Benchmark
Roger Peterson
Colin, That would be a wallet flatening tool. While it would be cool - I think I would be consigned to a deep, dark, cold place for a substantial time.
The Hyperdrive4 would get me there - at ONLY $2400 for 16gb.
I'll pass for now.
Bogusmill - go to http://www.cpuid.com and get PCWizard2007 - double check your temp. I just emailed my stepson and his OC'd from 2.4 to 3.4ghz runs at 72C (161F) with a high end cooling system with extra fans, etc.
My OC'd FX-60 idles at 39C but under load hit 60C (about 140) in short order. My laptop (lap heater) Idles near 70C and with V9 (CPU HOG) hits 85C in about 3 minutes (That is 185F).
  • 3 weeks later...
Not sure what you mean? When I got my 5 min. 4 sec. time on the benchmark I opened the .MCX file, changed the tolerance to .0001 on all three toolpaths, selected all three, hit regen and started timing.
I used inches, the metric times always seem faster. I had just loaded MCX2 so I hadn't changed any settings. But I don't understand what 1 to 1 or 3 to 1 is.
Ok I go 5min 2 sec on my new box.
XP pro
Extream core2 2.93 over clocked to 3.4
4 gigs a ram
Quadro fx 4500
Dual 24" monitors
This was tested out for over a week with my IT team before releasing to me on the floor about to build 2 more.
Temp stays cool and seems to be really stable and fast.
Great time, 4sec. faster than my home built. You have twice the RAM, and a 9% overclock. What did the box cost? I think your video card cost more my whole PC.
Your FSB is probably close to 300MHz, mine is 500MHz, an 87% overclock. My FSB is probably making up for your having twice the RAM. I have 1 10,000 RPM HD but it's not yet installed. When I get the second and they are in a RAID 0 array I'll run the bench again, see if I can regain the speed lead.
[ 08-16-2007, 12:55 PM: Message edited by: bogusmill ]
Bogus I to have the 160 gig Rapter 10,000 drive in there.
We did do before this one a 2.13 core2 and clocked to 3.5 and it did well but the extrem core makes the clocking easer and less stress on the core.
They want me to play for a few weeks keep an eye on the dempature if all goes well they want to try taking higher and testing.
I will check on the FSB as I do not remember what it was set for and I will check on the MB who makes it.
I know it was not to cheap the Extreme core was about $800 and the 650watt power supply was close to $200. Then there is the Lian all alum case that was about $100. just some of What I know.
the ram is the 800 were they did not go with the 1066 that it supports.
Cadcam,
Mine is a C2D E6320. Stock speed is 1.86GHz, thats a 7X multiplier and 266MHz front side bus. 7 x 266 = 1862
Now at 500Mhz FSB my processor is about topped out at 3.5GHZ but yours should be able to reach 3.8-4.2GHz. You'll need good RAM and CPU cooler. I think your multiplier is unlocked and at 11X so if it will run at 12X you should have 3.7GHz. I have my vcore at 1.512 volts and still dont break 130 degrees, I use a 580W power supply, Shark aluminum case with plenty of fans, and Crucial PC8500 RAM. Would cost about $1600 to duplicate today. Wouldn't you know it, right after I completed building it, there is a new chipset out and quad core just got faster and cheaper. Might build another new machine. Any one interested in an ex-record holder.
The FSB is clocked at 1250 and it runs at 50c all day and peekes during extreame crunching to a hi of 57c. the mother board is EVGA680I the Core is a X6800. we have it like you set on lite side of 3.4 and looking after a while of boosting.
PS I see I said 3.5 ealer that was the Core2 duo 2.13 we were playing with upstairs in IT.This one is at 3.4 right now.
the CPU cooler is huge and a speacial buy to do exactly what we wanted to keep it cool.
We are ordering a Quad Core to play with next.
Something is wrong with your FSB number. You have a default multiplier of 11.
11 X 1250 = 13.75GHz
Evga 680i is a very good board. My air cooler barely fits the case and I put 2 120mm fans on in push pull arrangement. I've never broken 54c with CPU using this set up. Research your quad core. There is a couple of new ones out that run faster, cooler, and draw less power.
Would have guessed 309 so I got close. Won't be doing quad core, at least not on this board. If you do I'll bet you slowdown. I might try Xenon core 2 though. Loading a Raptor this weekend to see if that helps. A second one in RAID 0 a payday or 2 later and try again. Keep your eye on heat. 680i MB's run hot.
