Sign in to follow this
65Mustang
2-56 Holes 2x Deep in Titanium
Hi,
I'm looking for options on putting 2-56 2x Deep Blind tapped holes in 6al 4v Titanium.
This material is on the harder side at 35 RC-C. Using Emuge taps for titanium is not
going so well. Has any one tried thread milling?
Frank
I threadmill all threaded holes in Ti. Works great. Add a couple spring passes for smaller threads as the tool will deflect more. Program to nominal then comp out till threadgauge fits.
Thanks Randy,
I just got the thread mill in today (single thread) and you almost need a microscope
to see the tip! Have you ever done a 2-56? If so what were your parameters?
10,000 RPM and 2 IPM, IIRC
Yeah, threadmill that all day long. I;ve done .210 deep threadmilling with the singlepoing method. I think I did 2 pases. Looking for the file now.
Make that 2.25 IPM @ 10,000... and just one pass, and single point tool.
Drill-bore-ream?
Feed/Speed sound about right on.
I did a couple passes @ .01 and a spring pass to keep tool from breaking and maintain consistency.
I bet you could form tap them.
DIsagree. There is NOT a better way to make this particular hole than threadmill. Emuge, OSG, etc... tried ALL of them. ROll Taps, cut taps, all... EPIC FAIL! Blind holes in ti are just freaking brutal.
Drill-bore-ream?
Drill, Spot, Threadill.
No need to ream a 2-56 hole. Just run the hole as close to the max minor diameter then threadmill.
I prefer running multi flute threadmills with a3 pass incremental program + a spring pass at the end. I like to drill and size the hole prior to threadmilling.
Thanks Guys,
The input is appreciated. Dave unfortunately my customer won't let me form tap.
I'm going to try Spot, Drill, Size w/ endmill, Thd Mill. I will let you know how it turns out!
Frank
To All,
Thread mill working great!!!
I had to com a .0001 every 8 holes (no big deal).
24 holes done and still on the same thread mill.
Thanks again for all your help.
Frank
I've got a bunch of M2 tapped holes in 6al 4v Titanium. I am testing out a .054 dia threadmill, .032 shank, 10K rpm. Looks like the rough pass stepover posts half of the value, unless they accidentally gave me decaf and I'm still asleep.
I'm on X5 MU1. Can anyone clue me in on how much stepover I need.? I'm afraid to go much more than .003.
