peck tapping
Go Navy
For our Fanuc controls, we had to add *peck1$ and place it before the feed in the ptap canned cycle.
This outputs a Q0 by default which the fanuc control is ok with.
If (for example) you select a 4. in the mcam dialogue box, it then outputs a Q4. for the peck amount.
If I HAVE to tap, I ALWAYS peck tap. It may not be reccommended (which I've not heard btw) but I've not broken a tap since changing to this method.
But an answer te question, like was stated earlier, add *peck1$, to the ptap postblock, then search down near the bottom of the post and change the following;
[tap]
1. "G84/G74 -Peck Tap"
3. ""
7. "Peck" <<<<<
8. ""
9. ""
10. ""
11. ""
[drill cycle descriptions]
1. "G81/G82 - Drill/Counterbore"
2. "G83 - Peck Drill"
3. "G73 - Chip Break"
4. "G84/G74 - Peck Rigid Tap" <<<<<<<
5. "G85/G89 - Bore (feed out)"
6. "G86 - Bore (stop, rapid out)"
7. "G76 - Fine Bore (shift)"
You may have several places to change [tap] but change them all.
[hijack] Threadmilling RULES! [/hijack] biggrin.gif
For this to work on a Haas you need to specify a different depth on each line for each hole. For example (and I'm just winging this):
X1.0 Y1.0 Z-.2
Z-.4
Z-.6
Z-.8
X2.0 Y2.0 Z-.2
Z-.4
z-.6
Z-.8
I asked my reseller to modify my post to support this and it works great. If the "peck" value on the parameters page is 0 then there is no peck. If I put a .2 value then it will peck in .200" increments. Maybe talk to your reseller and see if they can modify your post also, or maybe they can ask In-House for the changes they made.
FWIW, I don't see why Haas couldn't have made this as easy as adding a "Q" value to the tapping line a la Fanuc.....I could rant, but I'll quit while I'm ahead!
Here is John Paris' peck tapping (Thanks John!) with a slight modification for a Haas machine.
This will output "G84", "Z" and "R" on each line.
Sorry, I'm not at work so I can't post the output.
# ADDED FORMATS FOR PECK TAPPING CYCLE
fmt 4 count # timing counter
fmt 4 peck_cnt #remaining no. of pecks
fmt 4 numpeck # No. of pecks
fmt 4 pass # pass counter use to calculate depths
fmt Z 2 sub_depth #subsequent depths
fmt Z 2 calc_depth # The total caculated cutting depth
fmt Z 2 calc_peck # the calculated peck amount
fmt Z 2 strt_depth # the first tap depth
fmt Z 2 initial_calc # calculate the initial depth cut
fmt 3 stepeck #Inital step peck down increment from top of stock
pdrlcst$ #Custom drill cycles 8 - 19 (user option)
if drillcyc$ = 13,
numpeck = peck2$,
stepeck = peck1$,
if stepeck = 0,
peck_cnt = numpeck
initial_calc = (depth$ - tosz$) / peck_cnt
strt_depth = (tosz$ + initial_calc)
calc_depth = (depth$ - tosz$)
calc_peck = calc_depth / numpeck
"(PECK TAPPING CYCLE)", e$
pcan1, pbld, n$, *sgdrlref, *sg84, pdrlxy, *strt_depth, pcout, prdrlout, *feed, strcantext, e$
count = peck_cnt - 1
else,
peck_cnt = numpeck
strt_depth = (tosz$ + stepeck)
calc_depth = (depth$ - (tosz$ + stepeck))
count = peck_cnt
pass = 1
WHILE count > 1,
sub_depth = strt_depth + (calc_peck * pass)
pbld, n$, *sg84, *sub_depth, *refht_a, e$
pass = pass + 1
count = count - 1
pbld, n$, sg84, pfzout, *refht_a, e$
pcom_movea
pdrlcst_2$ #Custom drill cycles 8 - 19, additional points (user option)
if drillcyc$ = 13,
numpeck = peck2$,
stepeck = peck1$,
if stepeck = 0,
peck_cnt = numpeck
pcan1, pbld, n$, *sgdrlref, *sg84, pdrlxy, pfxout, pfyout, pcout, *strt_depth, *prdrlout, *refht_a, *feed, strcantext, e$
else,
peck_cnt = numpeck
count = peck_cnt
pass = 1
WHILE count > 1,
pass = pass + 1
count = count - 1
pcom_movea
[drill cycle 14]
1. "Peck Tap cycle"
2. ""
3. ""
4. ""
5. ""
6. ""
7. "INC. 1st Step from TOS"
8. "# of PECKS"
9. ""
10. ""
11. ""
[ 05-29-2009, 08:34 PM: Message edited by: mgsanchez ]
Both my Emuge and Guhring reps state not to peck tap since it causes chips to jam and break the tap. Ever since I started listening to that statement, we have not broken taps in our shop unless a freak situation. The right cutting parameters and coolant play a big role.
For cut taps, find what works for you but we have had great results 3xD deep no peck in materials up to 45 RC.
Forming, no reason whatsoever to peck.
Honestly..... If you are using the correct type of tap, lube, and cut parameters, you shouldn't need to peck tap. smile.gif
Maybe an M00 to use better lube - moly dee for most tough stuff.
As for the "jam up" this is true for blind holes if you are using a gun or plug tap, rather than a spiral tap.
I have used peck tapping in the past, for blind holes with a gun tap, but I added a retract and M00 to remove the chips between subsequent pecks.
For all of you who are thinking spiral taps are weak and most likely to break, think again, Hypro Exotaps rule.
No prob tapping Hast-X, Inconel, Invar, Nimonic...you name it 5x dia deep. smile.gif
BTW. Don't forget to put minor dia at max for tough materials like these.
JP - Great post work....I'll have to add that to my custom drill cycles.
[ 05-29-2009, 09:43 PM: Message edited by: MastercamGuru ]
...it must cost alot of cash a year for peck tapping...
Depends on a lot of factors. You can't roll tap every material. How much does a scrapped part cost?
...James, face it, you don't know what you're talking about....
Actually I don't know $#!+ from shinola, I just stayed at a Holiday Inn Express every night for the last 17 years, oh, and saved a bundle on my car insurance while I was at it. rolleyes.gif
If y'all haven't figured it out by now, there are numerous ways to skin a cat and each of us have a method to our madness and reasons for doing what we do.
JM2C
35K - Undercut (Neck) the shank or have Harvey do it for you.
Re: ??.390??
You did say .350 deep, right?
A 1/4" Diamond wheel + .125 LOC = .375 LOR (one plunge cut)
.390 leaves a little room for clearance and the lead of the threadmill.
To get .350 deep you usually have to go .350 + the pitch(.0179) to get full thread depth.
You could neck the single form threadmill as well. Either one will do the trick.
[ 06-04-2009, 02:15 PM: Message edited by: MastercamGuru ]
