Verisurf - Ernie Husted
VERISURF TOOLS For MASTERCAM
Same as before. Seeking....
I updated the install again.  please test.
It's only hanging on some computers, not all. The only clue I have is that its hanging when it's trying to create the uninstall program, using your system %Temp% folder for copying.
This install will make a VSInstallLog.txt in the mcamX8  folder, please send it to me if you have this problem again.
Ernie
Is there any date on when the full Verisurf X8 Package will be out?
With inspection tools etc for laser/probe devices?
Ernie,
Could you please PM me your contact info. One of our engineers would like some info about scanning parts prior to target machining. We will be doing a high volume of these parts and he is looking to reduce set up time.
 Tim Hainz
We have a release candidate out now.
Would you like to test it out?
Ernie
I'll send you a message with our inspection guy's e-mail. He was the one who wanted to know =] I just use the tools version you have here, he uses full-blown verisurf.
I'll walk over and ask him if he'd like to test it out.
Still the same thing Ernie
Hung up at Seeking
and yes, I did empty the Temp folder too
Same thing. Ernie here is a question. how do we remove the old X8 tools sense it is not in the add and remove programs. maybe if we got the old one out the new one would install. should I just manually remove it?
John are you running an exiting tool for X8 to?
exiting tool?
Look in the VSInstallLog.txt file to see the files that get installed,  it's located in the Mcamx8 folder.
It's getting stuck at trying to add the Uninstall program. not sure why....
Ernie
[12/22/2014 12:50:33] Success Setup started: C:\Users\jparis\Desktop\Verisurf_Tools_for_Mastercam_X8.exe
[12/22/2014 12:50:33] Notice Setup engine version: 8.0.0.0
[12/22/2014 12:50:33] Notice Product: Verisurf, version X8 tools 12-19-14
[12/22/2014 12:50:33] Success Language set: Primary = 9, Secondary = 1
[12/22/2014 12:50:33] Success Verify archive integrity
[12/22/2014 12:50:33] Skipped Date expiration check
[12/22/2014 12:50:33] Skipped Uses expiration check
[12/22/2014 12:50:33] Success System requirements check
[12/22/2014 12:50:33] Success Include script: _SUF70_Global_Functions.lua
[12/22/2014 12:50:33] Notice Start project event: Global Functions
[12/22/2014 12:50:33] Success Run project event: Global Functions
[12/22/2014 12:50:33] Notice Start project event: On Startup
[12/22/2014 12:50:34] Success Run project event: On Startup
[12/22/2014 12:50:34] Success Display screen: Verisurf X8 tools Setup
[12/22/2014 12:50:35] Notice Start project event: On Pre Install
[12/22/2014 12:50:35] Error Script: On Pre Install, Line 4 (2202)
[12/22/2014 12:50:35] Success Run project event: On Pre Install
[12/22/2014 12:50:35] Success Display screen: One Progress Bar (While Installing)
[12/22/2014 12:50:35] Success Free space check on drive: C:\
[12/22/2014 12:50:35] Success Set uninstall data folder: C:\Program Files (x86)\Verisurf Uninstall\X8Tools
[12/22/2014 12:50:35] Success Set uninstall config file name: C:\Program Files (x86)\Verisurf Uninstall\X8Tools\uninstall.xml
[12/22/2014 12:50:35] Success Uninstall config file merging
[12/22/2014 12:50:35] Success Create uninstall data folder: C:\Program Files (x86)\Verisurf Uninstall\X8Tools
[12/22/2014 12:50:35] Success Create uninstall data file: C:\Program Files (x86)\Verisurf Uninstall\X8Tools\uninstall.dat
[12/22/2014 12:50:35] Notice Uninstall executable already exists: C:\Program Files (x86)\Verisurf Uninstall\X8Tools\\uninstall.exe
[12/22/2014 12:50:35] Notice Compared uninstall file versions. New: 9.3.2.0 Old: 9.3.2.0 Result: 0
[12/22/2014 12:50:35] Success Overwrite uninstall executable: C:\Program Files (x86)\Verisurf Uninstall\X8Tools\\uninstall.exe
[12/22/2014 12:50:35] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\VSDRW.dll
[12/22/2014 12:50:35] Success Create folder: C:\Program Files\mcamX8\chooks\Verisurf\
[12/22/2014 12:50:35] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\VSDRW.dll
[12/22/2014 12:50:35] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\1Verisurf.dll
[12/22/2014 12:50:35] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\1Verisurf.dll
[12/22/2014 12:50:35] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\2VScene.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\2VScene.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\StartUp.ft
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\StartUp.ft
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\StartUp.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\StartUp.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\CHooks\verisurf.menu
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\CHooks\verisurf.menu
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\VSTools.ft
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\VSTools.ft
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\VSTools.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\VSTools.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\1Verisurf.ft
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\1Verisurf.ft
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\2VScene.ft
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\2VScene.ft
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\MBD.ft
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\MBD.ft
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\MBD.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\MBD.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\MBDImport.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\MBDImport.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\MBDImport.ft
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\MBDImport.ft
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\documentation\Verisurf\MBD.pdf
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\documentation\Verisurf\MBD.pdf
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\FreeImage.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\FreeImage.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\LibFits.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\LibFits.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\revlibdll.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\revlibdll.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Windows\Fonts\Verisurf_MBD.ttf
[12/22/2014 12:50:36] Success Register font: Verisurf MBD (TrueType), C:\Windows\Fonts\Verisurf_MBD.ttf
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\AutoAlign.dll
[12/22/2014 12:50:36] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\AutoAlign.dll
[12/22/2014 12:50:36] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\SharedRes.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\SharedRes.dll
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\chooks\Verisurf\Devices\MiscImages\VWCSRotationArrows.vsi
[12/22/2014 12:50:37] Success Create folder: C:\Program Files\mcamX8\chooks\Verisurf\Devices\
[12/22/2014 12:50:37] Success Create folder: C:\Program Files\mcamX8\chooks\Verisurf\Devices\MiscImages\
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\Verisurf\Devices\MiscImages\VWCSRotationArrows.vsi
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\Data\Logo.png
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\Data\Logo.png
[12/22/2014 12:50:37] Skipped Archive file: C:\Program Files\mcamX8\boost_chrono-vc110-mt-1_55.dll (Reason: Existing file overwrite setting)
[12/22/2014 12:50:37] Skipped Archive file: C:\Program Files\mcamX8\boost_system-vc110-mt-1_55.dll (Reason: Existing file overwrite setting)
[12/22/2014 12:50:37] Skipped Archive file: C:\Program Files\mcamX8\boost_thread-vc110-mt-1_55.dll (Reason: Existing file overwrite setting)
[12/22/2014 12:50:37] Skipped Archive file: C:\Program Files\mcamX8\libxl.dll (Reason: Existing file overwrite setting)
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\pcl_common_release.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\pcl_common_release.dll
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\pcl_kdtree_release.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\pcl_kdtree_release.dll
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\pcl_octree_release.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\pcl_octree_release.dll
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\pcl_registration_release.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\pcl_registration_release.dll
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\pcl_search_release.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\pcl_search_release.dll
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\pcl_surface_release.dll
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\pcl_surface_release.dll
[12/22/2014 12:50:37] Skipped Archive file: C:\Program Files\mcamX8\ToolkitPro1631vc110x64.dll (Reason: Existing file overwrite setting)
[12/22/2014 12:50:37] Success Install archive file: C:\Program Files\mcamX8\chooks\VS_WCS.ft
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Program Files\mcamX8\chooks\VS_WCS.ft
[12/22/2014 12:50:37] Success Install archive file: C:\Users\jparis\Documents\my mcamx8\MCX\MBD DEMO PART\VERISURF TUTOR PART MM.mcx-8
[12/22/2014 12:50:37] Success File added to uninstall list: C:\Users\jparis\Documents\my mcamx8\MCX\MBD DEMO PART\VERISURF TUTOR PART MM.mcx-8
[12/22/2014 12:50:37] Skipped Archive file: C:\Users\jparis\Documents\my mcamx8\MCX\MBD DEMO PART\VERISURF TUTOR PART.mcx-8 (Reason: Existing file overwrite setting)
It says it added to the uninstall list but it still doesn't show
Here is the rest of the log file on my system.
[12/22/2014 09:57:24] Skipped Archive file: C:\Users\ehusted\Documents\my mcamx8\MCX\MBD DEMO PART\VERISURF TUTOR PART.mcx-8 (Reason: Existing file overwrite setting)
[12/22/2014 09:57:25] Success Copy uninstall image file: C:\Users\ehusted\AppData\Local\Temp\_ir_sf_temp_0\IRIMG1.JPG->C:\Program Files (x86)\Verisurf Uninstall\X8Tools\IRIMG1.JPG
[12/22/2014 09:57:25] Success Support file added to uninstall list: C:\Program Files (x86)\Verisurf Uninstall\X8Tools\IRIMG1.JPG
[12/22/2014 09:57:25] Success Copy uninstall image file: C:\Users\ehusted\AppData\Local\Temp\_ir_sf_temp_0\IRIMG2.JPG->C:\Program Files (x86)\Verisurf Uninstall\X8Tools\IRIMG2.JPG
[12/22/2014 09:57:25] Success Support file added to uninstall list: C:\Program Files (x86)\Verisurf Uninstall\X8Tools\IRIMG2.JPG
[12/22/2014 09:57:25] Success Registry key added to uninstall list: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Verisurf X8 Tools
[12/22/2014 09:57:25] Success Uninstall CP entry: DisplayName = Verisurf X8 Tools
[12/22/2014 09:57:25] Success Uninstall CP entry: UninstallString = "C:\Program Files (x86)\Verisurf Uninstall\X8Tools\\uninstall.exe" "/U:C:\Program Files (x86)\Verisurf Uninstall\X8Tools\uninstall.xml"
[12/22/2014 09:57:25] Success Uninstall CP entry: Publisher = Verisurf Software, Inc.
[12/22/2014 09:57:25] Success Uninstall CP entry: URLInfoAbout = http://www.verisurf.com
[12/22/2014 09:57:25] Success Uninstall CP entry: HelpLink = http://www.verisurf.com
[12/22/2014 09:57:25] Success Uninstall CP entry: Contact = Verisurf Software, Inc. Support Department
[12/22/2014 09:57:25] Success Uninstall CP entry: DisplayVersion = X8 tools 12-19-14
[12/22/2014 09:57:25] Success Uninstall CP entry: InstallLocation = E:\Program Files\mcamx8
[12/22/2014 09:57:25] Success Uninstall CP entry: DisplayIcon = "C:\Program Files (x86)\Verisurf Uninstall\X8Tools\\uninstall.exe"
[12/22/2014 09:57:25] Success Folder added to uninstall list: E:\Program Files\mcamx8\chooks\Verisurf
[12/22/2014 09:57:25] Success Folder added to uninstall list: E:\Program Files\mcamx8\chooks\Verisurf\Devices
[12/22/2014 09:57:25] Success Folder added to uninstall list: E:\Program Files\mcamx8\chooks\Verisurf\Devices\MiscImages
[12/22/2014 09:57:25] Notice Start project event: On Post Install
[12/22/2014 09:57:25] Success Run project event: On Post Install
[12/22/2014 09:57:25] Success Display screen: Finished Installing
[12/22/2014 09:57:26] Notice Start project event: On Shutdown
[12/22/2014 09:57:26] Success Run project event: On Shutdown
[12/22/2014 09:57:26] Success Delete image file: C:\Users\ehusted\AppData\Local\Temp\_ir_sf_temp_0\IRIMG1.JPG
[12/22/2014 09:57:26] Success Delete image file: C:\Users\ehusted\AppData\Local\Temp\_ir_sf_temp_0\IRIMG2.JPG
[12/22/2014 09:57:26] Notice Exit setup process (Return code: 0)
I got it to go....the 2nd time
1st time it hung again on trying to install the sample files in
C:\Users\jparis\Documents\my mcamx8\mcx\MBD DEMO PART
While manually deleting the incomplete installations, I deleted those this time, when re-running the installation the 2nd time, it completed sucessfully
Ok thanks for that info,  those files were disk write protected, so that was most likely the problem.
I removed those sample MBD files and made a new install. hope that fixes the problem. :pc:
Ernie
I had a sucessful instal following Jparis instructions Did not get your update in time Ernie
