X+ Setup Sheet and Tool List - 3rd party Add-on
HI , I,m trying to use the "angle" in the x+ set up sheet. It dosen't seem to work. It only posted an angle on 4 of the 20 operations and the angles were wrong. It posted 90 deg. and the angles were 0.0 and 180.0 deg. Were trying to eliminate fat fingering numbers in to cut down on mistakes.I was
hoping the "angle" button would post the tool plane angles that we create.
problem # 2 - I want to use the "TL_RAd" tool radius but it only puts 2 place decimal, so if my radius is .015 it puts out .02. Is there a way to
make it 3 places?.
Does anyone know if there is a way to create the set up sheet to spit out the program with it? So you see the File info omn top like you do, then the tool info, then the program on teh bottom for reference? I know you can just copy and paste or just print and add it, just thought it would be cool to include it in the set up parameters.
After reinstalling this all my tool lists now come out as "portrait" and I was wondering how to change it back to "landscape" for printing. Also my screenshot is now on top of my logo instead of beside it like it was before. I was just wondering what I need to change to get it back to how it was. Thanks in advance for any help
Josh when you click on the take snapshot icon the window that pops up has a radio button for white background make sure that is checked
If I uncheck "white background" it works fine, blue back ground. If I check "white background" it is light gray.....
New version of X+ available.
X+
  • support of new holder name
  • added more CSS classes for customization
Is there any way to go back to not through-putting the new holder info? We were using that to pass simple text from the tool definition to our tool lists.
Thanks!
You just need the lang.dll, email me and I will send it to you.
I intalled on xp computer. It is in german. I then took the lang.dll file and put in the chook folder. When I try to run the dll file it says file format unknown. Any help? I pretty new to mastercam
Can someone help? When I run the lang.dll I get an error, Unknown file type. When I ran the x+.dll it worked fine, but it is in german.
dll -> ...\shared mcamx5\X+
That is were the lang.dll is located. However, When I try to run the lang.dll it says unknown file type.
Run the X+ tools from "X+" toolbar.
Thanks. I didn't realize on the setup sheet you could just highlight the header name and change it to english.
Hi Is there a list of procedures to get X+ to work Ive downloaded it and instated it and have the icons but they done do anything i have it set right i think! Im running windows 7 X5 thanks for your time
Okay,
I have a question.
I downloaded the X+ and installed it. When I dragged it to the toolbars, I accidently opened the Enumerate button and hit okay. Now I when I post, it doesn't post the whole program at once, it posts each toolpath like an event. How do I reverse what I did and make the post work again. I checked it with another part and the post is okay so I know it's not there. It was fine until I opened the Enumerate button.
HELP!!!!!!
Todd
I don't understand why the tl_chuck output was removed since I use that for my setup sheets and doesn't pertain to tool holders. If we could get that and the # of flutes put back into the setup sheets I'd be a happy camper. :)
It's been asked on the Beta site for months. No answer yet.
Would any one happen to know how to get X+ to name the html the same as the current machine group when you generate code for the toolpath group? I had my reseller alter my post so that it would trigger X+ when I generate code. That way I wouldn't forget to make a setup sheet. The operators like X+ setup sheets. everything they need to know on one HTML page.
X+ for version 6 is there one? The set up file for 5 i downloaded only loads in non english and did not seem to work in 6. Help me if you can. Thanks Jeff
