file as remaining material
k turk
let's say that my finished part is a pyramid and i am handed a cube of material from which to cut it. i don't want to machine all that material so i go to the bandsaw and make a rough pyramid leaving half an inch of material to the finish surface.
i've created a model of the bandsawed pyramid. how would i go about using that as a file to generate a Highspeed Roughing toolpath to remove the majority of the material and avoid cutting air? i was thinking i could use a Highspeed Rest Rough approach as there is a 'Compute remaining stock from CAD File' option, but i don't see a way to browse for the file of the roughed pyramid. when generating the toolpath with this selected i get a warning 'Operation does not have STL file.'
how would i go about trying to do what i'm trying to do?
thanks
k
(i've simplified the geometry for the explanation. i know i could create planes for each face and approach it that way)
This is kind of a sloppy way to do it, but generate a simple raster or parallel toolpath across your model using a 1/4" ballnose endmill( doesn't matter what size cutter ) leaving .5 for stock to leave. Now verify this toolpath using your original block size in your stock set-up and then save this verify as your STL file. This is now the CAD file that you will generate the rest roughing toolpaths from.
