Creating a custom cutter in X
mike561h
draw the radius profile of the tool(do not draw a line on zero to connect the profiles leave it open) on a new level or MCX file
select a woodruff cutter and on the bottom of the tool definition page you will see 3 options for the custom tool / auto / custom file / custom level /select what you need and you should see the profile in the view area
Draw a half profile of your custom tool to actual size.
It can be on a level in your file or a stand alone mcx file.
Create a new tool.. choose "undefined" as the type. Set the level number or navigate to the
defining mcx file.
The outline of your new tool will apear in the window.
On the parameters page set the diameter.
If the tool has a corner radius be sure to set it
in the corner radius field.
Use the tool as you normally would
It will backplot, verify and post properly.
  • 1 year later...
Mike, a good percentage of my milling tools are "custom", if you look at the help files you are instructed to only have arcs or lines, and have it as undefined, you also need to define the dia correctly for it to visually verify.
I use these tools for rough profiling screw compressors, and have found no problems with the profile/shape they produce ( i rough the profile to around .5/.6mm from finished), and have found no problem with the shape produced.
I verify and save the STL file and use this to compare against a designed shape
  • 3 weeks later...
defining mcx file.
I also use custom tools to cut inside and outside threads in mould forms (closures, caps, shoulders...)
I have an additional question:
The cetters are always shown in backplot but NOT always in verify.
So I can not always compare stl with the actual form of thread.
Whay is that. I draw the profile in the separate mcx file, on x0.y0.z0
questions:
do you draw a centerline of the tool?
do you connect the bottom of the cutter with x0.y0.z0?
do you save the file in the same folder with toolpath or in mcamx/mill/tools...?
do you draw a cutter in the samo file on a different layer?
