How can I get my post to spit out A and B moves?
I am working with MX5 and using a Chrion Post post processor (enhanced fanuc basically) which worked pretty good on X4 but X5 wants to think for me and rotate toolpaths without spitting out the proper A rotation. Also instead of spitting out A0 through A360. It spits out numbers like A900..
My question is:
Is there a switch I need to turn on/off to force my post to spit out A moves all of the time even if the next tool is running at the same A rotation?
I am using
MX5 multi axis, Lathe, Mill
Check in the machine definition. Doubble click on the A axis componet and see what the settings there are.
If the post was built from the generic 5ax mill post look at the variable "frc_cinit : 1" to see if its set to 1
First off thanks for responding
I looked at the A axis component but to be honest I not sure what I am looking for. I could send a screen cap of the page if you need it.
I also looked in the post editor and found "frc_cinit" It was set to zero so I changed it to 1 then reposted. For some reason it does not even put the A move on the first tool. I went to the "shared mcamx5" folder opened the post and changed it.
Thanks again and if you can help that would be great. If not I understand too.
WOO HOO! That worked for the A 900... degree issue! Thanks a lot.
The other issue is still happening. It just does not want to spit A moves out it spits out B all day long.
( MILLS PERIPHERY )
N100 G801 T1
M9991
M9993
G54
G800 H999 X-.572 Y-.473 Z1. B90. S1146
M28
Z.1
G1 Z-.227 F.01
This is the first tool and axis move in the program. After this move it goes to A90 just fine.
Thanks again for your help..
Here is what I found in my post. Thanks again for your help.
ptlchg$ #Tool change
#Cancel check in case missed in ptoolend
if prv_n_tpln_mch <> n_tpln_mch, pg69
##### Custom changes allowed below #####
pbld, "M01", e$
#pbld, n$, *sg00, *sgplane, *sg40, "G80", *sg90, *sgfeed, *sg98, e$
sav_absinc = absinc$
absinc$ = one
#prefreturn #xout, p_out not output here
absinc$ = sav_absinc
ptoolcomment
comment$
pcan
absinc$ = zero
##### Stop custom changes #####
p_absinc_chng
psof_tlchg_blck #Tool change position block
#Save the current brk_ in prv_brk_ for next loop
pupd_brk
p_absinc_chng
pe_inc_calc
# This call to 'pcom_movea' has been commented out to avoid
# double output of canned text
#pcom_movea
