misc reals ?
dforsythe
here is what i did and the sections modified. notice all the G187 stuff. pretty easy to set up, especially when InHouse gives you such a good base to start with(thanks InHouse):
beginning of post:
mr1 - High Speed
# 0 = Off
# 1 = Advanced Preview (look-ahead) control - G08 P1
# 2 = AI-NANO 2, AI(nano)CC output (Artificial Intelligence Contour Control) - G05.1 Q1
# 3 = AI-HPCC and AI-nanoHPCC (High Precision Contour Control) - G5 P10000
# 4 = Mazak Geometry Compensation/Accuracy G61.1, Mazak High Speed Machining Mode - G05 P2
# 5 = HAAS corning
# mr2 - Accel/Decel Value (for G05.1 Q1 and G61.1 only)
# 0 = No output
# Value = Accel/Decel coefficient
# Fanuc Notes
# 0 Least Accurate
# 10 Most Accurate
# R 0-3 Roughing
# R 4-7 Medium
# R 8-10 Fine
# mr3 - HAAS Smoothing Value
# mr4 - HAAS "P" Value - P1 = Rough, P2 = Medium, P3 = Finish
phsm1_on #High speed functions before G43
if opcode$ = 3 | opcode$ = 16,
mr1$ = 0
mr2$ = 0
if mr1$ = 1 & mr1_flg <> 1, #Advanced Preview (look-ahead) control - G08 P1
pbld, n$, "G08", "P1", e$
mr1_flg = 1
if mr1$ = 2, #AI-NANO 2, AI(nano)CC output (Artificial Intelligence Contour Control) - G05.1 Q1
pbld, n$, *sg49, e$ #Must be in G49 and remain before G43
if ipr_type > 1, ipr_type = 0 #Must be in G94
pbld, n$, sgfeed, e$
pbld, n$, "G05.1", "Q1", [if mr2$, "R", no_spc$, *mr2$], e$ #Mr2 gives accel/decel value/coefficient, usually R or P
mr1_flg = 2
# HPCC is working when called before G43.4 on Fanuc 31i
# if mr1$ = 3 & mr1_flg <> 3, #AI-HPCC and AI-nanoHPCC (High Precision Contour Control) - G5 P10000
# if ipr_type > 1, ipr_type = 0 #Must be in G94
# pbld, n$, sgfeed, e$
# pbld, n$, "G05", "P10000", [if mr2$, "R", no_spc$, *mr2$], e$
# #pbld, n$, "G05.1", "Q2", e$ #auto arc filtering
# mr1_flg = 3
if mr1$ = 5 & mr1_flg <> 1, #HAAS highspeed corning - G187
pbld, n$, "G187", [if mr4$, "P", no_spc$, *mr4$], [if mr3$, "E", no_spc$, *mr3$], e$
mr1_flg = 5
phsm_off #High speed functions off
if mr1_flg = 1, #Advanced Preview (look-ahead) control - G08 P1
pbld, n$, "G08", "P0", e$
mr1_flg = 0
if mr1_flg = 2, #AI-NANO 2, AI(nano)CC output (Artificial Intelligence Contour Control) - G05.1 Q1
pbld, n$, "G05.1", "Q0", e$
mr1_flg = 0
if mr1_flg = 3, #AI-HPCC and AI-nanoHPCC (High Precision Contour Control) - G5 P10000
#pbld, n$, "G05.1", "Q0", e$ #auto arc filtering
pbld, n$, "G05", "P0", e$
mr1_flg = 0
if mr1_flg = 4, #Mazak Geometry Compensation/Accuracy G61.1, Mazak High Speed Machining Mode - G05 P2
pbld, n$, "G64", e$
mr1_flg = 0
convert_rpd$ = prv_convert_rpd$ #Mazak Fusion requires high feed motion only, comment out for Matrix
if mr1_flg = 5, #HAAS Smoothing
pbld, n$, "G187", e$
mr1_flg = 0
Damian - To answer your question, mr3$ needs to be formatted.
Look at the fs2 statements for the proper output format.
fmt 4 P mr2$ #G187 P Value
fmt 4 E mr3$ #G187 E Value
pg187_postblock #Generic postblock to output G187 "P something" or "E something"
if mr2$,
pbld, n$, "G187", *mr2$, e$
if mr3$,
pbld, n$, "G187", *mr3$, e$
Guru,
I formated the mr3$ and it posted the form corect
g187 p1 e0. the only problem is the e value s/b .025. that is what i have in the mr3 box inside mc.
Trevor,
thanks for all the good info. if i cant figure it out by this afternoon, i will copy and past all of your code inside my post.
as always, thanks for the help,
Damian - The 4 in this statement makes the output an integer value.
Try this for 4 place decimals.
fmt 12 E mr3$ #G187 E Value
This is why I mentioned the fs2 statements.
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place
fs2 16 1 0 1 0n #Integer, forced output
# These formats used for 'Date' & 'Time'
fs2 18 2.2 2.2lt #Decimal, force two leading & two trailing (time2)
fs2 19 2 0 2 0t #Integer, force trailing (hour)
fs2 20 0 2 0 2lt #Integer, force leading & trailing (min)
  • 2 years later...
