MPLMaster editing question
nofalloff
About a year ago with the help of Ron and others here I edited a copy of MPLmaster to work with an old Sinumerik 810T lathe control. Specifically we were tweaking the threading cycles to output correctly. I've been using it for about a year with no problem till yesterday I tried to cut an ID thread and found the code was completely wrong (yes I haven't tried to cut an ID thread on this machine till now). I've been going through the post and the post guide but I'm hitting the limit of what I understand about MP programming.
The first problem I'm having is that sign of the R24 parameter value tells the control whether the thread is an ID (+) or OD (-) thread. So the thread height needs to be (major dia. - minor dia.) or vice versa depending on ID or OD. Right now all I get is a positive value. I pretty sure that this problem is not in the format statement but in how the height is calculated. I don't see how to change that in the "pre thread calculations" if that's where it need to be changed.
The next problem I'm having is the R26 which is the Z approach value is not picking up the data entered in that field in the operation in Mastercam. No matter what is entered in the operation the nc output for that parameter is always 0. The variable is lcc_zcst. Where does this pick up the value for the entered parameter in the op in MC?
I have spent hours trying to figure this out and have made no progress. Can someone please offer some advice?
peter-
Threading parameters for Sinumerik 810T
R20 = Thread pitch
R21 = Start point of thread in x
R22 = Start point of thread Z
R23 = # Spring passes
R24 = Thread Depth
R25 = Finnish pass increment
R26 = Approach distance
R27 = Run-out Distance
R28 = Number of rough passes
R29 = Infeed angle
R31 = End point Z
R32 = End point Z
L97 = Cycle call
Sample code for threading:
R20=.0769R21=.4167R22=.05R23=1R24=-.0416R25=0R26=.05R27=.05
N20 R28=3R29=0R31=.4167R32=-1.1
N30L97P1
Format statements current
# Thread output
fmt R21= 2 xmaj_thd # X major dia thread value
fmt R22= 2 zstrt_thd #Z Start
fmt R23= 4 nspring$ #Number of spring cuts
fmt R24= 3 thddepth$ #Thread height absolute
fmt Q 16 thdfirst$ #First depth cut in thread
fmt R25= 2 thdfinish$ #G76 thread finish allowance
fmt U 3 thd_dirx #Incremental X move for G76 mult starts
fmt W 3 thd_dirz #Incremental Z move for G76 mult starts
fmt R26= 2 lcc_zcst #Z Approach
fmt R27= 2 thdpulloff$ #Z runout
fmt R28= 4 thdncuts$ #number of rough cuts
fmt R29= 2 thdang #G76 threading angle
fmt R31= 2 thdrdlt #Thread R delta G92 and G76
fmt R32= 2 zend_thd # Z finish
fmt R34= 2 thdpull #G76 thread pull off
fmt R35= 4 thdlast$ #Last depth cut in thread
The post block for the threading cycle output.
pg76new #G76 threading new style
thdrdlt = xmaj_thd + abs(thdrdlt)
pbld, n$, pffr, *xmaj_thd, *zstrt_thd, *nspring$, *thddepth$, *thdfinish$, e$ #*thdpull, *thdlast$,
pbld, n$, *lcc_zcst, *thdpulloff$, *thdncuts$, *thdang, *thdrdlt, *zend_thd, e$ #pfxout, pfzout, *thdfirst$,
pbld, n$, "L97P1", e$
Some history on this here
http://www.emastercam.com/cgi-bin/ultimate...t=029886#000003
