Using Low elting point metal for tooling?
danielm
We have used similar materials for filling a void (pocket, bore, slot, whatever) before machining an adjacent feature; does a pretty good job preventing vibration and keeping thin walls from collapsing during cutting.
I would not think it would stand up very well to machining, with the melting point so low, and it is quite soft
In addition, because it is not bonded to the base material in any way, you would most likely jack it right out of your part unless the low-melt was encapsulated by the part somehow (like a dovetail or a t-slot).
Thinking way out on the fringe, if you need a threaded hole where you don't have any material; could you cast the low-melt around a Keensert, or a flange nut, or something like that?
C
You'd be better off using glass epoxy. It kinda looks like bondo. It does takes little while to cure but, when I worked in a wind-tunnel model shop on parts with no flat surfaces we could hold onto...it was the only hing that worked and did not contaminate the parts.
We use a LMP called Serametal. I have had good luck using it keep a shallow angle exit of a small drill strait and relatively burr free. I've used it as a temporary support for thin wall material, and I've used it as a down and dirty support for castings where the quantity was too low to justify a machined fixture.
