You can call the XForm_Project function within Mastercam,
works just like if the uer had selected the command.
Add a Class to your C# Project
[ C# <-> VB convert ]
using System;
using System.Runtime.InteropServices;
namespace MyProject
   // Declare the P/Invoke signatures
   class Interop
       // extern "C" __declspec(dllexport) int do_xform_project (int dummy)
       [DllImport("McCore.dll", EntryPoint = "do_xform_project", CharSet = CharSet.Auto)]
       public static extern int XformProject(int dummy);
And make the call, like this ->
int rv = MyProject.Interop.XformProject(0);
  • 1 year later...
Windows 7 32bit - Tested under Mcx7/VS2010 and Mcx6/VS2010
When running the above code in the IDE, it runs OK, but after completion, the IDE gives a PInvoke Error (see image)
Below is the complete (short) VB source:
Imports System.Runtime.InteropServices '
Imports System
Imports Mastercam.App
Imports Mastercam.App.Types
Namespace MyExample
Public Class NetHookAppExample
 Inherits NetHook2App
 Public Overrides Function Run(ByVal param As Integer) As MCamReturn
	 Dim rv As Integer = Interop.XformProject(0)
	 Return Mastercam.App.Types.MCamReturn.NoErrors
 End Function
End Class
' Declare the P/Invoke signature
Class Interop
 ' extern "C" __declspec(dllexport) int do_xform_project (int dummy)
 <DllImport("McCore.dll", EntryPoint:="do_xform_project", CharSet:=CharSet.Auto)> _
 Public Shared Function XformProject(ByVal dummy As Integer) As Integer
 End Function
End Class
End Namespace
Is there something else I should be doing ?
Try adding the the CallingConvention shown below...
' Declare the P/Invoke signatures
Class Interop
<DllImport("McCore.dll", EntryPoint := "do_xform_project", CharSet := CharSet.Auto, CallingConvention := CallingConvention.Cdecl)> _
Public Shared Function XformProject(dummy As Integer) As Integer
End Function
End Class
  • 4 years later...
Hi! I'm exploring the capabilities of Invoke to solve a task in my Nethook App.
I'd like to ask why do you know that "do_xform_project" is the EntryPoint for this function in the McCore.dll. Is there a way to explore the dll to get this?
Thank you in advance!
