Make Your Post Catch Common Errors
You already helped me to figured it out for the
Let me know when will you come to San Jose, California or Oakland, San Francisco because I can drive to these 3 cities and have drinks with you
OK Then! :D:cheers:
So. As we did before, simply add basic tool variable (t$ as string) to the error string:
t$ is a numeric variable, we have to convert it to string with no2str() function
stoollengthoffserror = "Look for CUT# " + sOpSeqNo + ": " + "(" + s20001 + ") WRONG TOOL LENGTH OFFSET#, Suppose to match: " + no2str(t$)
You can do the same right here too:
stoollengthoffszeroerror = "Look for CUT# " + sOpSeqNo + ": " + "(" + s20001 + ") WRONG TOOL LENGTH OFFSET#, Suppose to match: " + no2str(t$)
And at cutter comp error strings:
stooldiameteroffserror = "Look for CUT# " + sOpSeqNo + ": " + "(" + s20001 + ") WRONG CUTTER COMP, Suppose to match: " + no2str(t$)
stooldiameteroffszeroerror = "Look for CUT# " + sOpSeqNo + ": " + "(" + s20001 + ") WRONG CUTTER COMP#, Suppose to match: " + no2str(t$)
You know these procedures are GOLDEN like checking INITIAL HEIGHT, RETRACT HEIGHT,
Sure! After 10 years operating on different CNC machines and another 5 years with programming them, yes...
I know exactly what means a wrong sign before a simple number... ;)
USE CLEARANCE ONLY AT THE START AND END OF OPERATION
G89 OR G88 WARNINGS.
Do you mean G98/G99? Really good idea BTW. A little bit it's sound a factory specific stuff or a kind of "rote/habit".
But anyway, good idea and related with this topic too.
On the attached pic, do you wanna catch if one of the values under what you given?
Like a programming/factory standard?
Good idea, even if they are not very common, I mean not common generally, because it's not a T number or a D offset
those are common errors on CNC machines. But I can imagne that "Z" values are important standard in your shop.
I'll take a look, but tomorrow only, it's 23:58 in Hungary :D Don't say thanx, it's my hobby and with it I'm learning too. Don't forget my beer! ;):D
This is what I got and I hope you'll like it.
# Error Checks
sOpSeqNo : "" #Operation manager displayed operation number
stoollengthoffserror = "CUT#" + sOpSeqNo + " *** WRONG TOOL LENGTH OFFSET" + " *** T" + no2str(t$)+ " *** H" + no2str(tlngno$) + " *** MUST BE H" + no2str(t$)+ " *** " + "(" + s20001 + ")"
sg53xyzerrorcheck = "Look for CUT# " + sOpSeqNo + ": " + "(" + s20001 + ") UNUSUAL G0 G53 XYZ VALUE IN HERE"
stooldiameteroffserror = "CUT#" + sOpSeqNo + "*** WRONG COMP" + " *** T" + no2str(t$)+ " *** D" + no2str(tloffno$) + " *** MUST BE D31+ *** " + "(" + s20001 + ")"
scoolantisoffserror = "Look for CUT# " + sOpSeqNo + ": " + "(" + s20001 + ") NO COOLANT"
serrordetect = "Click OK to Q.C source program, click CANCEL to ignore"
sMyFancyDepthError = "WRONG TOP OF STOCK *** CUT# " + sOpSeqNo + " *** T" + no2str(t$) + " *** Z" + no2str(operation_depth) + " *** BUT TOP OF STOCK IS " + no2str(OpTopOfStock) + " *** " + "(" + s20001 + ")"
s20001 : "" #String for tool description
s20002 : "" #String for tool description
Tool.pdf
Yeah, really good! ;)
If you wish to break the whole string into multiline string, for better appearance and visibility, you can add "enter" or
"carriage return" as an ASCII code with no2asc() function.
An example:
stooldiameteroffserror = "CUT#" + sOpSeqNo + "*** WRONG COMP" + " *** T" + no2str(t$)+ " *** D" + no2str(tloffno$) + no2asc(13) + " *** MUST BE D31+ *** " + "(" + s20001 + ")"
Now your error message will be multiline always.
OK, here is my idea to catch few things in OPs:
We need some variables:
OpClrPlane  : 0  # Operation Clearance plane
OpRtrPlane  : 0  # Operation Retract plane
OpFeedPlane  : 0  # Operation Feed plane
OpClrPlane_ON : no$ # Operation Clearance plane set or not
OpRtrPlane_ON : no$ # Operation Retract plane set or not
OpClrPlane_min : 10 # Operation Minimum Clearance value - SET MINIMUM HERE
OpRtrPlane_min : 5  # Operation Minimum Retract value - SET MINIMUM HERE
OpFeedPlane_min : 2  # Operation Minimum Feed value - SET MINIMUM HERE
Need to catch some values from OP parameters @ pparameter$ postblock:
if prmcode$ = 10020, OpClrPlane = rpar(sparameter$, 1) # Operation Clearance plane
if prmcode$ = 15374, OpRtrPlane = rpar(sparameter$, 1) # Operation Retract plane
if prmcode$ = 10024, OpFeedPlane = rpar(sparameter$, 1) # Operation Clearance plane
if prmcode$ = 15100, OpClrPlane_ON = rpar(sparameter$, 1) # Operation Clearance plane set or not
if prmcode$ = 15101, OpRtrPlane_ON = rpar(sparameter$, 1) # Operation Retract plane set or not
Create a individual postblock:
pCheckOpValues
     # Clearance plane
     if not(OpClrPlane_ON), if mprint("Clearance plane not set!!!", 2) = 2, exitpost$
     else, if OpClrPlane < OpClrPlane_min, if mprint("Clearance plane LOW!!!", 2) = 2, exitpost$
     # Retract plane
     if not(OpRtrPlane_ON), if mprint("Retract plane not set!!!", 2) = 2, exitpost$
     else, if OpRtrPlane < OpRtrPlane_min, if mprint("Retract plane LOW!!!", 2) = 2, exitpost$
     # Feed plane
     if OpFeedPlane < OpFeedPlane_min, if mprint("Feed plane LOW!!!", 2) = 2, exitpost$
Somewhere here insert the call of our pCheckOpValues postblock (3 times in your post I guess)
(the places where you check the OP depth)
"( DOC =", *operation_depth, ")", e$
if OpTopOfStock < operation_depth, [if mprint("Something is verrryyyy-verrryyyy wrooonnngggg", 2) = 2, exitpost$]
last_op_id = op_id$
pCheckOpValues
Is there away I can identify the Cut# for the toolpath like previous I did like
scoolantisoffserror = "CUT#" + sOpSeqNo + " *** NO COOLANT ***" + no2asc(13) + "TOOL#" + no2str(t$) + " (" + s20001 + ")" + no2asc(13) + no2asc(13) + "M9 *** IS WHAT YOU HAVE NOW"+no2asc(13)+"M8 *** IS WHAT USUALLY IT HAS IN THE TOOLPATH"
Wow, Peter you really make my eyes bursting tears. You are so nice spend time for me.... Thank you...
No problem, glad to help! It's my hobby (and work will be) I have time in these days and I also learning with it.
But I just start to thinkin' to add a Donate button with PayPal in my signature.... :D:lol:
Sure... ;)
I'm sorry for being abused, I figured it out already. I will post the codes after I'm done. Thanks a million, Peter.
Yepp, so easy now! ;)
Well, I got it and the forum is now only allowing me to upload 35.27K image size whereas my file size is 300K
Here is my codes
#Custom Defined Variables
operation_depth : 0 # Operation full depth
last_op_id2 : 0 # OP tracking ID
OpTopOfStock : 0 # Operation Top of Stock
OpClrPlane_ON : yes$ # Operation Clearance plane set or not
OpRtrPlane_ON : yes$ # Operation Retract plane set or not
OpClrPlane_min : 0 # Operation Minimum Clearance value - SET MINIMUM HERE
OpRtrPlane_min : 0 # Operation Minimum Retract value - SET MINIMUM HERE
OpFeedPlane_min : 0 # Operation Minimum Feed value - SET MINIMUM HERE
# Error Checks
stoollengthoffserror = "CUT#" + sOpSeqNo + " *** POSSIBLE WRONG TOOL LENGTH OFFSET ***" + no2asc(13) + "TOOL#" + no2str(t$) + " (" + s20001 + ")" + no2asc(13) + no2asc(13) + "H" + no2str(tlngno$) + " *** IS WHAT YOU HAVE, IT SHOULD BE *** H" + no2str(t$)
sg53xyzerrorcheck = "Look for CUT#" + sOpSeqNo + ": " + "(" + s20001 + ") UNUSUAL G0 G53 XYZ VALUE IN HERE"
stoollengthoffszeroerror = "CUT# " + sOpSeqNo + "POSSIBLE WRONG TOOL LENGTH OFFSET#"+no2asc(13)+"TOOL#"+no2str(t$)+" ("+s20001+")"+no2asc(13)+no2asc(13)+"H" +no2str(tlngno$)+" *** IS WHAT YOU HAVE NOW"+no2asc(13)+"H"+no2str(t$)+" *** IS WHAT YOU SHOULD HAVE"
stooldiameteroffserror = "CUT#" + sOpSeqNo + " *** POSSIBLE WRONG COMP ***" + no2asc(13) + "TOOL#" + no2str(t$) + " (" + s20001 + ")" + no2asc(13) + no2asc(13) + "D" + no2str(tloffno$) + " *** IS WHAT YOU HAVE NOW, IT SHOULD BE HIGHER THAN D30 ***"
scoolantisoffserror = "CUT#" + sOpSeqNo + " *** NO COOLANT ***" + no2asc(13) + "TOOL#" + no2str(t$) + " (" + s20001 + ")" + no2asc(13) + no2asc(13) + "M9 *** IS WHAT YOU HAVE NOW" + no2asc(13) + "M8 *** IS WHAT IT SHOULD BE"
serrordetect = "CUSTOM MASTERCAM AUTOMACTIC SOURCE Q.C FUNCTION" + no2asc(13) + no2asc(13) + "Click OK to Q.C source program" + no2asc(13) + "click CANCEL to ignore"
sOpClrPlane_ON = "CUT#" + sOpSeqNo + " *** CHECK LINKING PARAMETER PAGE"+no2asc(13)+no2asc(13)+"INITIAL Z CLEARANCE VALUE IS NOT SPECIFIED"
sOpRtrPlane_ON = "CUT#" + sOpSeqNo + " *** CHECK LINKING PARAMETER PAGE"+no2asc(13)+no2asc(13)+"INITIAL Z RETRACT VALUE IS NOT SPECIFIED"
sMyFancyDepthError = "CUT# " + sOpSeqNo + " *** POSSIBLE WRONG TOP OF STOCK" + no2asc(13) + "TOOL#" + no2str(t$) + " (" + s20001 + ")" + no2asc(13) + no2asc(13) + "SOURCE DEPTH IS Z" + no2str(operation_depth) + " *** TOP OF STOCK IS " + no2str(OpTopOfStock)
ptlchg_errorpop #Pop-up common toolchange errors
errorcheck = 1
if tloffno$ <> t$ & tloffno$ <30, [if mprint(stooldiameteroffserror, 2) = 2, exitpost$] #Diameter Doesnt Match T
if tlngno$ <> t$ & tlngno$ <> zero, [if mprint(stoollengthoffserror, 2) = 2, exitpost$] #Length Doesnt Match T
if xh$ <> zero | yh$ <> zero | zh$ <>zero, [if mprint(sg53xyzerrorcheck, 2) = 2, exitpost$] #G53XYZ
if tlngno$ = zero, [if mprint(stoollengthoffszeroerror, 2) = 2, exitpost$] #Zero Length
if coolant$ = zero, result = mprint(scoolantisoffserror, 1) #No Coolant
if OpTopOfStock < operation_depth, [if mprint(sMyFancyDepthError, 2) = 2, exitpost$]
if not(OpClrPlane_ON), [if mprint(sOpClrPlane_ON, 2) = 2, exitpost$]
if not(OpRtrPlane_ON), [if mprint(sOpRtrPlane_ON, 2) = 2, exitpost$]
ptlchg_errorcheck #Check for common toolchange errors
if errorcheck = 0,
if tloffno$ <> t$ | tlngno$ <> t$ | coolant$ = zero, result = mprint(serrordetect, 2)
if result = 1, errorcheck = 1
if result = 2, errorcheck = 2
if errorcheck = 1, ptlchg_errorpop
# Start of File and Toolchange Setup
psof0$ #Start of file for tool zero
psof$
psof$ #Start of file for non-zero tool number
"(*)", e$,
comment$, e$
ptravel
pwritbuf5
pcuttype
toolchng = one
if ntools$ = one,
ptlchg0$ #Call from NCI null tool change (tool number repeats)
ptlchg_errorcheck #Check for common toolchange errors # This line will search for depth cuts and multi-passes
toolchng0 = one
rd_params$ # Read parameters - pparameter
pmisccheck
pcuttype
toolcount = toolcount + 1
if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)
else, nexttool = first_tool$
retractflg = 0
ptlchg$ #Tool change
pcuttype
toolchng = one
if wcstype = one, #Work coordinate system
pfbld, n$, *sg28, "X0.", "Y0.", e$
pfbld, n$, "G92", *xh$, *yh$, *zh$, e$
pbld, *sg53, "Y0", e$
[if indx_out <>0, "A0.", else, ""], e$
if mi10$=one, n$, *sm00, e$
else, pbld, n$, *sm01, e$
comment$,e$
"(*)", e$
ptlchg_com
THANK YOU PETER, ALL OF THESE SAFETY CHECKS ARE MADE BY YOU. YOU HAVE SAVE MANY UNWELCOME FUTURE ACCIDENTS. OUR PEOPLE THANK ----- YOU THAT THEY ARE AT A SAFE WORK PLACE WITH THEIR HANDS AND LEGS AND FACE... AND... EYES BEING PROTECTED BY YOU.
I TRULY HONOR YOU AS MUCH AS I'M TREATING MYSELF GOOD.... THANK YOU FOR EVERYTHING ABOUT THIS SAFETY CHECKS.
Hi Peter,
How do I disallow the "DRILLING" toolpath not to check the RETRACT plane because it does not have a RETRACT feature. Can you assist me? Thank you.
PS: The milling function of RETRACT check is good but not the drilling function since they don't have that function included.
S.Luong
You can check the type of operation, in your ptlchg_errorpop postblock change the last line to this:
if not(OpRtrPlane_ON) & opcode$ <> 3, [if mprint(sOpRtrPlane_ON, 2) = 2, exitpost$]
Is there a way...
Yes. Always almost... ;)
Is there away I can call out PASSES, SPACING, SPRING PASSES, STEP OVER PERCENTAGE, STEP OVER DISTANCE, values in the 2D TOOLPATHS - POCKET so I can remind my programmers what they did wrong?
Need to define EXACTLY what we want. Error check during post? List from these values in header section of NC code?
List from these values at tool changes in NC code?
Check and compare values to given Min/Max values?
one of the biggest problem that we are crazy about is the OPERATOR try to PROVE the G-CODES and back up to the system without updating the source. Therefore, I would like to define those fields and get ready for the bad days.
Is there away we can ask the post processor will do a comparing file right after we post? I think it would be tough but would be much more less crap parts...
  • 1 year later...
