EIA/ISO Sample Code for Mazatrol Matrix
turn on main spindle
(T2 | OD ROUGH RIGHT - 80 DEG. )
G123.1
M901
M202
G53.5
T2 T006 M6 D001
G28 U0. V0.
G28 W0.
M250
G0 B90.
M251
G53.5
G18
G50 S6000 R1
G96 S180 M03 R1
G0 X9.555 Z2.132
G99 G1 X8.1375 F.005
G0 Z2.162
X9.555
Z2.108
G1 X8.1375
G0 Z2.138
X9.555
Z2.084
G1 X8.1375
G0 Z2.114
G28 U0. Y0.
G28 W0.
M01
turning on sub spindle
N9
(| OD ROUGH LEFT - 80 DEG. DNGP-431)
( ROUGH FACE & TURN)
G123.1
M902
M302
G53.5
T9.01T005M6D009
G28U0.V0.
G28W0.
M250
G0B180.
M251
G53.5
G18
G50S6000R2
G96S175M304R2
G0 X7.7457 Z-.3404
X7.675 Z-.305M8M153
G99 G1 X3.9578 F.004
X3.9278 Z-.32
X3.5238
G0 X3.5945 Z-.3554
X7.7457
Z-.3254
X7.675 Z-.29
G1 X3.9878
X3.9378 Z-.315
G0 X4.0085 Z-.3504
X7.7457
Z-.3104
X7.675 Z-.275
G1 X4.0121
Z-.2779
X3.9678 Z-.3
G0 X4.0385 Z-.3354
X7.7457
Z-.2954
X7.675 Z-.26
G1 X4.0121
Z-.2779
X3.9978 Z-.285
G0 X4.0685 Z-.3204
Z-.5
M9M154
G28U0.Y0.
G28W0.
M05
M00
M00(CHECK INSERT)
drlling on main
make note !!1 always use G68 rotate and only use milling toolpaths, not c axis paths
N3
(T3 | 3/64 FLAT ENDMILL | LEN. - 3. | DIA. - 3. )
G122.1
M902
M300
G110 C2
G53.5
T3 T004 M6 D003
G28 U0. V0.
G28 W0.
G97 S8300 M203
M248
M250 M312
G98 G0 B102. C280.
M251 M311
G53.5
G111
G68.5 X0. Y0. Z0. I0. J1. K0. R102.
G0 G17 X.55 Z3.
Y0.
G83 Z-1.9327 R4.8729 Q.02 F5. M311
G80
G69.5
G28 U0. Y0.
G28 W0. M205
M01
here is a snip of 5 axis
G28 U0. Y0.
G28 W0.
N1
(3/16 BALL ENDMILL )
G122.1
M901
M200M300
T24 M6 D024
G30 P4 U0. V0.
G30 P4 W0.
M511(SYNCRO)
G97 S2852 M203
M248
G52.5 (MAZATROL COORDINATE SYSTEM CANCEL)
G10 L12 P[#51999] R[#[61000+#3020]/2] (TOOL RADIUS)
G10 L10 P[#51999] R#[60000+#3020] (TOOL LENGTH)
(WORK OFFSET G54 DATA SETTING)
G10 L2 P1 X#50700 (WORK OFFSET G54 X__)
G10 L2 P1 Y0.0 (WORK OFFSET G54 Y0.0)
#3200=3 (Z AXIS PARAMETER ROW OF S23)
#500=[#3223/100000] (#500 CAPTURES Z IN S23 PARAMETER)
G10 L2 P1 Z[#9101+[#500]] (WORK OFFSET G54 Z__)
G10 L2 P1 C#9102 (WORK OFFSET G54 C__)
G10 L2 P1 B0.0 (WORK OFFSET G54 B0.0)
G54
M250 M212
G98 G0 B100.5515 C11.3506
M211
G0 X6.0 Z-.4 G43.4 H24
X.3872 Z-.3869
Y-.6117 M8
G98 G1 X-.0241 Y-.5291 F100.
X-.0342 Y-.5008 Z-.3857 F6.
X-.039 Y-.4868 Z-.3841 C11.3483 B100.4925
X-.0451 Y-.4716 Z-.3821 C11.3461 B100.4412
X-.049 Y-.4617 Z-.3808 C11.3446 B100.4057
X-.0527 Y-.452 Z-.3796 C11.343 B100.369
X-.0562 Y-.4424 Z-.3784 C11.3414 B100.3314
X-.0596 Y-.433 Z-.3773 C11.3397 B100.293
X-.0628 Y-.4236 Z-.3762 C11.3379 B100.2538
X-.0662 Y-.4134 Z-.375 C11.3357 B100.2084
X-.0693 Y-.4034 Z-.3738 C11.3335 B100.1621
X-.0724 Y-.3935 Z-.3727 C11.3312 B100.1153
X-.0753 Y-.3839 Z-.3717 C11.3288 B100.0673
X-.0806 Y-.3649 Z-.3696 C11.3238 B99.9698
X-.0854 Y-.3466 Z-.3677 C11.3184 B99.8698
X-.088 Y-.3359 Z-.3666 C11.3149 B99.8087
X-.0905 Y-.3254 Z-.3656 C11.3114 B99.747
X-.0928 Y-.3151 Z-.3646 C11.3077 B99.6844
X-.0949 Y-.3049 Z-.3636 C11.3039 B99.6214
X-.0974 Y-.2928 Z-.3624 C11.2992 B99.5448
X-.0995 Y-.281 Z-.3613 C11.2942 B99.4671
X-.1016 Y-.2695 Z-.3603 C11.2891 B99.389
X-.1034 Y-.2581 Z-.3593 C11.2838 B99.3103
X-.1051 Y-.247 Z-.3583 C11.2783 B99.2309
X-.1066 Y-.236 Z-.3573 C11.2726 B99.151
X-.108 Y-.2252 Z-.3564 C11.2668 B99.0709
X-.1092 Y-.2146 Z-.3555 C11.2608 B98.9903
X-.1103 Y-.2047 Z-.3547 C11.2549 B98.9136
X-.1113 Y-.1949 Z-.3539 C11.2489 B98.8365
X-.1129 Y-.1758 Z-.3524 C11.2363 B98.6814
X-.114 Y-.1568 Z-.3509 C11.2227 B98.5215
How are you running the tools? Eia or Mazatrol for the control of them? Are you planning on using the G68 for your coordiate shift? The main things are the codes from main to sub spindle then the milling. Getting all that sorted out is the biggest thing beside maybe in you are planning on doing canned cycles for the turning operations.
Jermeny, I had many tool defintions for the same milling tool. I would have a main spindle and a sub spindle one. I would also have different ones for chasing hole sizes with endmills. :turned:
I did not mean to imply that you would not need one sometimes. I was just saying that was when you would need to call one. ;)
+1 one to the inhouse post.
Another thing to be aware of, unless this has changed on the newer models, if you are going to do 5-axis work on the sub spindle , you have to sync the spindles and tell the machine you are working on the main spindle.
Ron and Wes, Do you Guys use a G50 workshift for moving your Z between spindles or G53.5 Z[#variable]?
On the old mark4 we use the G50
We have 4 new I series machines and they are mill based. So I can set any work offset I want. Normally G54 on main and G55 for sub. They are way cool to program compared to the old style slant bed Integrexes. I use multi axis paths for all milling on the new ones, just because they play better with G43.4
