Buffer won't take string value
I'm trying to output data into .txt file for use in our intranet system.
I can pull most variables just fine, but some won't work.
This is my code that works:
size8 : 0
rc8   : 1
wc8   : 1
str8  : "" #empty string to be input for buffer write
fbuf 8 1 256 0 0
size8 = rbuf(8,0) #reading record zero initializes buffer
str8 = drs_str(2, mi4$) + " | " + drs_str(2, mi4$) + " | " + drs_str(2, Tool_var2) + " | " + drs_str(2, t$) + " | " + drs_str(2, speed) + " | " + drs_str(2, feed) + " | "
str8 = wbuf(8, wc8)
When I try to add drs_str(2, snamenc$) I get the error: (21 May 2015 09:47:11 AM - <2> - PST LINE (1007) - The arguments for this operator/function are not the same type (var/string)[9])
Could someone steer me towards getting the tool description to output to my buffer text file?
snamenc$ is a string variable already, drs_str is a function to convert a numeric value into a string, if you call it with a string value you will get an error since it is expecting a numeric value to be passed in.
If your looking for tool description though, its not really going to matter since snamenc is the name of the NC file .. if you want the tool name (which is what I think you mean by tool description, then its most likely strtool$ that you are looking for..
In order to grab this variable and write it to a buffer, you should probably to do it in the pwrtt$ postblock (or whatever block is writing the tooltable in your post) since that is the place where you can grab all the tools when the file is being pre-read.
Anyhow in answer to your original question, if you want to output the name of the NC file, you should be able to add snamenc$ instead of drs_str(2, snamenc$)
