Benchmark
Roger Peterson
Like I said previously, all the people who run this benchmark in metric get better times than those that use inches. Anyone's bench time in metric doesn't compare. I don't know the difference % wise so it's an apples to oranges comparison. The 4GB of RAM is showing up often in the faster times.
cheers.gif Rickster
I use a few different pc's during the course of a week. And I do have to say that haveing the right (or the wrong) pc makes a huge difference in getting through the day. We've had times from under 5 minutes, all the way up to 30 minutes, that is a GINORMOUS difference. There seems to be a lot around the 10 to 11 or 12 minute mark, and with the right pc you can drop that down to 5 or 6 minutes, cutting your calculation time in half. It appears the new dual xeons are king, but the core 2 duo's do very nice job at what would be a significant price drop from the xeons. Would any of you "faster" folk mind reposting your speed and approx purchase price?
My shop laptop.
Dell M90, 2.16G Core 2 duo, 2GB RAM,Quadro FX 2500M.
8Min. 5sec.
$3300
My homebuilt.
Asus P5B-Deluxe 1.86G core 2 duo OC'd to run at 3.5G, 2 GB RAM, Gefroce FX 8800 GTS-320.
5min. 6sec.
$1500
My work PC.
Dell Precision 380, 3.2G Pentium D,2GB RAM, Quadro FX 3450
11min. 10sec.
$2750
Now I have tried the new file (inch), this gave me another time, our main system
Asus P5D MB
4GB ram
Intel core 2 duo 6700 2.66Ghz
8800GTS video card
Mastercam X2 MR1 sp1
Our second pc system
Dell Dimension 5000
1GB ram
P4 2.8Ghz
Mastercam X2 sp1
No re-test, If willing just post your time and approx $$$ spent. I just want to see the correlation between $$$ and calculation time. I know the core 2 duo units will be less than the xeons. For many, the price may be well worth it.
Thanks!
Hey bogusmill what nvidia driver version are you running on the M90? Did you change any settings?
Thanks again!
Well I know this benchmark well by now and I know this is a Mastercam benchmark but I thought I would compare the numbers in SolidCAM2007R11, which also uses Vero's "Machining Stratigist" engine. Note SolidCAM has been using this the Vero core for its HSM longer that what Mastercam has.
machining STRATEGIST
Mastercam X2 SP1:
Desktop
Pentium 4 3.06GHz
XP Pro
2GB Ram
SolidCAM 2007 R11:
Desktop
Pentium 4 3.06GHz
XP Pro
2GB Ram
Note: When I benchmarked the time for SolidCAM I was also running Mastercam,Outlook as well as other various applications.
Whats With That!
Roger,
We remove the Dell crapeware filled OS, format the hard drive and load WinXP Pro. Then the latest drivers, in this case 84.29. I have the unified back/depth buffer turned off and antialiasing set to application controlled and I use default resolution of 1920 X 1200. Getting rid of the Dell installed OS is the single most important part of how well this laptop runs.
Keith, I have noticed the same thing using Cimco HSM. Similar toolpaths calculate in 1/4 the time. Masterecam claims its because they use a higher resolution modle, but that doesn''t sound like it would account for that big a difference...
In the meantime, I mildly overclocked my junkyard computer and got a 5m 41s time, down from 7m31s stock, so big gains can be had easily if your motherboard allows overclocking.
Bogusmill has the same cpu, but has more aggressively OC'd his machine to get down to 5m even. I am not knowledgeable enough to push mine that far...
My laptop and home PC both have Core 2 Duo CPU's and they are 3 minutes apart. I havent tested the Asus at 1.86. They have the same RAM size and 16X video cards. Asus has the Intel P965 chipset, M90 is Intel 945. So except for the CPU (and FSB) difference they are pretty equal.
The laptop runs at 2.16GHz and the Asus at 3.49. So 2.16 is 62% of 3.49 and 5min. 6sec. is 63% of 8min. 5sec. Thats pretty good scaling, hope my math is right.
Another interesting thing is that the video on both are great but in the 3DMark06 video benchmark the Quadro FX 2500M scored 4743 and my Geforce 8800GTS scored 10533!
Quote: I am curious, without reading ALL 5 + pages of this if someone could "summarize"
What desktop, CPU, memory, vid card, HD config seems to work exceedingly well.
Right now a pair of Asus P5B-D's with Core 2 Duo CPU's and GeForce 8800GTS video cards are neck and neck and way out in front of the rest of the pack.
FYI,
I had a 10 minute calculation time on this file.
With a few "minor" changes, including using a .stl file instead of the solid and a linking parameter change I can bring my calculation time to under 3 minutes on the same part at the same .0001" tolerance. Don't forget to add my stl export tolerance of .0002 to that. Many softwares work off of stl files for just this reason, speed. If you are willing to put up with the pitfalls inherant to stl files you can do so in mastercam also. Me, I'll wait for the surface data to be calculated.
Seems like some of you may have missed the reason behind using this file as a benchmark. It's a rather large toolpath to regenerate and if everyone listing a time to regen runs the EXACT same toolpath you can find out if your PC runs as fast or slow as you think is does.
What good is it to run a different file (.stl) or run it as metric? The sample is in the inches folder but the metric file runs about 15-20% faster. How can it help you or anyone to compare or post a regen. time for a toolpath that's not what everyone else is using? Instead of running some alternate file why not impress us by finding a setting that every mastercam user can use to make the EXACT same file come in with a better time. That would be valuable information to everyone posting here.
