Sign in to follow this
Guess_who
Trimming
I would just like to complain for a minute. But can anyone explain why when you choose "trim", MasterCam defaults to solid edges instead of 2d geometry.
when I go to trim 2d geometry and there is a solid under it, MasterCam will always choose the solid edge line first.
Is it just me that sees this as annoying and useless?
I know, "just turn off the solid geometry level", well that all find and dandy when you have a simple solid. But when you have a very complex solid, it takes a while to turn it on and off. And when you have to do it 100 times, those seconds add up.
Where is the option to say "ignore" solid edges. And BTW - masking only 2d geometry doesn't work.
In my screen shot, here is an example of what I'm talking about. If you try to trim the dark blue line, to the green line, MasterCam will choose the solid edge of the light blue pocket.
If anyone has some config settings or something, I'd love to try it.
OK, I'm done complain.
thanks for listening.
I feel your pain. I find that if I hit ALT S and unshade the solid, then I can select the geo underneath. Shading/unshading is a lot faster than blanking
alt-s also works if you have geometry over surfaces. with the surfaces shaded it always
wants to grab the surface not the line or arc. i put the unshading icon on my tool bar
just so i don't have to touch the keyboard.
HTH Ken,
I will turn shading off when selecting geometry quite often. However, I normally project my geometry a bit up from the part so this type of selection issue has never been a problem for me.
Great I'll try to get into the habit of Alt-S.
BTW - doesn't the default seem backwards? I might actually want to trim to a solid edge once in a blue moon, but not very often. Maybe I am just used to doing things the old fashion way and I need to modify how I use my solid edges. I've tried using solid edges for chaining, but it's just more of a hassle than it's worth IMO.
Have you tried using the Quick Mask buttons? If you right-click on the Wireframe quick mask button, it will put you into the "only" selection mode for wireframe. The trimming will then only work on the wireframe. This is how I get around this issue...
Thanks Colin, but that doesn't seem to work for solid edges when you're trimming. IDK why. But thanks for the tip about the quick masking. I never really used them, but that seems like a handy feature.
Ya, but you're not used to that already?
"But thanks for the tip about the quick masking. I never really used them, but that seems like a handy feature."
Force yourself to learn and use this feature for the next dozen jobs. One of my favorite tools for sure.
Are you certian you are using it correctly?
Works for me when trimming (or doing anything else...)
Well whenever I have said I'm sure about something, someone else has proved me wrong. But, as far as I know, yes, I am using it correctly.
Pretty simple actually, click "mask only", then choose just points. Pick trim, and hover over your solid. You will be able to pick any solid edge of the part, whether its a line or arc or whatever.
I will agree that masking works with most functions, but Masking + trimming, just doesn't work with solids edges.
The arrow points to the quick mask for wireframe.
RIGHT click on it.
Then you will ONLY be allowed to select wireframe.
Do you have that toolbar?
Cool!
Hey Rick, how are you?
Been to John's cottage lately?
John kicked me out....
So I gave your key to Hardmill, balls squared. ROR
RIGHT click on it.
Yes, I use it. And it works for most things. Just not when using the trimming function. Not a big deal.
Thanks for the reply.
You are absolutely correct Ray.
That is not cool.
I never use any of that stuff.... I just rotate until the line (or whatever you wanna trim) has nothing behind it but space....
Alt+S is the best option.
