peck tapping g-code
This is how I have to format for peck tapping:
O730 (PECK_TAPPING_TEST.730..MP)
(REV -)
(OP 3)
(MC-510VF MATSUURA)
(MAR-05-10)
(T5 - 2-56 GUN TAP)
G0 G17 G40 G80 G90 G94
G91 G28 Z0
G54
G90 X0 Y0
M1
(TAP 2-56 THRU)
T5 M6 ( 2-56 GUN TAP)
(MAX DEPTH - Z-.36)
G0 G90 G54 X.22 Y-.335 S1100 M8
G91 G43 H5 Z0. M3
G92 Z.05 M8
G90
G93
(PECK TAPPING CYCLE)
G98 G84 Z-.045 R.01 F.0179
Z-.09
Z-.135
Z-.18
Z-.225
Z-.27
Z-.315
Z-.36
G98 G84 X.935 Z-.045 F.0179
Z-.09
Z-.135
Z-.18
Z-.225
Z-.27
Z-.315
Z-.36
G98 G84 X1.127 Y-.36 Z-.045 F.0179
Z-.09
Z-.135
Z-.18
Z-.225
Z-.27
Z-.315
Z-.36
G98 G84 X1.607 Z-.045 F.0179
Z-.09
Z-.135
Z-.18
Z-.225
Z-.27
Z-.315
Z-.36
G94
G80
M9
G91 G28 Z0 M19
G28 Y0
G53 X-15.
(PECK_TAPPING_TEST.730)
M0
M99
This way should work in most machines that can go back into a tapped hole without cross-threading or opening up the pitch diameter.
Sample from my 30I control.
O0000 (PECK TAPPING)
(MATSUURA H.PLUS-300)
(I30 CONTROL)
(T1 - 1/4-20 TAPRH - H1 - D#1 - D0.2500")
(***** TOOL LIST END ****)
G0 G17 G20 G40 G80 G90
G91 G28 Z0.
(PECK TAPPING)
N1 T1 M6 ( 1/4-20 TAPRH)
(MAX - Z9.)
(MIN - Z6.3751)
G0 G17 G90 G54.1 P4
X-1.25 Y2.625
G43 H#517 Z9.
M08
G95
M80 S366
G98 G84 Z6.3751 R7.3751 Q.1 F.05
Y1.625
X1.25 Y2.625
Y1.625
G80
M09
M5
G91 G28 Z0.
/G65 P9863 H.01 M1. (TL. BRK. DET. - EJECT PALLET WITH ERRORS)
G0 G91 G28 Z0.
G49
G90
M98 P9901 (INITIATE PALLET SCHEDULER)
Yes there is. Look in the "Rigid Tapping" parameter section in your yellow FANUC manual. There's also a parameter so set full retract as opposed to the default High Speed retract.
  • 7 years later...
2 minutes ago, Travis_Buchanan said:
@Jay Kramer @ Precision Programming
In the example you posted, does the the tap retract to R each peck?  Does it reverse two revs?  etc?
Is this parameter controlled?
Travis good to see you and Happy New Year, comes down to how the control handles it. Some will go back to the R plane and others will go back to parameter value. What is the control?
21 minutes ago, Travis_Buchanan said:
Happy New Year to you Ron.  Hope you and your family is well.
Control is a Fanuc 31ib5.  I think i found it in the parameter manual.
One parameter to turn it on, another parameter to set a return value.
Yes and if you want to be real trick you can use the update parameter process in your code output to change the behavior on the fly if both parameters are on the fly adjustable without a control reset to change them. I did this on a Nakamura a couple years ago to override the percentage loop parameter to allow for broaching, but wanted it back on for normal operations. The guys in Japan gave me a slick way to turn it off for the broaching and then turn it back on after the broaching was done.
