Chip thinning and Mastercam
Greg_J
Hello Guys,
I'm machining a 1.25 wide slot 4.5 deep using a 1.0 high feed cutter.
The first part of cutting the slot is full diameter of the tool but on the way back the radial depth of cut is .25 so I use the chip thinning formula and my increased my feed.
The question I have is how do I get Mastercam to post that out, I don't want to manually go into the program and change the feed for every depth cut.
I played with the High feed settings in Mastercam but I'm not getting the desired results, but it could be that I'm not using correct settings.
Any ideas?
TIA,
Greg
Hello Guys,
Any ideas?
TIA,
Greg
Hi, GREG,
I think you should change contour mill to Peel Mill.
In the peel mill setting, you can increase the feed rate to a higher value, and set the step over value to about 7%(it depends on the material and tools)
i post a picture to explain what i mean
hope it will be helpful.
TOM
