. Some toolpaths - like Parallel seem to be faster on the M65. They have better graphics cards, so when the toolpath includes showing graphics during the calculations, they are faster on the M65, otherwise equivalent.
Online Stopwatch - http://tools.arantius.com/stopwatch
How many of you guys posting these 5 minute times reran the benchmark to get these low times? The last time we went through one of these benchmark deals, it was found that if you run it a second time it was a lot faster because everything was in the cache.
I can't believe that there is such a difference in these times, with the computers being so close in spec. There is no reason for the xeons to be twice as fast with a program like Mastercam that doesn't take advantage of dual processors. They do have a little more cache on the chip, but this isn't really proving anything....
Craig
Just for grins, those with INTEL and HT turned on, try turning Hyperthreading OFF and re-run the test.
MC locks up at different times, while changing the
total tol 1st time. I almost got to hit the regen before it locked on me the 2nd time.
Turning it back on, no problems.
Did this happen to anyone who tried this?
Rick
I dont know about anyone else but I regenerated only 1 time.Did exactly what Roger described.
It was just over 6 mins.
I didn't want to sound like I was accusing anyone of "cheating", but obviously all things are not equal when 2 machines with almost the same specs can be so different...
11:08.
Obviously, I have some tweaking to do. Thankfully, I would never process a Core Rough at .0001 tolerance.
Mastercam can't use the dual core, but the computer can. The dual core frees up proccessing
power because WinDoze and all the computer overhead can run on one proccessor freeing up the other one to crunch Mastercam.
The evidence is pretty clear. Dual core pentiums
are beating single core pentiums and single core Xeons. Dual core Xeons are smoking everything.
It would be interesting to see what kinds of times
a quad core Xeon would produce.
My rule of thumb is to use 10% of the stock to leave
.02 stock .002 tol(rough)
.01 stock .001 tol etc
0 stock .0003 tol is my max
gcode, there are some xeons with 11 minute times too...
I have a dual xeon also, so i'm not biased really
Did someone put this up on the FTP? I don't really want to load all the mill samples just to do this test.
THX
they are single core Xeon's
12min 7sec(1st pass) not bad for less than $1000system
Autosave was on at 7min interval so it saved once durring test. Also running Ramsaver Pro.
OS Name Microsoft Windows XP Professional
Processor x86 Family 15 Model 7 Stepping 10 AuthenticAMD ~2010 Mhz
Mother Board ASUS A8N-SLI DELUXE ACPI BIOS Revision 1002, 11/26/2004
Total Physical Memory 2,048.00 MB
Available Physical Memory 1.43 GB
NVIDIA GeForce 6600 256mb x 2 SLI
For S&Giggles, I turned the Affinity on Mastercam.exe to CP1 only, and set the Priority to Realtime.
when from 9:02 down to 8:35
Dell M65 notebook
2 GB RAM @ 1.99 GHz
Are you supposed to leave the filter off and just change the tolerance to 0.0001?
If so, mine was:
9min 43sec
Amd Athlon 64 3500 2.2Ghz
3gb ram
Nvidia 7600 GS
XP pro
