Sign in to follow this
Followers 0
K2csq7
prmcode
40 posts in this topic
Hi All,
I have some 5ax multisurf parallel cut ops and I wanted to use the parameter for the "limits" that I set inside the tool axis control branch for some post work (see pic attached).
I tried prmcodes 12324 - 12333, all gave me an output of zero.
I added the cminangle variable
fmt  A  20  p_out   	#Primary output axis position
fmt  B  20  s_out   	#Secondary output axis position
fmt  C  20  cminangle   #angular limit defined in operation parameters
and this to the pparameter$ postblock
if prmcode$ = 12331, cminangle = rpar(sparameter$, 1)
Not sure what is wrong, any help is appreciated.
Oh yeah, I don't think I am using the right prmcode.... but it's the only one I could find in the documentation that looked kinda close..
Those are some unique numbers that should be easily found in the NCI. Post the NCI, find the numbers, and that will tell you the associated prmcode.
I found the #'s in the NCI but only for the actual toolpath, can't find them in the parameters (at the top of the NCI)
Then they would accessed via a variable name, not a prmcode.
Post the section of NCI, and I will see if I can identify for you.
Edit my last post, I thought I had found them, but just reposted & tried to find them... I can't, even tried looking for that # in radians (65.425003 degrees = 1.14188 radians), can't find either # in the NCI.... I can post as much of the NCI as you would like but it's huge. here is the beginning
1050
14 42 11 2 2011 9 54 6 \\A1SBS\COMPANY\ENGINEERING\MCAMX\EXOTIC METALS FORMING COMPANY\12584 REV D\MILLING LESS TOOLS.MCX-5
999
440 0 82
1051
MH
1053
Machine Group-1
1008
FINISH K-K
1011
2. 0. 0. 0. 0. 0. 0. 0. 0. 0.
1012
0 0 0 0 0 1 1 1 2 0
1013
0 0.375 0.1875 1 1 0. 0. 0. 0 C:\DOCUMENTS AND SETTINGS\ALL USERS\DOCUMENTS\SHARED MCAMX5\MILL\TOOLS\SPHERMIL.MCX-5
1014
1. 0. 0. 0. 1. 0. 0. 0. 1.
1016
82 11 440 1 0. 0. 0. 41 0 0 4 0 0. 0 1 4 82 1
1017
950
0 0 0 352200 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1025
1027
1. 0. 0. 0. 1. 0. 0. 0. 1. 0. 0. 0.
1028
0 0 0. 0. 1. 0. 0. 1. 0 0 0 0
1029
0. 0. 0. 0. 0. 0. 0. 0. 0. 0 0
1020
0. 0. 0. 0. 0. 0. 0 1. 0. 0. 0. 0 50000 ALUMINUM inch - 2024
20010
TOP
20011
20012
TOP
20013
20014
TOP
20015
20016
20017
20018
part
20019
20001
3/8 BALL ENDMILL
20002
20003
20004
4 11 1 2 0.375 0.1875 0. 180. 0 0 6.332032 36.6 6.332032 1426 16 4
20006
0 50. 50. 25. 25. 0. 0. 0.
20007
0. 0.75 2.5 0.8 0.375 2. 1. 0 100. 37. 0
20008
0. 0. 1. 0 0. 0. 0 0. 0.
20009
0 0
20800
0.
20600
352181 66EC8677-FBBA-11DA-991B-001111AFFC59 "" "" Machine Base
20600
352182 66EC8679-FBBA-11DA-991B-001111AFFC59 "X" "X" HMC X Axis
20600
352183 66EC867B-FBBA-11DA-991B-001111AFFC59 "" "" Mill Machine Table
20600
352184 66EC867D-FBBA-11DA-991B-001111AFFC59 "B" "B" HMC B Axis
20600
352185 66EC867F-FBBA-11DA-991B-001111AFFC59 "C" "C" HMC C Axis
20600
352186 66EC8681-FBBA-11DA-991B-001111AFFC59 "" "" Fixture/Holder
20600
352216 26527C57-35EC-11E0-B76D-0026B98C7C03 "" "" Stock
20600
352187 66EC8683-FBBA-11DA-991B-001111AFFC59 "Z" "Z" HMC Z Axis
20600
352188 66EC8685-FBBA-11DA-991B-001111AFFC59 "Y" "Y" HMC Y Axis
20600
352189 66EC8687-FBBA-11DA-991B-001111AFFC59 "" "" HMC Tool Spindle
20600
352190 A1DF5B0B-1DB1-11E0-84D0-0026B98C7C03 "" "" Aggregate
20600
352191 66EC8689-FBBA-11DA-991B-001111AFFC59 "" "" Automatic Tool Changer
20601
352200 66EC8697-FBBA-11DA-991B-001111AFFC59 0 Default
20700
0 0 0 0 0 0 0 0 0 0
1001
0 100 10 4 4 4 0 921 98.1 0 -8.00439098 15.33112489 -0.72718845 10. 10. 10. 0 0.
11
-7.92898068 15.16620161 -0.77483137 -8.00439098 15.33112489 -0.72718845 10. 40 0 0. 0. 0.
11
-7.92093692 15.1486098 -0.77991328 -7.99634722 15.31353308 -0.73227036 -1. 40 0 -0.44767439 0.85732602 0.25412543
11
-7.71412815 15.25536963 -0.77991328 -7.78953845 15.42029291 -0.73227036 98.1 10 1000 -0.43608497 0.86328066 0.25411887
You need to look at the NCI documentation they should be listed in there. You are going to need to pull differently than what you are currently thinking IMHO. This might need to be a assigned to a buffer to then pull out the limits like zmin and zmax. I would shoot off an email to posts@mastercam.com and see what they recommend.
I heard some rumors about a new post section on the forum so mabye if that happens othefs might chime in.
Thanks Ron, I looked into the documentation and the closest I found was on page 281 MULTIAX_LIMIT ('s)
I even tried running "pwrttparam", ~prmcode$, ~sparameter$, e$ thru the post & couldn't find anything helpful....
Shot an email to posts@mastercam.com....we will see.
In playing a little with this type of toolpath, it appears that this particular data is not passed to the NCI file. If that is indeed the case, there is no way for the post to access the data directly.
That being said, however, it is possible to pass the data to the NCI by placing the values in an area that is accessible, mr1 & mr2 (Miscellaneous Real 1 & 2) for example. That means a little more work on your part, but is an easy fix for transferring data to the post.
Hope this helps a little.
Thanks grammer thats a good 1
Hard to believe, but thanks for the advice, I will be giving it a shot.
You can try to post every prmcodes in pwrttparam$ postblock and find your value in it if you are lucky^^
Just so I am on the same page ^^^^^^^ is what David is talkin about right?
If you want to see all the prmcodes put this in your pparameter$ post block
"pparameter", ~prmcode$, ~sparameter$, e$
It may already be there, if so then just unblock it.
It will show you everything the post sees. Alot more than whats shown in the nci file.
Make your angles something unique like "22.2222" and "33.3333" so you can search for them.
Post out the nc code and see what prmcodes they are.
Also some prmcodes are accessed the fprmtbl function. Search for fprmtbl in the documentation to see how that works.
yeah thought your pparameter would give me something different than pwrtparameter, but no dice....
Some general notes on parameters for everyone with regards to MP posts:
- There are several ways parameters must be obtained.
* some parameters are available in the NCI file and can sometimes be read using sparameter$ or via existing variables.
* Some values with existing variables do not need a parameter read, but a parameter read could be used to fill a new variable with the same information. * There is a long list of existing variables in the V9 documentation and you can also find several in some of the newer documentation
- Contrary to popular belief there are many parameters that do not appear in the NCI file in any form, but they still exist. They are passed by some method directly from mastercam to MP and then to the post when called for.
* in order to call for parameters not available via the NCI file some commands like rd_params$, rd_cd$, rd_md$, rd_tlpathgrp$, etc must be present in the correct location in the post. This can be difficult to troubleshoot. Some of this information is in mpmaster already but there are no guarantees it is all there, especially for newer parameters that are not used in any of the mpmaster output currently.
* some parameters are only accessible via parameter tables.
parameter table calls:
#Read parameter lookup tables -
if prmcode$ >= 17000 & prmcode$ < 18000, result = fprm(1) #Run the parameter table for Machine Definition Parameters
#Leave lines below commented until you enter values in related lookup tables
if prmcode$ >= 18000 & prmcode$ < 19000, result = fprm(2) #Run the parameter table for Control Definition Parameters
#if prmcode$ >= 19000 & prmcode$ < 19900, result = fprm(3) #Run the parameter table for Toolpath Group Parameters
parameter table contents:
fprmtbl 1 42 #Table Number, Size
# Param Variable to load value into
17008 spostname #Post Processor Filename
17060 minfrdeg_old #this parameter no longer functions MU00008b
17054 minfeedpm #Limit for feed in inch/min
17055 maxfeedpm #Limit for feed in inch/min
17058 maxfrinv #Maximum feedrate - inverse time - inch - Minimum value from MD as this is inverse time
17059 minfrinv #Minimum feedrate - inverse time - inch - Minimum value from MD as this is inverse time
17922 maxfrdeg #Maximum feedrate deg/min
* there are other parameters still that are only available as a filled group of variables. essentially the parameter number is called and a bunch of variables are filled at once in sequence all from the main call parameter, like so:
declaration of all variables associated with the parameter:
fmt 2 slot # 20004 Parameter line
fmt 2 tool_type
fmt 2 matl_type
fmt 2 corner_rad_type
fmt 2 diameter
fmt 2 corner_rad
fmt 2 threads
fmt A 2 tip_angle
fmt 2 dia_off
fmt 2 len_off
fmt 2 tool_feed
fmt 2 plunge
fmt 2 retract
fmt 2 rpm
fmt 2 coolant1
fmt 2 n_flutes1
fmt A 2 tip_angle_ch
call of the parameter group to fill the variables in pwrttparam or pparameter:
if prmcode$ = 20004, slot = rpar(sparameter$,16) - note the total number of variables is the 2nd argument in the function.
- i have probably forgotten a thing or two but that's most of the critical stuff. In summary obtaining information from parameters in MP can vary in complexity depending on how they must be obtained. Also the system of information itself is somewhat more complex than it needs to be, which is mainly due to the MP language being built upon over a number of years and the needs for information expanding beyond the original scope of older MP post processors.
Regards,
Your local post processor Guru
Thanks M30..............(I guess)......you know anything about the parameters for the limits shown in the pic attached to the first post in this topic?
haha. Sorry i would have commented if i had tried pulling those before. I haven't run into a situation where i've had to pull those variables, and currently don't have mastercam to test.
I wish I could help further.
Regards,
Paul could he build a buffer method like Zmax and Zmin and then from there use to come with what the range is for the toolpath is question?
I wonder if a script could be made to copy the numbers from your NCI file to your NC file.
Paul, Thank you, I would much rather hear the bad news than spin my wheels...
M30,
I'm glad you've taken an interest in editing Post Processors, but some of the information you posted is incorrect, so I'm going to take a minute and clear some of that up.
Mastercam passes information to the post processor in two general ways: as information in the NCI file (this infomation populates Pre-Defined variables automatically), and as Parameters that are written to a Temporary file called the .OPS file. This .ops file is then read by the Parameter Read functions, and certain values are extracted. These values are then put into user defined variables as either a String, or a Numeric variable.
Some of the information is available Multiple times. For example, Tool Information is available for every Operation directly in the NCI file. But Parameters from your individual toolpaths (like Depth Cuts, or # of Multi-passes) are also written to the .ops file, for every Operation. This is infomation that is available in the .ops, but you have to write custom logic in your Post in order to extract these values and do something useful with it. So if you had 5 Contour Operations that used Depth Cuts, and you had a Parameter Read/Write setup to capture that, you'd have to make sure you were using a Buffer, because the Depth Cut parameter would change for each toolpath.
You mentioned that some Parameters are in a group of Variables. The reason we do this is to create an Implied Array. This Array is used in combination with a Buffer. A Buffer is used to read, sort, and output information.
So just creating an ordered list of variables and then using a Parameter read/write routine does you no good, unless you use it in combination with a Buffer read/write routine. Why? because that ordered list of variables will only contain the information for the last Operation, without using a Buffer.
By the way, you can all thank Paul Decelles for coming up with the Parameter Read functionality.
Followers 0
