kkominiarek
VMC's with a Fanuc Series 18i-mb control
The below section of code backplots and verifies fine.
Operation is standard pocketing with islands using a 3/16 bull mill.
G1 X2.5182 Y-.4059
X2.8628 Y-.0609
X2.7946 Y-.0142
X2.5833 Y-.2255
G3 X2.6694 Y-.074 I-1.3003 J.8397
X2.6837 Y-.0122 I-.126 J.0618
X2.6838 Y-.0098 I-.1403 J0. (trouble line for johnsford vmc)
G1 X2.7078 Y.0143
X2.816 Y-.0291
On the Agma VMC the code machines as it should.
On the Johnsford VMC the line of code "where labeled" machines a ccw 360 deg circle (dig into island) then continues on the correct path.
We had this machine for 4-5 years w/o any issues like this in the past.
Both machines have the same control....would anyone know what the issue could be? (a parameter?)
The machine doesn't like the .0001" move in X. Change the parameter that breaks the arcs into quadrants so it doesn't break arcs. I had an older machine at another shop I worked in that had problems with that. Hope that helps.
Goto settings
config
tolerances........ Whats your min. arc length set to?
G1 X2.5182 Y-.4059
X2.8628 Y-.0609
X2.7946 Y-.0142
X2.5833 Y-.2255
X2.6838 Y-.0098 I-.1403 J0. (trouble line for johnsford vmc) (shouldn't the X be the same or smaller number [depending on rounding] than the previous X)
G1 X2.7078 Y.0143
X2.816 Y-.0291
I'm thinking the Johnsford is correct and the Agma is misreading.
G1 X2.5182 Y-.4059
X2.8628 Y-.0609
X2.7946 Y-.0142
X2.5833 Y-.2255
G1 X2.7078 Y.0143
X2.816 Y-.0291
Hi!,
If you got the answer for this problem ??
Please let me know .
Thanking you.
regards
Nitin
Guest MTB Technical Services
The Parameters for processing Arcs are most likely not the same on both machines.
The easiest fix is to simply change you control settings in Mastercam to
1) Change the minimum arc distance and break arcs at 180 increments.
or
2) Change the output to use R-Words arcs instead of I & J.
or
Hi!,
Thanks .
I changed the control setting :
Minimum arc radius = 0.02
& break arcs at quodrants .
You can see the line where arc is taking longer path than a shortest path. Only when there is a small diffrence in X or y postion in circular path
N5188 G2 X-30.783 Y137.992 I22.175 J-90.224
N5190 G3 X-26.7 Y136.305 I4.083 J4.096
N5192 X-26.661 Y136.304 I0. J5.783
N5194 X-25.882 Y136.378 I-.172 J5.922
I do have few queries :
  1. why do we need minimum radius as : 0.005 or evn 0.1 when we knwo that we cannot machine lower than cutter radius
  2. In some case default max radius is given 200 mm : It should be maximum so as to allow lrger arcs i. 9999mm or more
  3. Tolarance in surface toolpath where this error is geneating i.e Surface finish contour : 0.001 is default value : we changed later to 0.01
  4. What is the setting required in machine controller . Any machine parameter ?
  5. Problem is due to machine taking larger portion of arc at this location see image attached.
Thanking you for your suggestions !
regards
verry small change in Y as above is causing the problem ?
Would you please modify MasterCAM of output format?
Or, you may try parameter N5008#5 from 0 to 1 to check any improvement.
N05008 P 00
0
00000
à
P 00
1
00000
This is because Fanuc controller has calculated the command of path.
However, the two points are too closed for G02/G03 moving which is like a straight line.
Fanuc will think to run path with big arc.
Please refer it.
OTHER REF.: see some solutions provided by machine tool supplier
we had a simmeler problum with two parts in a row, never had a problum with the machine befor, master cam was not caculating the right end point or swing point of the arc the progamer drew it out on the computer and it was not the right numbers, the machine should have alarmed out, but the parm was set big enough to let it keep going, the only thing that fixed it was to set to the no rounding setting we reran prog meny times with diffrent settings, but no rounding was the only fix for us
We tried a few things....nothing worked for this particular issue.
Our vendor had us change parameter 3450 and 5008......this did not work
Add lines...G49 G40: G5.1 Q1: before the G43 H4 Z.3:.....this did not work
We tried the parameter change with and without the G49 G40: G5.1 Q1:....this did not work.
We had no problems before and no problems since.
