Modifying Long Hand drill code
Would it be possible to modify my Peck drilling, set to output in long code, to give me option on feedrates for retract and return?
I would like something like this:
G1 Z-4.0 F5. (DRILL FEED)
G1 Z0. F50. (FAST FEED OUT)
G1 Z-3.8 F25.(SLOWER FEED BACK IN HOLE)
G1 Z-4.3 F5. (DRILL FEED)
Second part of my question, If this can be accomplished. Would this information be posted to the NCI file or only to final NC code?
As I I am using third party posts.
This section of code will do what you want. You will need to edit the text for the custom drill cycle name and drill parameters used in the control definition file. Also you will need to define variables used for output in your post.
To use this:
Select Custom Drill Cycle 9
Type desired entry feedrate in Drill Parameter #1
Type desired exit feedrate in Drill Parameter #2
The rest is the same as a normal peck drill cycle, with values for Peck 1, Peck 2, and Retract amount.
 if drillcyc$ = 9,	 #MODIFIED FEEDRATES CYCLE
 omitcycend = 1
 zpecktemp = refht$ - peck1$ - drl_sel_ref$
 zpeckclr = zpecktemp + peckclr$
 entryfeed = drl_prm1$
 exitfeed = drl_prm2$
 z$ = depth$
 zevac = refht$ - drl_sel_ref$
 pdrlcommonb
 "G0 G90", pfxout, pfyout, e$
 *initht$, e$
 *refht$, e$
 "G1", *zpecktemp, *feed, e$
 "G1", *zevac, *exitfeed, e$
 "G1", *zpeckclr, *entryfeed, e$
 zpecktemp = zpecktemp - peck2$
 while zpecktemp > depth$,
 "G1", pfzout, *feed, e$
 "G1", *refht$, *exitfeed, e$
 "G0", *initht$, e$
 pcom_movea
 !x$, !y$
To use this:
 omitcycend = 1
 z$ = depth$
 pdrlcommonb
 *initht$, e$
 *refht$, e$
 "G0", *initht$, e$
 pcom_movea
 !x$, !y$
Where in the .pst file does this custom cycle get inserted?
Drill cycle does not work on my fanuc lathe control. Can I use the custom drill cycle #9 for peck drilling?
Is there a simpler custom cycle that will do the same thig as a G74? Or preferably G83?
clay
Custom cycles are tailored to do exactly what the post owner wants to achieve. With a little effort, you can learn how to code your own cycles to do exactly what you desire. Or hire someone to code it for you.
  • 1 year later...
I love this macro, it opens more possibilities, however I feel the logic will get people in trouble.
There should be testing to ensure no overcut in the hole depths.
Here is update with testing statements to ensure depth wanted.
I found this in my testing & I hope this will help.
Testing is a must for your ensured accuracy.
Please do your own as I may have missed something!
if drillcyc$ = 8, #MODIFIED FEEDRATES CYCLE, VER-2
omitcycend = 1
IF zpecktemp < depth$, zpecktemp = depth$
z$ = depth$
pdrlcommonb
n$, "G0 G90", pfxout, pfzout, e$
n$, "G1", *Initht, e$
n$, "G1", *Refht, e$
n$, "G1", *zpecktemp, *feed, e$
n$, "G1", *zevac, *exitfeed, e$
IF zpecktemp <> depth$,
n$, "G1", *zpeckclr, *entryfeed, e$
if zpecktemp < depth$, zpecktemp = depth$
n$, "G1", *Refht, *exitfeed, e$
n$, "G0", *Initht, e$
pcom_movea
!x$, !y$
	 omitcycend = 1
	 z$ = depth$
	 pdrlcommonb
	 pcom_movea
	 !x$, !y$
Kind of an unwritten rule around here. Use at your own risk. :turned:
