Sign in to follow this
Gecko779
Rotary Axis WCS incrementing
Trying to learn to use our new indexer and having some trouble getting good code. I'm milling 2 wrench flats on a cylinder and trying to use the rotary to spin the part. I have tried several different stratagies in mastercam but i cannot for the life of me get mastercam to output g54 consistently. No matter how i approach the part it is generating a g55 offset for the second flat, like this:
N120 (FLAT 1)
N130 (COMPENSATION TYPE - WEAR COMP)
N140 T1 M06 ( 1/2 FLAT ENDMILL)
N150 (MAX - Z.325)
N160 (MIN - Z.1545)
N170 M08
N180 G00 G17 G90 G54 A0. X.475 Y-.4965 S1000 M03
N190 G43 H1 Z.325
Removed to save space
N260 (FLAT 2)
N270 G00 G90 G55 A-180. X.475 Y-.4965
N280 G43 H1 Z.325
N290 Z.1545
I have tried transforming (rotate) around the x axis and using a tool plane (located on the second flat) but both output g55 for the second flat
I am using bone stock mpmaster and mastercam x4 MU3
thanks for your help
Go to your Misc Values page in the first operation
and put a 1 in
"Lock on First WCS"
I set this as a default and set it to 1 for ALL operations..
If you post your whole file and its just set in the first OP, the whole file will be OK..
but if its only set in thefirst OP and you post from the middle, you will get burned..
so I make sure its set in all OPs for safety
When using transform click "Maintain Source Operation's" under Work offset numbering.
