Need Multipost VBscript advice
Good evening fellow forum members. I need some advice with a vbscript that post my operations to three different machines. Please see trodes_post.vbs on the ftp site in the vb_scripts folder. I altered this VBscript from Connormac's original. (Thank you Connormac!!! cheers.gif )
Currently, when I use the VBscript to post, it only posts in part of the Mastercam's filename. NOT the entire filename as I wish. For example, my current part is located in the following folder:
C:9999mfgetset3a
I want to post the programs in the following folder structure:
E:9999mfgetset3aBOSTOMATIC
E:9999mfgetset3aOKK
E:9999mfgetset3aMAZAK TRODE
But, as the VBscript is currently written, it posts to the following folders:
E:9999mfgBOSTOMATIC
E:9999mfgOKK
E:9999mfgMAZAK TRODE
I know absolutely NOTHING about VBscript and I've been messing with this on and off for the last couple weeks with no success. banghead.gif Any help will certainly appreciated. Thank you!!!
The script will only use the first two folders in the drawings name to create the output path. For example:
C:9999mfgetset3aTEMP.MCX is the path to my test file, the script parses this path and assigns
9999 to the variable companyname and the mfg to the variable Program and uses those two variables to create an output path i.e C:9999mfg.
If you want to output two additional output folders you will need to edit the script.
[ 03-31-2009, 02:05 PM: Message edited by: Mick from CNC Software, Inc. ]
Yep, the folders above are always in that format. The part will always have four folders and we post the .nc program to the exact folders, but into the E: drive instead of the C: drive. Therefore, if the part file = C:6112trdfinapltaplate.mcx, then the posted program should be directed to E:6112trdfinapltncfilename.nc
Let me know if this works as expected.
'// Author: Connormac
'// Date: 16/09/2003 12:58 PM
'// File Name:
'// Description: Posts drawing to 3 defined posts
'// Comments: Edited by [email protected]
'// 04-06-2009
'// Added recursive create folder method using current drawing
Public Const DEF_FIRST_POST = "BOSTOMATIC.pst"
Public Const DEF_SECOND_POST = "OKK.PST"
Public Const DEF_THIRD_POST = "MAZAK TRODE.PST"
Dim FSO
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
'On Error Resume Next
' -- Check for drawing
If IsDrawing Then
Dim strName
Dim strFolder
' -- Get the current file name
strName = GetCurrentFileName
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- Get the path
strFolder = FSO.GetParentFolderName(strName)
' -- Make the top level output folder
CreateFolder strFolder
Dim strCNC_1
Dim strCNC_2
Dim strCNC_3
' -- Assign paths to each machine
strCNC_1 = AddBackSlash(strFolder) & "BOSTOMATIC"
strCNC_2 = AddBackSlash(strFolder) & "OKK"
strCNC_3 = AddBackSlash(strFolder) & "MAZAK TRODE"
' -- Create the folders
MakeFolders strCNC_1
MakeFolders strCNC_2
MakeFolders strCNC_3
Dim strCurrentPost
' -- Store current post
strCurrentPost = GetPostName
' -- Set first post as current post
Call SetPostName(DEF_FIRST_POST)
' -- Post it
Call RunPostAll(strCNC_1, False)
' -- Set second post as current post
Call SetPostName(DEF_SECOND_POST)
' -- Post it
Call RunPostAll(strCNC_2, False)
' -- Set third post as current post
Call SetPostName(DEF_THIRD_POST)
' -- Post it
Call RunPostAll(strCNC_3, False)
' -- Set mc back to original post
Call SetPostName(strCurrentPost)
ShowString "Posting complete"
End If
End Sub
' Function Declaration
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
Public Sub MakeFolders(path)
' -- NOTE: If you use an invalid character for a part number you'll have a problem!
Call FSO.CreateFolder(path)
End Sub
' Sub Declaration
Sub CreateFolder(strPath)
' -- Recursive folder create, will create directories and Sub
' -- Fixes endless recursion in some instances when at lowest directory
If strPath <> "" Then
If Not FSO.FolderExists(FSO.GetParentFolderName(strPath)) Then Call CreateFolder(FSO.GetParentFolderName(strPath))
Call FSO.CreateFolder (strPath)
End If
End Sub
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "" Then sPath = sPath & ""
AddBackSlash = sPath
End Function
Good morning Mick. Very close, but not quite there. The folder structure is perfect, but the data path is not correct. The .nc programs are now posting to the same hard drive as the part. See the pic below.
[ 04-09-2009, 08:51 AM: Message edited by: peon ]
Give this a try.
'// File Name:
'// 04-06-2009
'// 04-13-2009
'// Added drive prompt to output
Dim FSO
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
If IsDrawing Then
Dim strName
Dim strFolder
Dim sCurrentDrive
Dim sDrive
Dim strCurrentPost
' -- Get the path
' -- Prompt for Drive change
sDrive = AskString("Input drive letter for output folder, e.g. E", "E")
' -- Get the current drive letter
sCurrentDrive = Left(strFolder, 1)
' -- replace it
strFolder = Replace(strFolder, sCurrentDrive, sDrive, 1, 1)
Dim strCNC_1
Dim strCNC_2
Dim strCNC_3
If Err Then
ShowString "Error, " & Err.Description
Else
' -- Post it
' -- Post it
' -- Post it
End If
End If
End Sub
Dim Ret
IsDrawing = Ret
End Function
End Sub
' Sub Declaration
End If
End Sub
End Function
  • 3 months later...
Hello all,
Another of the "issues" I have experienced is that the "nc" file comes up in the editor even though I do not wish it to.
I have set the post dialogs NOT to edit the file,and also set the RUNPOST parameter to FALSE as in the above code.
Is there anything else that I can do?
regards,
Steven
Mick,
I did as you suggested and gained some ground. The editors no longer start up after posting.
I did have some other "challenges" that were quite interesting. For example, the nc file type ( ie.. ".eia" or ".ncf") seems to be ignored when the posts are run from script. The posts always seem to default to ".nc".
We differ from PEON in that we keep all nc files in the same folder. The names or extensions differ to identify the machine they are posted for.
I have found that a post will work fine if I post manually, but fails if I post using script. Also, a post may work fine with script but will fail if posted manually. This has driven me to create two "SETS" of posts. One set to post each manually, and the other to be posted by VB.
Thank you for your assistance,
Steven
Anyone?
I regard this as a VB question primarily, but it is also a post processor question.
I updated some version 9 post processors into X4 and worked the bugs out. The results are what I expect.
Now the VB part....
When I use a VB script to call the posts, the results all end up with spaces between the coordinates. I removed them from the .PST file and do not want them in the code. Why would calling the post from VB cause diffferent results?
Regards,
Steven
Roger,
That is one of the first things I checked.
I checked again just now, and found that the pst file had "0" spaces, and also the NC OUTPUT setting was set to "0" spaces.
On the machine group properties tab, I select the post to run, and then post manually. The resulting file is 46k long. I execute the SAME post from VB, and the file is 101k long. The VB executed file contains spaces although the pst and the NC OUTPUT settings are "0".
I have asked my tech support group for a post processor guide similar to those in version 8 and 9. Do such guides exist for X4?
best regards,
Steven
A Post Guide isn't going to be of much help in this case!
How about this?
Create a Zip2Go package of what you're running/posting and also add the VB Script to that package (A Z2G is really just a ZIP) and be sure that the PST in question is in the Z2G.
Then send if off to -> [email protected]
Include a note in the message that I told you to send it.
I would assume that we'll be able to run down these mysterious spaces quicker than - try this and now try this...
Me again,
I can now post for several machines and generate my setup sheet through VB.
I have created my setup sheet as a text file.
I can open my setup sheet file and read all the lines in the file. Using Script, how do I send each line to the printer after it is read?
all help is VERY much appreciated.
Regards,
Steven
My last qestion on the Topic:
While I am waiting for tech support to return solutions to my X4 issues, I am attempting to implement muli-posting on the version 9.1 that we are currently using.
I find that only one toolpath segment seems to be posted when called from VB. Can someone tell me if this is correct, and how to post all toolpaths if it is correct?
I know 9.1 is not the current version of choice, but until I can get X4 fully configured and tested, I will not be able to release it to all the programmers.
Any and all help is MOST APPRECIATED.
regards,
Steven
