UNJF vs UNF internal threads
mchris77
I have a 1/2-20 UNJF-3B thread to make. I've been reading specs all morning and from what I can tell a UNF and UNJF thread are the same for an internal hole. With the exception of the UNJF having a slightly larger minor dia. So I should be able to use a 60 deg single point threading tool without issue. Can anybody confirm or deny this?
That is correct. And use the same 1/2-20-3B gages.
"J" style threads are mostly used in Aerospace.
All the "J" means is a controlled root radius which is also a larger radius, than the standard UN threads root radius on MALE threads.
So when creating a "J" MALE thread the correct screw cutting, or thread mill must be used to create the correct root radius.
When creating a "J" female thread all that needs to be done is to create a larger Minor diameter to clear the larger root radius on the male thread. Standard UN insert can be used.
The larger root radius on the male thread creates a stronger male thread.
